Windows 7 Remove An Item From Right-Click Context Menu
Open the "Registry Editor" (Start (Orb), Run and type in regedit and click ok or press enter.)
Navigate to and expand each the following:
HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
(This is where programs attach to the right click menu.)
Now, you simply delete the keys you do not want.
Same method for Xp and Vista
Note: This is a registry change, do so at your own risk and back it up before hand.
