Resolution Problem
I have a problem with my monitor , Ihave LG Flatron W2043C and Intel G31 Chipset, My monitor's manual says default resolution is 1600x900 but but I cant see this resolution in my list. I only have 1600x1200 ,1400x1050 ,1280x1024 ,1024x768 .But when I trying to use 1600x1200 or 1400x1050 , it says "Frequency out of range".I can only use 1280x1024 and 1024x768. Then I installed Intel GMA driver it shows all resolutions including 1600x900. But when I use 1600x900 ,all text appeared really blured. all things are looking strached.I think 1600x1200 is my default resolution. Windows shows this as maximam resolution. Now how can I use 1600x1200 ??
Your screen shouldn't be blurry at 1600x900, thats the native resolution for the monitor. Try adjusting your display settings while using 1600x900. Right click on desktop and select personalize. Look to the bottom left you should see a link for display options. Check to make sure the magnification level is at default(100%) and ClearType text is enabled.
LG Flatron W2043C 20 inch Computer LCD Monitor
GENERAL
Manufacturer LG
Model Flatron W2043C
SCREEN
Screen Size 20 inch
Technology TFT active matrix
Screen Resolution 1600x900
