Revolutionizing Call Quality Management with AI in Dynamics 365 Contact Center
Dynamics 365 Contact Center is stepping up its game in call quality management by introducing an advanced AI summary feature built right into the closed conversation form. This strategic update empowers service representatives to review not only call recordings and transcripts but also a rich suite of post-call analytics—including sentiment analysis, key performance metrics, and even post-call survey results—all at the conversation’s conclusion. In a world where customer experience is paramount, have you ever wondered how quickly your team could resolve recurring issues if they had direct access to these insights?
windowsforum-revolutionizing-call-quality-management-with-ai-in-dynamics-365-contact-center.webp
A New Era in Call Data Insight​
Microsoft’s commitment to customer service excellence is evident in this update. Traditionally, once a call ended, agents and supervisors had to sift through multiple data sources to pull together information about the conversation. Now, with a single consolidated view, they can access:
  • Voice recordings and complete transcripts
  • AI-generated summaries that capture the entire conversation (including voicemails)
  • Sentiment analysis that provides immediate insights into the caller’s mood
  • Key metrics and performance data for each interaction
  • Post-conversation survey data revealing customer satisfaction (CSAT), First Contact Resolution, and Net Promoter Scores
  • A detailed Conversation Journey card that maps out the timeline, session durations, and agent transitions
This wealth of information enables a comprehensive review of customer interactions, accelerating both problem resolution and continuous improvement initiatives.
Key Features and Their Functionality​
One of the standout elements of the update is the AI summary feature. Unlike static transcripts, the AI summary distills the entire conversation—including voicemails—into an accessible narrative that captures all essential details without requiring agents to review lengthy call logs. This high-level summary helps teams quickly identify key issues and opportunities for service improvement.
Conversation Journey Card​
An equally innovative feature is the Conversation Journey card. This card provides granular details of each call segment, including:
  • The duration, date, and time of every segment
  • Identification of all call participants and agents involved
  • Detailed session information, where a new session is automatically created every time the primary agent is reassigned
  • Session headers that note the start time, total duration, and participation status
  • A record of session closures, complete with the agent’s exit time and the associated closure reason
By breaking down the call into discrete segments, the Journey card allows supervisors to pinpoint exactly where a conversation might have derailed or succeeded, offering a roadmap for training improvements and operational refinements.
Post-Call Survey Integration​
Administrators now have the ability to enable a dedicated post-conversation survey tab within the conversation form. This tab aggregates:
  • CSAT scores
  • Customer feedback in text form
  • First Contact Resolution outcomes
  • Net Promoter Scores
If the survey isn’t enabled or if the customer does not complete it, the tab remains hidden from the agent’s interface. This ensures that only actionable and complete data are presented, thereby maintaining focus on quality insights that drive performance improvements.
Unified Access to Voicemail Summaries​
The AI summary doesn’t stop at regular calls—it also extends to voicemails. This means that even a voicemail is summarized comprehensively rather than displaying just a snippet of the conversation. The agent thus gains a full understanding of the caller’s message without having to manually review the entire transcript.
Administrative Controls: How to Enable and Configure​
For organizations wishing to take full advantage of these innovations, the configuration process is straightforward:
  • Accessing the Copilot Service Admin Center:
  • Navigate to the “Insights” section and then select “Summaries.”
  • If a call summary was previously generated when the conversation ended, it will automatically appear; otherwise, it will generate when the transcript viewer loads.
  • Enabling the Post-Conversation Survey Tab:
  • Under “Voice call experiences” in the admin center, toggle on the option for the Post-conversation survey tab.
  • Be mindful that if surveys are not completed (or the tab isn’t enabled), the data will not appear to service representatives.
  • Note that calls with surveys are routed directly to the survey processing engine, specifically the Microsoft Copilot for Service Copilot Bot, ensuring that agents remain focused on real-time customer needs.
By centralizing control over these analytical features, IT administrators can ensure consistency in data capture and security compliance—a key consideration in any modern contact center environment.
The Technical Backbone of AI Summaries​
Behind these new capabilities lies a sophisticated blend of artificial intelligence and workflow automation. The system harnesses advanced natural language processing (NLP) and machine learning techniques to analyze the complete conversation transcript in real time. Consider these technical insights:
  • Real-Time Data Processing: Much like similar AI-driven summarization features discussed in Microsoft Teams call transfers, the system efficiently processes call data as soon as the conversation ends.
  • Natural Language Analysis: The AI examines contextual markers and key phrases to extract meaningful insights and generate a concise summary that encapsulates the conversation’s main points.
  • Session and Participant Tracking: By mapping out every phase of an interaction, the system logs session start and end times, reassignments, and closure reasons, offering a thorough breakdown of each call’s lifecycle.
This robust technical design not only enhances operational efficiency but also ensures that the derived insights are accurate, enabling businesses to pinpoint areas for improvement without wading through irrelevant details.
Broader Implications for the Contact Center Landscape​
The integration of AI summaries into Dynamics 365 Contact Center marks a significant evolution in how organizations manage and improve customer interactions. When compared to traditional methods of call monitoring and quality assessment, this update provides several broader benefits:
  • Efficiency Gains: Agents and supervisors no longer need to manually parse lengthy call logs. An instant, AI-captured snapshot is now available, saving valuable time and reducing cognitive overload.
  • Enhanced Problem Resolution: With comprehensive data available at their fingertips, service representatives can quickly identify and address customer issues, leading to faster resolutions and increased customer satisfaction.
  • Data-Driven Decision-Making: Detailed insights into agent performance, sentiment trends, and customer feedback enable continuous process optimization. This proactive approach is similar in spirit to other Microsoft product updates, such as Windows 11 updates and the regular rollout of Microsoft security patches, ensuring that systems remain secure and efficient in today’s fast-paced digital environment.
  • Improved Training and Support: The granular data provided by the conversation journey card serves as an excellent resource for training purposes. Supervisors can use real-world examples to coach agents on best practices and effective communication techniques.
As businesses continue to embrace digital transformation, integrated solutions like these not only boost efficiency but also foster a culture of continuous improvement. It’s an evolution that resonates across the entire Microsoft ecosystem, reinforcing the commitment to security and operational excellence—attributes that Windows users have come to expect from Microsoft innovations.
A Step-by-Step View of the New Workflow​
Imagine you’re a service representative ending a particularly challenging call. Here’s how the integration of the new AI summary transforms your workflow:
  • Call Completion: As the conversation ends, the system immediately processes the entire dialogue.
  • Data Aggregation: All call recordings, transcripts, and survey responses are compiled in a centralized location.
  • AI Summary Generation: The system utilizes NLP to analyze the conversation and generate a coherent, high-level summary, which includes sentiment analysis and key performance metrics.
  • Journey Mapping: The Conversation Journey card is updated with detailed session information, including agent reassignments and closure reasons.
  • Review and Feedback: Once the transcript viewer loads, the agent can review the AI summary alongside the detailed breakdown of the call—a tool that not only aids in self-evaluation but is also invaluable during quality assurance sessions.
This streamlined workflow reduces the time spent on administrative tasks, allowing agents to focus on improving their interactions, and in turn, enhancing overall customer satisfaction.
Future Outlook: Embracing a Data-Driven Customer Service Paradigm​
The integration of AI-powered summaries in Dynamics 365 Contact Center is more than just an incremental improvement; it’s a strategic leap towards a more intelligent, data-driven customer service model. By blending sophisticated AI algorithms with user-friendly interfaces, Microsoft is setting a new standard for call quality management. In real-world scenarios, this means:
  • Service centers will be better equipped to handle high call volumes without sacrificing quality.
  • Managers will gain instant access to actionable insights, ultimately leading to improved training, more efficient processes, and higher CSAT scores.
  • The unified view of call data fosters a truly collaborative culture where every stakeholder—from IT administrators to frontline agents—can work with the same data set, ensuring that the entire organization is aligned in its mission to deliver exceptional customer service.
Moreover, when juxtaposed with other industry innovations such as the integration of AI summarization in Microsoft Teams, this update underscores a broader shift in how businesses are leveraging artificial intelligence across the board. It’s a clear signal that efficiency, accuracy, and seamless integration are no longer optional—they are essential components of modern enterprise solutions.
Microsoft’s latest update to the Dynamics 365 Contact Center—integrating comprehensive AI summaries into the closed conversation form—demonstrates a thoughtful approach to modernizing call quality management. By providing a unified platform that captures every nuance of customer interactions, the system delivers:
  • Streamlined access to detailed call recordings, transcripts, and AI-generated summaries
  • Precise breakdowns of conversation journeys and session-specific data
  • Integrated post-call survey results that further illuminate customer satisfaction metrics
In an era where customer experience can make or break a brand, these innovations promise to transform traditional call centers into agile, data-driven hubs of customer engagement. As IT professionals and customer service representatives begin to harness these new tools, one can’t help but wonder: Will your contact center be ready to reap the benefits of this AI-powered revolution in call quality management?
The update is yet another strong indication of Microsoft’s relentless pursuit of operational excellence—akin to the regular Windows 11 updates and stringent Microsoft security patches that continue to bolster the overall ecosystem. Whether you’re an agent on the frontlines or an IT administrator fine-tuning your system’s performance, this innovation is poised to set new benchmarks for customer service in the digital age.
Source: Microsoft Use the Contact Center AI summary for call quality management - Microsoft Dynamics 365 Blog
