Windows 7 Right click menu delay in IE7/8/9...?
hLVE
Heya.
Not sure where else to post this, hopefully you guys will be able to help me figure out what's going on. This is an issue that I've had for a VERY long time in every IE install I try (IE 7/8/9) and both in x64bit and x32bit...
Video showing my issue ...
http://rockdown.net/Video_00004.wmv
Windows 7 x64 here... latest updates. not sure what the issue is.
Heya.
If you are having a lag/hang like that it should show in event viewer please
There are several ways to find what the problem is. The best is to go into event viewer (type eventvwr in search). Go to the windows log>application tab.
You want to look for critical errors (they have red in the left column ).
When you find them you want to look for critical errors...
Heya.
When you find them you want to look for critical errors that say app hang, app crash, or anything that relates to the problem.
When you find them please note the event ID, and the source codes and tell us what they are.
Let us know if you need help with any of this.
Ken
i've checked my eventvwr, found nothing relative...
though, i started checking IE.exe with process monitor... and found a lot.
Link Removed due to 404 Error
i compiled the errors from processmon into a spreadsheet, and exported the spreadsheet to html so you can all view and hopefully help :\
