zvit
Honorable Member
Anyone every see this, where in the "safely remove hardware" popup, it doesn't list the drive letters or info, so you can't know which drive to remove?
As a workaround, I am using a shortcut to the command: "C:\Windows\System32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll" which brings up the following window:
but this issue just started recently with a new computer and was wondering if anyone has a fix.
Some facts:
1. Restore is not an option.
2. Uninstalling things are not an option.
3. Yes, computer was restarted.
Thanks!
Some facts:
Thanks!
