Windows 7 Save As view stuck...
magaphoto
Win7HomePremium64:
For now, in SOME programs, (Audacity for example), During Save As into specific libraries (Docs in my case): How do you disable the Group By view? Nothing else seems available in context menus, also, in this situation New Folder is grayed out.
In my situation it's particularly infuriating since this machine's My Docs has thousands of directories, folders, and shortcuts, all I can do is watch them roll into place.
Look it up. I haven't seen this situation discussed elsewhere. As far as I know, this means it's something really simple or it's a Registry goof.
Thanks in advance.
Normally, after you select a Group By option, a NONE option will show up in the context menu that will cancel the action.
Top Bottom
