Search Engine Updates
Mike
Windows Forum Admin
  • Fixed cosmetic issue with search results that have a title that contains unicode characters
  • Better handling of non-standard latin characters (makes German, Spanish, Swedish and Norwegian work without needing setting)
  • Changed how delta indexes are threaded within distributed indexes
  • Fixed issue where a specific server setup could cause delta indexing of article comments to fail
  • Fixed rare issue where a delta index would be ignored as part of a distributed index
  • Sorting threads or posts by number of views works properly
  • Searching posts for all threads started by a user give correct results
  • Override $search_core class if using vBulletin 4.1.5+ (better way to disable vBulletin's search result cache)
  • Added setting to disable searching of private messages
  • Better handling of distributed indexes for non-suite installations
  • Added word stemming/morphology support (a search for "fly" will return "flies" and "flying" for example)
  • Fixed issue when searching for threads started by a specific user within a specific forum
