- Thread Author
- #1
An upgrade is not the route to take. It leaves useless files on your system and can cause conflicts.
Save all you Documents, Pictures, contacts, videos, music, etc to a flash drive,
Be aware, you will need to re-insatllall your 3rd party applcations.
Then perform a "clean" insatll.
I upgraded from xp. I have a primary and secondary in my pc, when i upgraded the secondary is no where to be found in my computer, i can still see it in devices, but there are no useful options for it. how can i read it, without having to reformat?
Link Removed you have to perform an upgrade with XP.
QUOTE]
Doesn't xp require a clean install? Only Vista upgrades... right?
I know an upgrade version will work based on seeing xp has been installed.. but I don't think it imports any system settings, software, personal files, photos, documents, etc. It's really a clean install isn't it?
