Windows 7 (Seemingly) Random BSOD's
mltinus
Hello,
BSOD's have been occuring on my PC for over 9 months now. They seem to be occuring at random moments (sometimes when i'm gaming, and other times when i'm not even at my pc).
I will attach the Seven Forums.zip to my reply on this post. The SF Diagnostic Tool results, screenshots from CPU-Z and the PASS-MARK RAMMon report are included.
There are a lot of dump-files, so hopefully someone can help me.
Thanks in advance,
Martin
Here are the required reports and files
  • Seven Forums.zip
Hi mltinus and Welcome to The Forum.
STOP 0xA0000001:
Usual causes:
Appears to be a custom bugcheck coded into ATI drivers
Your latest dump file lists atikmdag.sys as the probable cause. This is one of your Graphics Drivers.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download BSOD friendly Link Removed due to 404 Error as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the AVG Removal tool(s). Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
Drivers that pre-date Windows 7. Update:
atksgt.sys Sun May 17 14:36:34 2009
lirsgt.sys Sun May 17 14:06:57 2009
Copy Protection platform - Tages SA.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also loads with iTunes
Rt64win7.sys Thu Feb 26 09:04:13 2009 Realtek PCIe GBE Family Controller v7.048 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1469821) option to download.
speedfan.sys Sun Sep 24 14:26:48 2006 Speedfan.
Drivers with Updates:
atikmdag.sys Wed Apr 20 02:53:29 2011
atikmpag.sys Wed Apr 20 02:22:32 2011
AMD Graphics Drivers
A few other things to consider.
I'd do the following on your system. GoTo Start and in the Search or a Run... window type msconfig.msc and hit Enter.
Under the Start up tab, Disable:
MagicDisc
GoogleUpdate
AdobeAAMUpdater
& possibly Dropbox???
Then:
GoTo Start and in the Search or a Run... window type services.msc and hit Enter.
Bonjour: If you have an "i" product set start up to manual. If you haven't (it also comes with adobe) set start up to disabled.
Adobe Acrobat Update Service: Set start up to manual (good) or disabled (better). Any site you visit that may want you to view an "adobe type document" will tell you it's out of date, you don't need an auto-updater.
Bugcheck Analysis:
BugCheck A0000001, {5, 0, 0, 0}
Probably caused by : atikmdag.sys ( atikmdag+4cdb1 )
Followup: MachineOwner
2: kd> !analyze -v
Unknown bugcheck code (a0000001)
Unknown bugcheck description
Arguments:
Arg1: 0000000000000005
Arg2: 0000000000000000
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA0000001
PROCESS_NAME:  System
CURRENT_IRQL:  a
LAST_CONTROL_TRANSFER:  from fffff88005909db1 to fffff80002cc6c40
STACK_TEXT:
fffff880`0318c758 fffff880`05909db1 : 00000000`a0000001 00000000`00000005 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`0318c760 00000000`a0000001 : 00000000`00000005 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x4cdb1
fffff880`0318c768 00000000`00000005 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xa0000001
fffff880`0318c770 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x5
STACK_COMMAND:  kb
FOLLOWUP_IP:
atikmdag+4cdb1
fffff880`05909db1 ??              ???
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  atikmdag+4cdb1
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME:  atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4dae3c99
FAILURE_BUCKET_ID:  X64_0xA0000001_atikmdag+4cdb1
Drivers:
fffff880`05832000 fffff880`05870000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f41000 fffff880`00f98000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`04450000 fffff880`044d9000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`05870000 fffff880`05886000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`011bd000 fffff880`011c8000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`09848000 fffff880`09853000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00cda000 fffff880`00ce3000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`010cf000 fffff880`010f9000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`066db000 fffff880`066fb000   AtihdW76 AtihdW76.sys Fri Sep 24 06:44:48 2010 (4C9C3AD0)
fffff880`058bd000 fffff880`061f1000   atikmdag atikmdag.sys Wed Apr 20 02:53:29 2011 (4DAE3C99)
fffff880`04600000 fffff880`04650000   atikmpag atikmpag.sys Wed Apr 20 02:22:32 2011 (4DAE3558)
fffff880`07ee3000 fffff880`07f32000   atksgt   atksgt.sys   Sun May 17 14:36:34 2009 (4A1012E2)
fffff960`00920000 fffff960`00981000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`04733000 fffff880`0477a000   avgldx64 avgldx64.sys Thu Jun 03 22:06:48 2010 (4C081968)
fffff880`0472b000 fffff880`04732100   avgmfx64 avgmfx64.sys Wed Aug 17 12:31:52 2011 (4E4BA6A8)
fffff880`01880000 fffff880`0188c0c0   avgrkx64 avgrkx64.sys Thu Feb 11 03:52:44 2010 (4B737F0C)
fffff880`01576000 fffff880`015c7000   avgtdia  avgtdia.sys  Wed Apr 27 08:34:54 2011 (4DB7C71E)
fffff880`018cc000 fffff880`018d3000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0471a000 fffff880`0472b000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04195000 fffff880`041b3000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00650000 fffff960`00677000   cdd      cdd.dll      unavailable (00000000)
fffff880`077d5000 fffff880`077f2000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`0168b000 fffff880`016b5000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01850000 fffff880`01880000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d52000 fffff880`00db0000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`014a9000 fffff880`0151b000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`055ed000 fffff880`055fd000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`077f2000 fffff880`07800000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04679000 fffff880`046fc000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`046fc000 fffff880`0471a000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`045cb000 fffff880`045da000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06738000 fffff880`0675a000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0760c000 fffff880`07615000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`07600000 fffff880`0760c000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06760000 fffff880`06773000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06773000 fffff880`0677f000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05479000 fffff880`0556d000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0556d000 fffff880`055b3000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0104c000 fffff880`01060000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01000000 fffff880`0104c000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0152c000 fffff880`01536000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01ae9000 fffff880`01b33000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`047b6000 fffff880`047c3000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`02c01000 fffff800`02c4a000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`055b3000 fffff880`055d7000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`067aa000 fffff880`067c3000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`067c3000 fffff880`067cb080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0679c000 fffff880`067aa000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`040cc000 fffff880`04195000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01bea000 fffff880`01bf3000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`047a0000 fffff880`047b6000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0441a000 fffff880`04429000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`067cc000 fffff880`067da000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00b9f000 fffff800`00ba9000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`06617000 fffff880`0665a000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0675a000 fffff880`0675f200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07f32000 fffff880`07f3f000   lirsgt   lirsgt.sys   Sun May 17 14:06:57 2009 (4A100BF1)
fffff880`06600000 fffff880`06615000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0188d000 fffff880`018b0000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`01445000 fffff880`01481880   mcdbus   mcdbus.sys   Tue Feb 24 10:34:07 2009 (49A3CD1F)
fffff880`00cef000 fffff880`00d3e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`067e7000 fffff880`067f5000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04429000 fffff880`04438000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`067da000 fffff880`067e7000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`041b3000 fffff880`041cb000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`041cb000 fffff880`041f8000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`04000000 fffff880`0404e000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`015c7000 fffff880`015eb000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`016b5000 fffff880`016c0000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fa1000 fffff880`00fab000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0106c000 fffff880`010ca000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`045c0000 fffff880`045cb000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01bd8000 fffff880`01bea000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`010f9000 fffff880`01186000   mv91xx   mv91xx.sys   Wed Mar 17 07:53:06 2010 (4BA08A62)
fffff880`011b5000 fffff880`011bd000   mvxxmm   mvxxmm.sys   Wed Mar 17 07:52:37 2010 (4BA08A45)
fffff880`016c6000 fffff880`017b9000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`058aa000 fffff880`058b6000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`040a1000 fffff880`040b4000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`047c3000 fffff880`047f2000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`066c6000 fffff880`066db000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`04508000 fffff880`04517000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`01400000 fffff880`01445000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01536000 fffff880`01547000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`045b4000 fffff880`045c0000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c4a000 fffff800`03233000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`0125a000 fffff880`013fd000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`018c3000 fffff880`018cc000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0404e000 fffff880`040a1000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`044e2000 fffff880`04508000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00feb000 fffff880`01000000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fb8000 fffff880`00feb000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e78000 fffff880`00e88000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0151b000 fffff880`0152c000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`07f3f000 fffff880`07fe5000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`066fb000 fffff880`06738000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d3e000 fffff880`00d52000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`01060000 fffff880`0106be00   PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`05886000 fffff880`058aa000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04650000 fffff880`0466b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`045da000 fffff880`045fb000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04400000 fffff880`0441a000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04563000 fffff880`045b4000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`061f1000 fffff880`061fc000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01bf3000 fffff880`01bfc000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`099c3000 fffff880`099f1000   rdpdr    rdpdr.sys    Sat Nov 20 11:06:41 2010 (4CE7ABC1)
fffff880`017ee000 fffff880`017f7000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017f7000 fffff880`01800000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0980f000 fffff880`09848000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`01b9e000 fffff880`01bd8000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`040b4000 fffff880`040cc000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05800000 fffff880`05832000   Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`01186000 fffff880`011b5000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`07fe5000 fffff880`07ff0000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`05467000 fffff880`05473000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04517000 fffff880`04534000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01b97000 fffff880`01b9e000   speedfan speedfan.sys Sun Sep 24 14:26:48 2006 (45168798)
fffff880`01b8f000 fffff880`01b97000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0992b000 fffff880`099c3000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`098c2000 fffff880`0992b000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`07e00000 fffff880`07e31000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`055fd000 fffff880`055fe480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`018e5000 fffff880`01ae9000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`07ea2000 fffff880`07eb4000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01569000 fffff880`01576000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`099f1000 fffff880`099fc000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`01547000 fffff880`01569000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`0454f000 fffff880`04563000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`004e0000 fffff960`004ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`09800000 fffff880`0980f000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`0477a000 fffff880`047a0000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`0665a000 fffff880`0666c000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0677f000 fffff880`0679c000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`07615000 fffff880`07616f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`05456000 fffff880`05467000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`0666c000 fffff880`066c6000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`05400000 fffff880`05456000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`055d7000 fffff880`055e4000   usbuhci  usbuhci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`00fab000 fffff880`00fb8000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`018d3000 fffff880`018e1000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0761e000 fffff880`077d5000   viahduaa viahduaa.sys Sat May 15 11:22:39 2010 (4BEE75EF)
fffff880`017b9000 fffff880`017de000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00db0000 fffff880`00dec000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01b33000 fffff880`01b43000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01b43000 fffff880`01b8f000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`04534000 fffff880`0454f000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`017de000 fffff880`017ee000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e8e000 fffff880`00f32000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f32000 fffff880`00f41000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`044d9000 fffff880`044e2000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003b4000   win32k   win32k.sys   unavailable (00000000)
fffff880`00dec000 fffff880`00e00000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`055e4000 fffff880`055ed000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f98000 fffff880`00fa1000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`01482000 fffff880`014a3000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`07e31000 fffff880`07ea2000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0188d000 fffff880`0189b000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0189b000 fffff880`018a7000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018a7000 fffff880`018b0000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018b0000 fffff880`018c3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Thanks for the quick reply :).
I have already done almost everything you suggested except replacing AVG.
I will let you know how things go.
Thanks again,
Martin
Good to hear Martin. At least you have an idea on what is next to remove/change if you get another bsod. Although we'll need the dmp file.
Off Topic??
What you'll find is that (to me) the annoying Adobe Updater replaces itself in StartUp whenever you physically start any Adobe product.
Note I've not mentioned Adobe Reader once here before the "Use Foxit" brigade jump in!
See this thread on how to stop this happening. Link Removed - Invalid URL
Top Bottom
