Hi - back in Win95, and I think 98, there was a MS tool that you were able to d/l and use for free. It was called 'send to'. There are some who I am sure know exactly what I am talking about; for those who don't, the install would add a 'send to' cmd to the right-click menu, for any file or folder. So, if I wanted to move 123.txt from C:/Temp to D:/Temp, I would r-click on 123.txt, and there was the 'send to' cmd. Click it, select destination, and volia - that file is now copied into D:/Temp. Very convenient.
Is there any thing similar for W7?
Thanks!
Thanks!
