serious and confused
OK...my question is fairly simple: I installed w7 build 7600, is that Build the final version? When I open Everest and look at the info on my OS it still says "Trial". Does this mean it will shut down at some point or is it indeed the final retail version. I was led to believe it was the final retail version and I paid for it. Did I get screwed?
:confused: in Virginia
Joe S
Where did you get this from? Is it by chance the Enterprise edition for evaluation purposes? I think that had a time limit built in. If it's from torrent site you're on your own.
Joe
Joe
I don't recall it being Enterprise, it said Ultimate. I bought it online somewhere (can't remember which site as I was looking @ several). It installed fine, there is no watermark but it says Trial when I look at the Everest Info. I don't see a "stop date" however.
run Slmgr -xpr from the command prompt
You can also use -dli and -dlv for other info.
if you aren't activated you need an activation key code
