bestmitbbs
Recently, my computer has this BSOD problem almost everyday.
Attached is 5 instances. Seems to be similar problems. But don't know how to fix them. Thanks a lot!
Windows 7 Enterprise
Dell XPS 8100
Intel Core i7-870 processor(8MB Cache, 2.93GHz)
12GB DDR3 SDRAM at 1333MHz-2X2GB/2x4GB
ATI Radeon HD 5770 1024MB GDDR5 (320-9990)
1TB Serial ATA 2 Hard Drive 7200 RPM (342-0171)
Your USB controller persistently causes blue screens:
BUGCODE_USB_DRIVER (fe)
0000000080863b3c, PCI Vendor,Product id for the controller
Probably caused by : usbehci.sys ( usbehci!EHCI_sMode_PollEndpointSlot+67 )
Update drivers:
Intel Management Engine
HECIx64.sys Thu Sep 17 15:54:16 2009
Broadcom NetLink (TM) Gigabit Ethernet
k57nd60a.sys Fri Oct 16 06:29:38 2009
Unplug Logitech SetPoint.
Are you using any other USB devices besides Logitech SetPoint?
CRASH DUMPS
Loading Dump File [F:\DMP\051111-16052-01.dmp]
Mini Kernel Dump File: Only registers and stack...
Update drivers:
CRASH DUMPS
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`0301d000 PsLoadedModuleList = 0xfffff800`03262e90
Debug session time: Wed May 11 21:01:21.001 2011 (UTC - 4:00)
System Uptime: 0 days 9:33:28.000
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck FE, {5, fffffa800c4b21a0, 80863b34, fffffa800d16c258}
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: usbport!_DEVICE_EXTENSION                     ***
Followup: MachineOwner
3: kd> !analyze -v
USB Driver bugcheck, first parameter is USB bugcheck code.
Arguments:
Arg1: 0000000000000005, USBBUGCODE_INVALID_PHYSICAL_ADDRESS The host controller is
    using a physical memory address that was not allocated by
    the USBport driver.
Arg2: fffffa800c4b21a0, Device extension pointer of the host controller
Arg3: 0000000080863b34, PCI Vendor,Product id for the controller
Arg4: fffffa800d16c258, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xFE
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff880047b4f3e to fffff8000309d640
STACK_TEXT:
fffff880`031fda18 fffff880`047b4f3e : 00000000`000000fe 00000000`00000005 fffffa80`0c4b21a0 00000000`80863b34 : nt!KeBugCheckEx
fffff880`031fda20 fffff880`0477bfdf : 00000000`bd6d4380 fffffa80`0c4b36a0 fffffa80`0d16c3c8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`031fda60 fffff880`0477bba4 : fffff880`05d23100 fffff880`031fdc00 fffffa80`0d16c3c8 fffff880`014a4d00 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`031fdaf0 fffff880`04780c01 : fffffa80`0d16c258 fffffa80`0c4b21a0 fffffa80`09ce1890 00000000`00000000 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`031fdb70 fffff880`04788e8b : 00000000`00000002 fffffa80`0c4b21a0 00000000`00000000 00000000`00000040 : usbehci!EHCI_PollEndpoint+0x41
fffff880`031fdbb0 fffff880`0478d9d1 : 00000000`00000040 00000000`00000004 fffffa80`0d16c010 fffffa80`0c4b2050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`031fdbe0 fffff880`04799077 : fffffa80`0c4b21a0 00000000`00000040 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`031fdc40 fffff880`04789f89 : fffffa80`0c4b2050 00000000`00000000 fffffa80`0c4b2a02 fffffa80`0c4b2a18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`031fdca0 fffff800`030a8b1c : fffff880`031d5180 fffffa80`0c4b2a18 fffffa80`0c4b2a30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`031fdcd0 fffff800`0309536a : fffff880`031d5180 fffff880`031e00c0 00000000`00000000 fffff880`04789db0 : nt!KiRetireDpcList+0x1bc
fffff880`031fdd80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`0477bfdf 4533c9          xor     r9d,r9d
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  usbehci!EHCI_sMode_PollEndpointSlot+67
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: usbehci
IMAGE_NAME:  usbehci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7a66a
FAILURE_BUCKET_ID:  X64_0xFE_INVALID_PHYSICAL_ADDR_usbehci!EHCI_sMode_PollEndpointSlot+67
Loading Dump File [F:\DMP\050911-22042-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03066000 PsLoadedModuleList = 0xfffff800`032abe90
Debug session time: Mon May  9 12:09:49.223 2011 (UTC - 4:00)
System Uptime: 2 days 7:42:59.222
BugCheck FE, {5, fffffa800c4311a0, 80863b3c, fffffa800cc55c48}
***    work.                                                          ***
7: kd> !analyze -v
Arguments:
    the USBport driver.
Arg2: fffffa800c4311a0, Device extension pointer of the host controller
Arg3: 0000000080863b3c, PCI Vendor,Product id for the controller
Arg4: fffffa800cc55c48, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
BUGCHECK_STR:  0xFE
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff880053c8f3e to fffff800030e6640
STACK_TEXT:
fffff880`03392a18 fffff880`053c8f3e : 00000000`000000fe 00000000`00000005 fffffa80`0c4311a0 00000000`80863b3c : nt!KeBugCheckEx
fffff880`03392a20 fffff880`055aafdf : 00000000`bd719800 fffffa80`0c4326a0 fffffa80`0cc55ed8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`03392a60 fffff880`055aaba4 : fffff880`05fa3100 ffffffff`ffffff00 fffffa80`0cc55ed8 ffffffff`ffffff00 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`03392af0 fffff880`055afc01 : fffffa80`0cc55c48 fffffa80`0c4311a0 00000000`00000000 00000000`00000007 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`03392b70 fffff880`0539ce8b : 00000000`00000002 fffffa80`0c4311a0 00000000`00000000 00000000`00000070 : usbehci!EHCI_PollEndpoint+0x41
fffff880`03392bb0 fffff880`053a19d1 : 00000000`00000070 00000000`00000004 fffffa80`0cc55a00 fffffa80`0c431050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`03392be0 fffff880`053ad077 : fffffa80`0c4311a0 00000000`00000070 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`03392c40 fffff880`0539df89 : fffffa80`0c431050 00000000`00000000 fffffa80`0c431a02 fffffa80`0c431a18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`03392ca0 fffff800`030f1b1c : fffff880`0336a180 fffffa80`0c431a18 fffffa80`0c431a30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`03392cd0 fffff800`030de36a : fffff880`0336a180 fffff880`033750c0 00000000`00000000 fffff880`0539ddb0 : nt!KiRetireDpcList+0x1bc
fffff880`03392d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`055aafdf 4533c9          xor     r9d,r9d
Loading Dump File [F:\DMP\051011-20841-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0301c000 PsLoadedModuleList = 0xfffff800`03261e90
Debug session time: Tue May 10 06:46:00.767 2011 (UTC - 4:00)
System Uptime: 0 days 18:35:04.766
BugCheck FE, {5, fffffa800c4371a0, 80863b3c, fffffa800cc06c48}
***    work.                                                          ***
7: kd> !analyze -v
Arguments:
    the USBport driver.
Arg2: fffffa800c4371a0, Device extension pointer of the host controller
Arg4: fffffa800cc06c48, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
BUGCHECK_STR:  0xFE
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff8800542df3e to fffff8000309c640
STACK_TEXT:
fffff880`03392a18 fffff880`0542df3e : 00000000`000000fe 00000000`00000005 fffffa80`0c4371a0 00000000`80863b3c : nt!KeBugCheckEx
fffff880`03392a20 fffff880`055d7fdf : 00000000`bd751f00 fffffa80`0c4386a0 fffffa80`0cc06ed8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`03392a60 fffff880`055d7ba4 : fffff880`05fca100 ffffffff`ffffff00 fffffa80`0cc06ed8 ffffffff`ffffff00 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`03392af0 fffff880`055dcc01 : fffffa80`0cc06c48 fffffa80`0c4371a0 00000000`00000000 00000000`00000007 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`03392b70 fffff880`05401e8b : 00000000`00000002 fffffa80`0c4371a0 00000000`00000000 00000000`00000010 : usbehci!EHCI_PollEndpoint+0x41
fffff880`03392bb0 fffff880`054069d1 : 00000000`00000010 00000000`00000004 fffffa80`0cc06a00 fffffa80`0c437050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`03392be0 fffff880`05412077 : fffffa80`0c4371a0 00000000`00000010 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`03392c40 fffff880`05402f89 : fffffa80`0c437050 00000000`00000000 fffffa80`0c437a02 fffffa80`0c437a18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`03392ca0 fffff800`030a7b1c : fffff880`0336a180 fffffa80`0c437a18 fffffa80`0c437a30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`03392cd0 fffff800`0309436a : fffff880`0336a180 fffff880`033750c0 00000000`00000000 fffff880`05402db0 : nt!KiRetireDpcList+0x1bc
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`055d7fdf 4533c9          xor     r9d,r9d
Loading Dump File [F:\DMP\051211-16208-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0304b000 PsLoadedModuleList = 0xfffff800`03290e90
Debug session time: Thu May 12 05:41:03.171 2011 (UTC - 4:00)
System Uptime: 0 days 8:38:39.171
BugCheck FE, {5, fffffa800c3f11a0, 80863b3c, fffffa800cbd6c48}
***    work.                                                          ***
7: kd> !analyze -v
Arguments:
    the USBport driver.
Arg2: fffffa800c3f11a0, Device extension pointer of the host controller
Arg4: fffffa800cbd6c48, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
BUGCHECK_STR:  0xFE
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff88004a2df3e to fffff800030cb640
STACK_TEXT:
fffff880`03392a18 fffff880`04a2df3e : 00000000`000000fe 00000000`00000005 fffffa80`0c3f11a0 00000000`80863b3c : nt!KeBugCheckEx
fffff880`03392a20 fffff880`04480fdf : 00000000`bd6daa80 fffffa80`0c3f26a0 fffffa80`0cbd6db8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`03392a60 fffff880`04480ba4 : fffff880`05feb100 ffffffff`ffffff00 fffffa80`0cbd6db8 ffffffff`ffffff00 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`03392af0 fffff880`04485c01 : fffffa80`0cbd6c48 fffffa80`0c3f11a0 00000000`00000000 00000000`00000007 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`03392b70 fffff880`04a01e8b : 00000000`00000002 fffffa80`0c3f11a0 00000000`00000000 00000000`00000070 : usbehci!EHCI_PollEndpoint+0x41
fffff880`03392bb0 fffff880`04a069d1 : 00000000`00000070 00000000`00000004 fffffa80`0cbd6a00 fffffa80`0c3f1050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`03392be0 fffff880`04a12077 : fffffa80`0c3f11a0 00000000`00000070 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`03392c40 fffff880`04a02f89 : fffffa80`0c3f1050 00000000`00000000 fffffa80`0c3f1a02 fffffa80`0c3f1a18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`03392ca0 fffff800`030d6b1c : fffff880`0336a180 fffffa80`0c3f1a18 fffffa80`0c3f1a30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`03392cd0 fffff800`030c336a : fffff880`0336a180 fffff880`033750c0 00000000`00000000 fffff880`04a02db0 : nt!KiRetireDpcList+0x1bc
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`04480fdf 4533c9          xor     r9d,r9d
Loading Dump File [F:\DMP\051211-15818-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03005000 PsLoadedModuleList = 0xfffff800`0324ae90
Debug session time: Thu May 12 15:47:23.917 2011 (UTC - 4:00)
System Uptime: 0 days 2:48:38.916
BugCheck FE, {5, fffffa800c4701a0, 80863b3c, fffffa800cba8c48}
***    work.                                                          ***
7: kd> !analyze -v
Arguments:
    the USBport driver.
Arg2: fffffa800c4701a0, Device extension pointer of the host controller
Arg4: fffffa800cba8c48, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
BUGCHECK_STR:  0xFE
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff88004473f3e to fffff80003085640
STACK_TEXT:
fffff880`03192a18 fffff880`04473f3e : 00000000`000000fe 00000000`00000005 fffffa80`0c4701a0 00000000`80863b3c : nt!KeBugCheckEx
fffff880`03192a20 fffff880`0443afdf : 00000000`bd71d480 fffffa80`0c4716a0 fffffa80`0cba8db8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`03192a60 fffff880`0443aba4 : fffff880`05bd4100 ffffffff`ffffff00 fffffa80`0cba8db8 ffffffff`ffffff00 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`03192af0 fffff880`0443fc01 : fffffa80`0cba8c48 fffffa80`0c4701a0 00000000`00000000 00000000`00000007 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`03192b70 fffff880`04447e8b : 00000000`00000002 fffffa80`0c4701a0 00000000`00000000 00000000`00000010 : usbehci!EHCI_PollEndpoint+0x41
fffff880`03192bb0 fffff880`0444c9d1 : 00000000`00000010 00000000`00000004 fffffa80`0cba8a00 fffffa80`0c470050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`03192be0 fffff880`04458077 : fffffa80`0c4701a0 00000000`00000010 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`03192c40 fffff880`04448f89 : fffffa80`0c470050 00000000`00000000 fffffa80`0c470a02 fffffa80`0c470a18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`03192ca0 fffff800`03090b1c : fffff880`0316a180 fffffa80`0c470a18 fffffa80`0c470a30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`03192cd0 fffff800`0307d36a : fffff880`0316a180 fffff880`031750c0 00000000`00000000 fffff880`04448db0 : nt!KiRetireDpcList+0x1bc
fffff880`03192d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`0443afdf 4533c9          xor     r9d,r9d
Loading Dump File [F:\DMP\051211-15646-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0300a000 PsLoadedModuleList = 0xfffff800`0324fe90
Debug session time: Thu May 12 12:57:58.349 2011 (UTC - 4:00)
System Uptime: 0 days 0:31:32.237
BugCheck FE, {5, fffffa800c4af1a0, 80863b3c, fffffa800cb83c48}
***    work.                                                          ***
7: kd> !analyze -v
Arguments:
    the USBport driver.
Arg2: fffffa800c4af1a0, Device extension pointer of the host controller
Arg4: fffffa800cb83c48, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
BUGCHECK_STR:  0xFE
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff8800422df3e to fffff8000308a640
STACK_TEXT:
fffff880`03392a18 fffff880`0422df3e : 00000000`000000fe 00000000`00000005 fffffa80`0c4af1a0 00000000`80863b3c : nt!KeBugCheckEx
fffff880`03392a20 fffff880`043e5fdf : 00000000`bd6d2080 fffffa80`0c4b06a0 fffffa80`0cb83db8 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`03392a60 fffff880`043e5ba4 : fffff880`05beb100 ffffffff`ffffff00 fffffa80`0cb83db8 fffff800`030aa100 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`03392af0 fffff880`043eac01 : fffffa80`0cb83c48 fffffa80`0c4af1a0 00000000`00000000 00000000`00000007 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`03392b70 fffff880`04201e8b : 00000000`00000002 fffffa80`0c4af1a0 00000000`00000000 00000000`00000040 : usbehci!EHCI_PollEndpoint+0x41
fffff880`03392bb0 fffff880`042069d1 : 00000000`00000040 00000000`00000004 fffffa80`0cb83a00 fffffa80`0c4af050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`03392be0 fffff880`04212077 : fffffa80`0c4af1a0 00000000`00000040 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`03392c40 fffff880`04202f89 : fffffa80`0c4af050 00000000`00000000 fffffa80`0c4afa02 fffffa80`0c4afa18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`03392ca0 fffff800`03095b1c : fffff880`0336a180 fffffa80`0c4afa18 fffffa80`0c4afa30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`03392cd0 fffff800`0308236a : fffff880`0336a180 fffff880`033750c0 00000000`00000000 fffff880`04202db0 : nt!KiRetireDpcList+0x1bc
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`043e5fdf 4533c9          xor     r9d,r9d
DRIVERS
fffff880`0537a000 fffff880`053b8000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00f55000 fffff880`00fac000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`04a61000 fffff880`04a77000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`011af000 fffff880`011ba000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`09236000 fffff880`09241000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`058d2000 fffff880`058f5000   AtiHdmi  AtiHdmi.sys  Thu Apr 08 03:42:30 2010 (4BBD88E6)
fffff880`04a7e000 fffff880`0537a000   atikmdag atikmdag.sys Wed Jan 26 17:48:28 2011 (4D40A4BC)
fffff880`0463c000 fffff880`0468a000   atikmpag atikmpag.sys Wed Jan 26 17:13:33 2011 (4D409C8D)
fffff880`04464000 fffff880`0446b000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`047cf000 fffff880`047e0000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`056db000 fffff880`056f9000   bowser   bowser.sys   Tue Feb 22 23:55:04 2011 (4D649328)
fffff960`006b0000 fffff960`006d7000   cdd      cdd.dll      unavailable (00000000)
fffff880`04400000 fffff880`0442a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00ce1000 fffff880`00da1000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01850000 fffff880`01880000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00c83000 fffff880`00ce1000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01513000 fffff880`01585000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`04a51000 fffff880`04a61000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`059c2000 fffff880`059d0000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0472e000 fffff880`047b1000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`047b1000 fffff880`047cf000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`0471f000 fffff880`0472e000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05932000 fffff880`05954000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`059d0000 fffff880`059e3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`044b7000 fffff880`045d5000   dump_iaStorV dump_iaStorV.sys Thu Jun 10 20:46:19 2010 (4C11875B)
fffff880`059b6000 fffff880`059c2000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04271000 fffff880`04365000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`04365000 fffff880`043ab000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`09200000 fffff880`09236000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0104c000 fffff880`01060000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01000000 fffff880`0104c000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01596000 fffff880`015a0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01af7000 fffff880`01b41000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`04256000 fffff880`04263000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`035f4000 fffff800`0363d000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`043ab000 fffff880`043cf000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`0595a000 fffff880`059b6000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`043cf000 fffff880`043e0000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`03b18000 fffff880`03b31000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`03b31000 fffff880`03b39080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`03b0a000 fffff880`03b18000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05612000 fffff880`056db000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01bf1000 fffff880`01bfa000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`01091000 fffff880`011af000   iaStorV  iaStorV.sys  Thu Jun 10 20:46:19 2010 (4C11875B)
fffff880`04626000 fffff880`0463c000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04a00000 fffff880`04a51000   k57nd60a k57nd60a.sys Fri Oct 16 06:29:38 2009 (4AD84B12)
fffff880`01489000 fffff880`01498000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03b4f000 fffff880`03b5d000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00b97000 fffff800`00ba1000   kdcom    kdcom.dll    Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff880`0580e000 fffff880`05851000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`014f8000 fffff880`01513000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`017b8000 fffff880`017e3000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`05954000 fffff880`05959200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03b3a000 fffff880`03b4f000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`03bc2000 fffff880`03bd7000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03b6a000 fffff880`03b7e000   LMouFilt LMouFilt.Sys Tue Aug 24 13:21:43 2010 (4C73FFA7)
fffff880`03b7e000 fffff880`03ba1000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`03a72000 fffff880`03ac3d00   lvrs64   lvrs64.sys   Fri Apr 01 01:01:39 2011 (4D955C33)
fffff880`02401000 fffff880`027fd000   lvuvc64  lvuvc64.sys  Fri Apr 01 01:02:12 2011 (4D955C54)
fffff880`00c20000 fffff880`00c6f000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`03ac4000 fffff880`03ad2000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`013f0000 fffff880`013ff000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03b5d000 fffff880`03b6a000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e86000 fffff880`00ea0000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`0442a000 fffff880`0445b000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`09241000 fffff880`09251000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`056f9000 fffff880`05711000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05711000 fffff880`0573e000   mrxsmb   mrxsmb.sys   Tue Feb 22 23:56:22 2011 (4D649376)
fffff880`0573e000 fffff880`0578b000   mrxsmb10 mrxsmb10.sys Tue Feb 22 23:55:12 2011 (4D649330)
fffff880`0578b000 fffff880`057af000   mrxsmb20 mrxsmb20.sys Tue Feb 22 23:55:12 2011 (4D649330)
fffff880`01897000 fffff880`018a2000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fb5000 fffff880`00fbf000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0149a000 fffff880`014f8000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`04714000 fffff880`0471f000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01bdf000 fffff880`01bf1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01665000 fffff880`01758000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`04263000 fffff880`0426f000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`01214000 fffff880`01243000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`058bd000 fffff880`058d2000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`01645000 fffff880`01654000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`01600000 fffff880`01645000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01758000 fffff880`017b8000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`0932a000 fffff880`0933f000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`018a2000 fffff880`018b3000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04708000 fffff880`04714000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0300a000 fffff800`035f4000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0124d000 fffff880`013f0000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`0445b000 fffff880`04464000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`015a0000 fffff880`015c6000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00e00000 fffff880`00e15000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00fcc000 fffff880`00fff000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`01585000 fffff880`01596000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07476000 fffff880`0751c000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`058f5000 fffff880`05932000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c6f000 fffff880`00c83000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`053b8000 fffff880`053dc000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`053dc000 fffff880`053f7000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0468a000 fffff880`046ab000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`047e0000 fffff880`047fa000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`046b7000 fffff880`04708000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`043f1000 fffff880`043fc000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`044ae000 fffff880`044b7000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`09370000 fffff880`0939e000   rdpdr    rdpdr.sys    Sat Nov 20 06:06:41 2010 (4CE7ABC1)
fffff880`045f0000 fffff880`045f9000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0188e000 fffff880`01897000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`093b8000 fffff880`093f1000   RDPWD    RDPWD.SYS    Sat Nov 20 06:04:37 2010 (4CE7AB45)
fffff880`01ba5000 fffff880`01bdf000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`03bd7000 fffff880`03bef000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0751c000 fffff880`07527000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01b9d000 fffff880`01ba5000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`09292000 fffff880`0932a000   srv      srv.sys      Tue Feb 22 23:56:21 2011 (4D649375)
fffff880`0756a000 fffff880`075d4000   srv2     srv2.sys     Tue Feb 22 23:56:00 2011 (4D649360)
fffff880`07527000 fffff880`07558000   srvnet   srvnet.sys   Tue Feb 22 23:55:44 2011 (4D649350)
fffff880`043fc000 fffff880`043fd480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`018f3000 fffff880`01af7000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`07558000 fffff880`0756a000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`018d5000 fffff880`018e2000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`0939e000 fffff880`093a9000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`018b3000 fffff880`018d5000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`01200000 fffff880`01214000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`093a9000 fffff880`093b8000   tssecsrv tssecsrv.sys Sat Nov 20 06:04:09 2010 (4CE7AB29)
fffff880`04600000 fffff880`04626000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05851000 fffff880`05863000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`045d5000 fffff880`045efc80   usbaudio usbaudio.sys Sat Nov 20 05:43:52 2010 (4CE7A668)
fffff880`059e3000 fffff880`05a00000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`05800000 fffff880`05801f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`043e0000 fffff880`043f1000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05863000 fffff880`058bd000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04200000 fffff880`04256000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`03afe000 fffff880`03b0a000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`03aed000 fffff880`03afe000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`03ad2000 fffff880`03aed000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`015c6000 fffff880`015fba80   VBoxDrv  VBoxDrv.sys  Tue Jan 18 11:05:44 2011 (4D35BA58)
fffff880`01060000 fffff880`01084080   VBoxNetAdp VBoxNetAdp.sys Tue Jan 18 11:05:44 2011 (4D35BA58)
fffff880`011ba000 fffff880`011e2d00   VBoxNetFlt VBoxNetFlt.sys Tue Jan 18 11:05:43 2011 (4D35BA57)
fffff880`01654000 fffff880`0165fc40   VBoxUSBMon VBoxUSBMon.sys Tue Jan 18 11:05:44 2011 (4D35BA58)
fffff880`00fbf000 fffff880`00fcc000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0446b000 fffff880`04479000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`04479000 fffff880`0449e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00da1000 fffff880`00ddd000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01b41000 fffff880`01b51000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e2a000 fffff880`00e86000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01b51000 fffff880`01b9d000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`017e3000 fffff880`017fe000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`0449e000 fffff880`044ae000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ea2000 fffff880`00f46000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f46000 fffff880`00f55000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`018e2000 fffff880`018eb000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00030000 fffff960`00342000   win32k   win32k.sys   unavailable (00000000)
fffff880`00ddd000 fffff880`00df1000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`00fac000 fffff880`00fb5000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`03ba1000 fffff880`03bc2000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`0933f000 fffff880`09370000   WUDFRd   WUDFRd.sys   Sat Nov 20 05:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`07400000 fffff880`07471000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01880000 fffff880`0188e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`044bf000 fffff880`045dd000   dump_iaStorV
    Checksum:  00000000
    ImageSize:  0011E000
fffff880`045dd000 fffff880`045f0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Tried the suggestions but don't work. Need more help on this. Thank you! No other usb devices
Please read the first post in this sticky thread in the root of the BSOD. Once you have accumulated the data put it all into one folder, zip it up and attach it to your next post.
