- Thread Author
- #1
Hi. Im a volunteer admin at an emergency serveice and have been having issues for the last few days.
Initially when I attempted to log in (last week) I was getting the circle of dots non stop. I did some research and found the Server 2016 can sometimes take ages to do an update. Although I hadnt seen this before, I decided to leave it to continue.
When I checked again, I was able to log in. Since restarting the server im getting bad username or password and no network connection.I restarted in safe mode with networking and have been able to log in.
I have been unable to access windows update to run troubleshooting so I deleted the software distribution folder as I thought it might be an update issue.. No change
Ive run DISM /online/cleanup-image /checkhealth and scanhealth and both resulted that the component store is repairable.
I attempted to do a restore health using DISM but it cant find the source. I then downloaded Server 2016 Essentials and tried to use that as a source but no success. After numerous attempts at trying to use DISM over the last few days im finally asking for help. Any assistance is appreciated.
I also had a thought that maybe Active Directory is corrupted but that doesnt explain no network in normal boot.
Based on your updates and the attached
1. Analysis of Your
dcdiag output, here's a focused analysis and targeted action plan:1. Analysis of Your dcdiag Report
Major Points:
- AD Database Not Corrupt: The diagnostic completes initial setup and finds a single DC, so your database itself isn’t destroyed.
- Critical Services NOT Running: Key lines:
These are vital for domain controller operations and could explain the login/network failures in normal mode.Code:NETLOGON Service is stopped on [MRSERVER] kdc Service is stopped on [MRSERVER] DNS Service is stopped on [MRSERVER] - Connectivity & DNS Failures:
Code:The host 491a32e9-ab1b-4f13-a7b8-54ad639896d9._msdcs.MRCC19.local could not be resolved to an IP...
- Joined
- Mar 14, 2023
- Messages
- 100,266
This is a crucial breakthrough in diagnosing your issue. These logs reveal that:
and:
Share any unusual output.
Look for specific missing dependencies, failed drivers, or error codes.
Post the summary result (did it find/correct corruption?.
If SFC can’t start or fix, try DISM again as previously described, using the correct Server 2016 ISO/matching install.wim.
If set to Disabled, flip back to Automatic:
To sum up:
You haven’t lost AD data—it’s the “plumbing” beneath that has rusted through.
Focus on:
Let’s see if we can yank this back from the brink!
The Netlogon service depends on the Server service (LanmanServer), Workstation service (LanmanWorkstation), or their dependency group, and these are failing to start. The cascade effect is:
Server/Workstation services fail → Netlogon fails → AD and domain logins fail.
What Causes This?
- LanmanServer (Server service) and LanmanWorkstation (Workstation service) are foundational for network file/printer sharing, domain logon, AD, and almost all DC functions.
- If these services are failing, it strongly points to:
- Corrupt/missing system files or registry entries
- Broken network stack or dependent service(s)
- Bogus/faulty/disabled driver or service breaking their dependency chain
- Rare: Group Policy gone bad, or AV/EDR software interfering at the system level
What To Do Next
1. Check Dependent Services/Drivers
Let’s find out which dependency (service or driver) isn’t loading.View all dependencies for Server and Workstation services:
sc qc LanmanServer
sc qc LanmanWorkstation
Get-Service -Name LanmanServer, LanmanWorkstation | Select Name,Status,StartTypeShare any unusual output.
2. Investigate Service Startup Errors
Check event logs for errors related to “Server” or “Workstation” at boot:Get-WinEvent -LogName System | ? { $_.Message -like "*Lanman*" -or $_.Message -like "*Server service*" -or $_.Message -like "*Workstation service*" } | Select-Object -First 10 | Format-List TimeCreated,MessageLook for specific missing dependencies, failed drivers, or error codes.
3. Confirm Driver/Core Component Health
Some built-in Windows drivers must be running for LanmanServer/Workstation, such as:- srv.sys (for Server service)
- mrxsmb.sys (SMB redirector)
- Bowser, Browser, or similar legacy drivers
sfc /scannowPost the summary result (did it find/correct corruption?.
4. Check for Disabled Services
From Safe Mode, you can check if these services are Disabled (should be Automatic):Get-Service -Name LanmanServer, LanmanWorkstation | Select Name, StartType, StatusIf set to Disabled, flip back to Automatic:
Set-Service LanmanServer -StartupType Automatic
Set-Service LanmanWorkstation -StartupType Automatic
5. Check Device Manager for Warnings
- In Safe Mode, open Device Manager and see if any drivers, especially for network adapters or “System Devices,” have a yellow warning or error.
- Roll back/update as needed.
If All the Above Fail
- If services and system scans (SFC/DISM) fail to repair the Server/Workstation core, and dependencies are missing/corrupt, your OS might be too damaged for quick repair.
- At that point, an in-place repair install (with a matching Server 2016 ISO—select “upgrade/repair” not full wipe) or full backup restoration may be fastest and safest.
To sum up:
Focus on:
- Identifying missing/corrupt dependencies for Server/Workstation
- SFC/DISM scans and repairs
- Restoring correct service start types and core drivers
- Preparing for a repair install or system restore if these cannot be repaired
sc qc commands, dependency service states, and SFC scan.Let’s see if we can yank this back from the brink!
- Thread Author
- #22
sc qc LanmanServer - no responsesc qc LanmanWorkstation - no response
Get-Service -Name LanmanServer, LanmanWorkstation | Select Name,Status,StartType -
Name Status StartType
LanmanServer Stopped Automatic
LanmanWorkstation Running Automatic
TimeCreated : 22/07/2025 20:27:57Message : The Netlogon service depends on the Server service which failed to start because of the following error:
The dependency service or group failed to start.
TimeCreated : 22/07/2025 17:51:59
TimeCreated : 22/07/2025 15:03:18
TimeCreated : 22/07/2025 15:01:12
Message : The Netlogon service depends on the LanmanServer service which failed to start because of the following
error:
Message : The LanmanWorkstation service entered the running state.
TimeCreated : 22/07/2025 14:58:41
Message : The Tile Data model server service entered the stopped state.
TimeCreated : 22/07/2025 14:58:03
error:
TimeCreated : 22/07/2025 14:58:01
TimeCreated : 22/07/2025 14:55:54
TimeCreated : 22/07/2025 14:54:14
Message : The Netlogon service depends on the LanmanWorkstation service which failed to start because of the
following error:
SFC/ scannow found errors but could not fix all of them
i ran Set-Service LanmanServer -StartupType Automatic<br>Set-Service LanmanWorkstation -StartupType Automatic and they returned no info.
No warnings- Joined
- Mar 14, 2023
- Messages
- 100,266
Excellent troubleshooting and thanks for the thorough responses—this narrows things down considerably!
Let’s recap the findings and guide you toward the next, most effective actions:
Post results from DISM (or CBS log analysis, if you want), or confirm if you’re ready for restore/repair instructions. I can provide a step-by-step for the in-place upgrade/repair method if needed.
We’re nearly at the finish line—thanks for persevering!
Key Observations from Your Results
1. LanmanServer (Server service) Will Not Start
- LanmanServer is set to Automatic, but not running.
- Netlogon and other critical DC services depend on LanmanServer. This is why domain logon, file sharing, and much more are blocked.
2. sc qc LanmanServer yields no response
- This suggests underlying registry or system corruption: the
Service Control Managercan’t query the Server service’s configuration, which is very abnormal. - “No response” is itself a rare, serious sign; usually, it should at least return configuration details.
3. LanmanWorkstation is Running
- This means at least some network stack is functional, but the “server side” component is missing or broken.
4. SFC Result: ‘Found errors but could not fix all of them’
- There’s definite corruption. SFC wasn’t able to repair all system files—very likely including the LanmanServer service or its dependencies.
5. No Device Manager Warnings
- This makes it less likely to be a hardware/NIC driver problem—this is core system/registry/service file corruption.
Diagnosis Summary
You have a classic “critical system component or registry corruption” scenario—almost certainly tied to the files/services for Server (LanmanServer), and possibly other components SFC couldn’t fix. This is a known failure pattern for systems that have experienced:- Botched or interrupted Windows Updates
- Disk corruption or critical file system issues
- Wrongful interference by third-party software or GPO
- Earlier attempts at manual file removal
Action Plan: Final Repair Attempts
1. Check CBS.log for Corrupted Files
You can get more details about what SFC couldn’t fix:findstr /c:"[SR]" %windir%\logs\cbs\cbs.log > C:\sfcdetails.txt- You can upload
sfcdetails.txthere if you’d like help reviewing it. - Look for references to files like
srv.sys,srvsvc.dll, registry hives, or other system core files.
2. Run DISM with Correct Source
If you haven’t already, run:DISM /Online /Cleanup-Image /RestoreHealth /Source:wim:X:\sources\install.wim:1 /LimitAccess- Replace
X:with your mounted Server 2016 matching ISO location. - If you used the wrong edition/image index, it will fail; use:
dism /Get-WimInfo /WimFile:X:\sources\install.wim
to list all indexes and try the exact one for your install.
3. If DISM Fails: Consider In-Place Upgrade Repair or Restore
Given that your Server service is literally not findable by SCM or sc qc, a repair install (in-place upgrade) or restoration from a backup will almost certainly be required.- In-place OS repair: Boot from Server 2016 matching media and choose “Upgrade” (this keeps roles/data but repairs Windows system files and registry).
- Restore from backup: If repair install is blocked or fails, restoring a good image from just before the incident is your fastest route.
Summary Table
| Symptom | Outcome | Next Step |
| LanmanServer NR | Broken | DISM repair, else repair install |
| SFC fails | Corruption | Check CBS.log, run DISM |
| DeviceMgr OK | No HW issue | Focus on system/registry repair |
| Login/auth fail | Expected | Result of core service failure |
Bottom Line
- You’ve ruled out most surface-level issues.
- The failure of LanmanServer to respond to
sc qcand refusal to start confirms deep corruption. - Final step: Try DISM one last time (making very sure the source media matches your install and you’re using the correct index).
If it fails, proceed with an in-place upgrade repair or restore from backup.
- Joined
- Mar 14, 2023
- Messages
- 100,266
Good catch—using
If the DC is not pointing at itself for DNS, you will have:
Fixing this is critical before attempting further repairs or logins in normal mode.
Please update your DNS settings so the DC points to itself, then attempt to start DNS, LanmanServer, and Netlogon. Let me know if these services now start or if the same errors persist.
This one setting may dramatically change your results!
8.8.8.8 (Google DNS) is not correct for a domain controller. On a Windows Server domain controller, your main (or only) DNS server must point to itself (127.0.0.1 or its own static IP), not an external DNS like Google.If the DC is not pointing at itself for DNS, you will have:
- AD and Netlogon failures (since they rely on SRV records in your domain DNS)
- Inability to properly register its own records
- Domain logon, replication, and various services will fail
What You Should Do (in Safe Mode with Networking):
- Update the DNS Settings
- Open a command prompt and run:
Get-NetIPConfiguration - Note your network adapter name (e.g., "Ethernet").
- Set DNS to localhost (127.0.0.1) or your server’s static IP:
Set-DnsClientServerAddress -InterfaceAlias "Ethernet" -ServerAddresses 127.0.0.1
(Replace"Ethernet"if your adapter is named differently. - OR, if you prefer, set to your server’s actual static IP.
- Confirm the Change
- Run:
ipconfig /all
Ensure the “DNS Servers” list only shows your DC (127.0.0.1 or its static IP).
- Run:
- Flush DNS Cache
- Just in case:
ipconfig /flushdns
- Just in case:
- Try Restarting Key Services
- Now try to start the DNS service:
Start-Service DNS - Then the Server service:
Start-Service LanmanServer - Then Netlogon:
Start-Service Netlogon - Note any errors.
Why This Matters
Having an external DNS like Google in a domain environment blocks Active Directory services from resolving internal records, which can render your DC non-functional—even if everything else is healthy.Fixing this is critical before attempting further repairs or logins in normal mode.
- Joined
- Mar 14, 2023
- Messages
- 100,266
Great question—this is important to clarify before taking such a major step.
Let me know if you need a full checklist or step-by-step for the repair install, or if you have new results after your DNS change!
In-Place Upgrade/Repair and Its Impact
What Is an In-Place Upgrade (Repair Install)?
- An in-place upgrade or repair install of Windows Server 2016 means you boot from the same version/edition installation media and choose the option to upgrade/repair the existing OS (not a clean install).
- It replaces corrupted/missing system files, fixes registry/service configuration, but retains server roles, data, applications, AD DS (Active Directory), and Group Policy settings.
Will It Affect Active Directory or Folder Redirection?
Active Directory
- No, Active Directory will NOT be lost in a successful in-place upgrade.
- All domain data, users, groups, GPOs, and DNS records (if running AD-integrated DNS) will be preserved.
- The server remains the domain controller after the repair.
Folder Redirection
- Folder redirection GPOs and their links/settings in AD are not changed by the OS in-place upgrade; they will continue to exist and apply to computers/users as before.
- The contents of redirected folders (on local disks or shares) are not touched by the repair install.
- However: If the folder redirection targets are on this server, and shares/filesystem permissions have been modified/corrupted due to earlier OS issues, validate them post-upgrade.
- Double-check that NTFS and share permissions remain as you intend after the upgrade.
Best Practices Before Repair Install
- Full Backup:
You’ve mentioned cloud backup—make sure you have a current, tested bare-metal or image backup before starting. - Backup System State:
Optionally, use Windows Server Backup to grab a “System State” backup (includes AD DS, boot files, registry). - Document Shares and Permissions:
Although data and shares should persist, document your shares and folder permissions as a precaution.
After the In-Place Upgrade
- Check all Windows Updates (you'll likely need to reapply cumulative updates).
- Review AD DS health: Run
dcdiagandrepadmin /showrepl(if you ever add another DC). - Test folder redirection: Log on with a test user to ensure redirection/GPOs function.
Bottom Line
- In-place upgrade/repair is explicitly designed to fix Windows system/registry corruption while preserving AD and all user data including redirected folders and GPOs.
- It is the best OS repair method when SFC/DISM can't fix core components and you want to avoid rebuilding the server.
- Joined
- Mar 14, 2023
- Messages
- 100,266
Great catch! That’s a PowerShell cmdlet, and it looks like you're in Command Prompt or possibly PowerShell on an older version (some early Windows Server builds lack “NetTCPIP” module by default).
No worries—here’s how you can get your network adapter name and set DNS from either PowerShell or regular Command Prompt:
If something still doesn’t work, let me know the exact error messages.
If you prefer a one-liner for PowerShell on older Windows versions, try:
But if that’s unavailable, the
Once DNS is corrected, this may change your service-startup results. Please let me know if services now launch, or if you hit new errors—we’ll be one step closer to resolving the root issue!
1. Identify Your Adapter Name (in Command Prompt)
ipconfig /all- Look for the correct “Ethernet adapter” name (common names:
Ethernet,Local Area Connection, or a custom name).
2. Set DNS to Localhost (From Command Prompt)
- Replace
Ethernetwith your adapter’s actual name if needed:
netsh interface ipv4 set dnsservers "Ethernet" static 127.0.0.1 primary- If you want to use your server’s static IP as DNS, change
127.0.0.1to the actual IP address.
3. Verify DNS Setting
ipconfig /all- Under your main adapter, ensure “DNS Servers . . . . . : 127.0.0.1” (or the server’s static IP) is now set.
4. Try Starting DNS, Server, Netlogon Again
- After updating DNS, proceed as previously instructed:
- Start DNS service
- Then attempt to start LanmanServer (Server service)
- Then Netlogon
- Note if error messages change or if any of these services will now start.
Set-DnsClientServerAddress -InterfaceAlias "Ethernet" -ServerAddresses 127.0.0.1But if that’s unavailable, the
netsh approach always works.Once DNS is corrected, this may change your service-startup results. Please let me know if services now launch, or if you hit new errors—we’ll be one step closer to resolving the root issue!
- Joined
- Mar 14, 2023
- Messages
- 100,266
No, that line shows the adapter hardware description, not the "interface name" needed for
What you need for the
Example:
In this example, the adapter’s name for
then your
If you’re unsure, just copy and paste the relevant header lines (the ones above the "Description") from your
Once you’ve set DNS, proceed with starting the services as previously described. Let me know the results!
netsh.What you need for the
netsh command is the “adapter name” (e.g., Ethernet, Local Area Connection, or similar), which appears just above the description line in the ipconfig /all output.Example:
Ethernet adapter Ethernet: Description . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet #2 Physical Address. . . . . . . . : xx-xx-xx-xx-xx-xx ...
netsh is Ethernet. If your section header is something like:Ethernet adapter Local Area Connection 2:then your
netsh command would use "Local Area Connection 2".How to Proceed
- Find the line in your
ipconfig /alloutput that looks like:
Ethernet adapter [YOUR ADAPTER NAME]:
Example:Ethernet,Local Area Connection,Ethernet 2, etc. - Plug that exact name (inside quotes, if it contains spaces) into the command below:
netsh interface ipv4 set dnsservers "YourAdapterNameHere" static 127.0.0.1 primary
(Replace"YourAdapterNameHere"with what you found.
ipconfig /all, and I’ll tell you exactly which name to use.Once you’ve set DNS, proceed with starting the services as previously described. Let me know the results!
- Joined
- Mar 14, 2023
- Messages
- 100,266
Not quite—“Connection-specific DNS Suffix . : local.tld” is only showing the DNS domain that’s assigned to this interface.
The adapter name is the label that appears right above this, in the output of
Here’s what to look for in your output:
In the above, the name
If you see something like:
then you would use
To be sure:
ipconfig /all.Here’s what to look for in your output:
Ethernet adapter Ethernet: Connection-specific DNS Suffix . : local.tld Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet #2 ...
"Ethernet" is your adapter name for netsh.If you see something like:
Ethernet adapter Local Area Connection 2:then you would use
"Local Area Connection 2".To be sure:
- Please copy and paste the 3-4 lines above the “Description” line (including the line with the colon), or attach the
ipconfig /alloutput directly, and I’ll tell you exactly which name to use in yournetshcommand.
ipconfig output, let me know and I’ll review it for you!- Thread Author
- #34
I set the DNS and static ip as they should be using command prompt. ipconfig /all confirms correct setting. However i am unable to access the internet in safe mode and still cannot log in normally.
I also notice many distributedcom errors
- Joined
- Mar 14, 2023
- Messages
- 100,266
You’ve got your static IP and DNS set correctly, but:
Summary:
You’ve now ruled out configuration as the root problem—the issue is service/OS corruption beneath. DCOM errors are a symptom, not the cause.
The only safe way forward is a repair install (in-place upgrade) from matching Server 2016 media, or restoring from backup.
Let me know if you need a step-by-step for performing the in-place upgrade/repair install, or want guidance on restoring from backup. You’ve done excellent, thorough troubleshooting!
- Safe Mode blocks internet by design. In Safe Mode (even with Networking), many services—including those responsible for network location awareness, authentication, firewalls, and even some network drivers—are purposely disabled. It is normal for internet access to be restricted or only partially working.
- Unable to log in normally: This persists because your core AD/DC services are still unable to start in normal mode (as covered before with your Server/LanmanServer/Netlogon failures).
About the DistributedCOM (DCOM) Errors
DistributedCOM (DCOM) errors are extremely common after major network or service failures and are almost always secondary to the main issues. They typically occur because:- Critical DC services can’t start, so DCOM/RPC endpoints for AD, DNS, and similar can’t be reached.
- Network misconfiguration prevents Windows from connecting to required local or domain resources.
What To Do Now
1. Confirm All Key Settings
- Static IP, correct subnet, and gateway: ✔
- DNS = 127.0.0.1 or server’s IP (not external): ✔
2. If Services Will Not Start, and No Normal Login:
- This confirms system/registry/corruption issues remain. Even with correct TCP/IP settings, DC services (LanmanServer, Netlogon, DNS, etc. must be able to start and talk to the network. Since they won't start, and SFC/DISM couldn't repair all files, you are left with only these real options:
Final Steps: In-Place Upgrade (Repair Install) or Restore
- Repair Install (In-Place Upgrade)
- Use a Server 2016 ISO/USB/DVD of the exact same edition/build as currently installed.
- Boot into Windows (Safe Mode with Networking works), and run
setup.exefrom the media. - Choose the 'Upgrade' option (not a clean install; do NOT format disks).
- This will:
- Repair Windows system files and registry (including broken services like LanmanServer)
- Keep AD, data, GPOs, and folder redirection intact
- Require re-applying some Windows Updates post-repair
- This process is tried-and-true for saving a broken DC when remote repair is impossible and you want to avoid a full restore.
- If Setup/Repair Install Fails to Start
- If Windows cannot run setup (even in Safe Mode), or if the repair install is blocked, restore your most recent backup.
- This wipes out the corruption and brings the server back to last healthy state.
After In-Place Repair or Restore:
- Double-check:
- AD health (
dcdiag) - Server/Netlogon/DNS services are running
- Folder redirection, shares, permissions, group policies
- AD health (
- Update Windows fully, reinstall the latest network drivers from the vendor
Summary:
- Joined
- Mar 14, 2023
- Messages
- 100,266
Great questions—this step is critical for avoiding data loss or further complications, especially on a domain controller.
2. Data Volumes (D:\, E
Summary Table:
Let me know your backup solution type, and I can advise precisely which options to check/uncheck. Never restore only parts of C:\Windows for an AD server—do the full system volume.
If you need more info or clarification, just ask!
Restoring from Backup: What Should You Restore?
1. Domain Controller Scenario:
- If you want to restore operating system health, Active Directory, and all registry/service configuration, you must restore the entire system volume (usually the whole C: drive), ideally from a bare-metal/server image or a full “system state” backup.
- Restoring "just"
C:\Windowsis NOT safe or supported—the registry, service configurations, and many critical dependencies live outside that one folder. - A partial restore (copying over C:\Windows or similar) risks mismatched files, unbootable OS, or Active Directory corruption. Microsoft explicitly does not support piecemeal OS or AD file/directory restores.
- Restoring "just"
2. Data Volumes (D:\, E :
- Your D: and E: drives, since they hold databases and redirected folders, should NOT be restored unless those files are also corrupt or lost.
- Restoring these is only necessary if those databases or shared file/folder contents are damaged.
- Doing a C: only (system) restore should leave D: and E: untouched, preserving your data.
- Always review your backup solution’s documentation, but with most image or system-state backups, restoring C: won’t overwrite other volumes unless you tell it to.
Best Practice for Restoring a Domain Controller
- Full System/OS Volume Restore (C
: - Use your backup solution's "system recovery" or "bare metal" option, or restore the entire system (C
partition to its state just before the failure. - This guarantees Active Directory, the registry, installed programs, and Windows services are restored to known-good status.
- Leave D: and E: As-Is (unless corrupt):
- Do not overwrite D: and E: unless those drives’ files are also compromised or the backup is meant to roll back the entire server including data changes.
- After Restore:
- Confirm system health, AD operation, and services start correctly.
- Verify D: and E: data are untouched (except for reversion of possibly “open” files to their snapshot state if using a volume-aware system backup).
Special Note: System State Backup
- If you have a system state backup, you can sometimes restore AD/registry/services without a full C: overwrite, but this is advanced, more error-prone, and not a universal fix.
- For major OS corruption, full C: restoration is safer.
Summary Table:
| Drive | When to Restore | What it Affects |
| C: (System) | Always, for AD/OS | OS, AD, registry, services, installed apps |
| D:\, E:\ (Data) | Only if corrupted | User data, DBs, folder redirection (avoid if healthy) |
Final Advice
- When restoring a system image/OS volume, double-check that you replace only C: unless your intent is to revert all drives.
- If in doubt, consult your backup software's documentation or specify what tool/solution you're using, and I’ll give step-by-step instructions.
- Joined
- Mar 14, 2023
- Messages
- 100,266
That's an important consideration—restoring from a cloud backup service like iDrive requires internet access on the target server (or at least on a system that can mount or transfer the restore data). Here are your practical next steps:
Let me know if you need step-by-step guidance for restoring from an iDrive backup, or if you want instructions for performing an in-place Server 2016 repair install from local media.
If you have downloaded any logs/tools for reference, let me know how you'd like to proceed—or upload the log/text so I can help further!
Options When the Server Has No Internet Access
1. Restore to a Different Machine, Then Transfer Locally
- If you have another computer with internet access:
- Log in to iDrive from that working machine.
- Download the full system backup or the latest image of the C: drive (choose "entire machine" or "system state" if possible).
- Transfer the restore data to the affected server using a USB drive or over the local network.
- Use recovery tools (e.g., bootable Windows Server rescue media or backup agent) to restore the backup onto the correct server volume.
2. Use iDrive’s Restore Options in Safe Mode (If You Can Get Internet Working)
- If you can get any kind of internet access in Safe Mode with Networking (e.g., via tethering, wireless, temp switch), you can try initiating the restore directly from the iDrive agent/software on the server.
- Temporarily connect a laptop/tablet as a hotspot if that's an option, just for the restore process.
3. Physical Media Restore
- Some backup services offer shipment of a physical drive containing your backup data (may take longer and often costs extra).
4. Repair Install While You Troubleshoot Connectivity
- If restoring from backup is blocked due to lack of connectivity, you could try the in-place upgrade repair install method from Server 2016 media as discussed earlier. This doesn’t require downloading from iDrive and may resolve the corruption.
- Afterward, fix the network drivers/services. If Internet returns, you’ll still have the restore backup as a fallback.
Extra: Diagnosing No Internet in Safe Mode
- In Safe Mode with Networking, double-check:
- Your IP/gateway/DNS config is correct (which you’ve done).
- Try pinging the default gateway (local router) and 8.8.8.8:
Code:ping 8.8.8.8 ping [your_gateway_ip] - If pings fail, your network adapter may lack full Safe Mode drivers, or services are still missing.
- If the local network (not just Internet) doesn't work in Safe Mode, only a full repair or restore will bring services up in normal mode.
Next Steps
- Download backup on another system if possible.
- Attempt a repair install from your Windows Server 2016 media while your local backups are accessible.
- If you succeed in repairing the OS and get Internet back, you can do an iDrive restore if needed.
Similar threads
- Solved
- Replies
- 4
- Views
- 180
- Solved
- Replies
- 9
- Views
- 628
- Replies
- 12
- Views
- 93
- Replies
- 0
- Views
- 27
- Article
- Replies
- 0
- Views
- 81
