Hi
I am a developer. I have installed one of our product in a Windows 7 machine. Started the program by simple double click the shortcut in Desktop. Then from the program while trying to take print (by clicking on command button which sends print commands into printer) it fails. Then I executed the program from a command prompt after opened the command prompt as 'Administrator', then the print works. How can we give the print and other related things to be enable/can set the permissions if we execute the program by simply double click the short cut key?
Regards
Soorjith P
Regards
Soorjith P
