Setting Folder Default
Flupsie
Well-Known Member
I would like to know how to set a particular folder as the deafault when open up a file for eg how do I set "My Documents" folder as the default folder
Your assistance will be most appreciated
davehc
Do you mean when you open Windows explorer.?
That would be
C:\Windows\explorer.exe /n, /e, C:\(here the folder of your choice)
But if you mean , for example, if you open up, say, a .doc. This would open in Word, or Open office, whatever you have installed. The default folder would be whatever you had chosen in the configuration of Word.
Flupsie
Well-Known Member
Thanks for the reply. I have managed to figure out how to set the default when I open Word or Excel
davehc
OPk. No Prob. Glad you got it sorted out!
