Windows 7 side-by-side confiruration is incorrect
TomD
I've just downloaded and installed Quicken2010 on a brand new computer with Win 7 :D. When I try to run Quicken 2010 I get the error "The Application has failed to start because its side-by-side configuration is incorrect. ..." in a pop up. The rest of the error text says, "Please see the application event log or use the command-line sxstrace.exe tool for more detail." I tried the sxstrace program. It opened and instantly closed without a trace - :frown:. I can't find the relevant event log, and likely wouldn't know what to do with the info if I did find it! -:confused: Any guidance is welcome. Thanks, Tom.
Top Bottom
