Siemens’ SIMATIC RTLS Locating Manager — the Windows-based server component that fuses UWB tag data into real-time location feeds — was the subject of a fresh security republishing on August 12–14, 2025 that calls out multiple mid-to-high severity flaws, including two newly tracked CVEs: CVE-2025-30034 (a reachable assertion that can cause denial-of-service) and CVE-2025-40751 (insufficient protection of credentials in Report Clients), and urges operators to update to Locating Manager v3.3 or later. The vendor advisory and the consolidated advisories make clear the remediation: update the Locating Manager to V3.3, isolate RTLS infrastructure, and harden the Windows host — guidance that is mirrored across Siemens’ ProductCERT and public vulnerability databases.
A compact server sits on a desk in a high-tech control room, surrounded by monitors displaying blue network diagrams.Background​
SIMATIC RTLS Locating Manager is the central software component in Siemens’ RTLS suite: it ingests gateway measurements, computes positions, and exposes them via APIs to higher-level systems (MES, WMS, analytics). The product family spans several SKU/license lines (6GT2780-0DA00 / -0DA10 / -0DA20 / -0DA30 / -1EA10 / -1EA20 / -1EA30), deployed globally in manufacturing, logistics and transportation use cases. The product’s continued presence in critical-manufacturing and transportation environments makes any vulnerabilities in it operationally sensitive. This release is the latest in a multi-stage disclosure history for RTLS Locating Manager: Siemens previously addressed a large set of CVEs tied to earlier releases (V3.0.1.1 and earlier), and the August 2025 ProductCERT release (SSA-707630) consolidates new issues and points customers to the V3.3 remediation. CISA also maintains archived advisories for this product family and has repeatedly echoed vendor guidance to limit network exposure for control systems.
Executive summary of the vulnerabilities​
  • Scope: All SIMATIC RTLS Locating Manager versions prior to V3.3 are listed as affected by the two CVEs highlighted in the republished advisory.
  • Key CVEs called out in the August 2025 advisory:
  • CVE-2025-30034 — Reachable Assertion (CWE‑617). Affected devices do not properly validate input sent to a listening port on the local loopback interface; an unauthenticated local attacker could cause a denial-of-service condition. Siemens reports a CVSS v3.1 base score of 6.2 and a CVSS v4.0 score of 6.9 for this issue. This CVE record is available in public vulnerability databases. (cert-portal.siemens.com, nvd.nist.gov)
  • CVE-2025-40751 — Insufficiently Protected Credentials (CWE‑522). Report Clients do not properly protect credentials used to authenticate to the RTLS server, which could allow an authenticated local attacker to extract credentials and escalate from Manager to Systemadministrator. Siemens lists CVSS v3.1 6.3 and CVSS v4.0 4.8 for this issue; public trackers and scanner vendors have also published entries. (cert-portal.siemens.com, tenable.com)
  • Exposure/attack vector: Both issues are primarily local (Attack Vector = Local in the vendor vectors); CVE-2025-30034 requires local loopback interaction while CVE-2025-40751 requires local authenticated access to a Report Client. These are not described as remotely exploitable without additional access, but other vulnerabilities in older advisories affected remote paths and integrity of updates — so operators should treat the entire product lifecycle as potentially exposed. (cert-portal.siemens.com, cisa.gov)
  • Remediation: Update to SIMATIC RTLS Locating Manager V3.3 or later; Siemens’ advisory explicitly points customers to the V3.3 update and to additional hardening guidance.
Technical analysis​
CVE-2025-30034 — Reachable assertion (CWE-617)​
CVE-2025-30034 is described as improper input validation on a listening port bound to the loopback interface. In practice this means a local process or user that can connect to 127.0.0.1 can provide input that reaches a code path with an unchecked assertion; when triggered, this assertion leads to a denial-of-service (service crash or abort). Siemens documents the exact CVSS vectors and severity and the public NVD entry echoes the summary and scoring submitted by the vendor; scanner vendors have also indexed the CVE for enterprise detection. Operators should therefore treat local processes, scheduled tasks, and any software running on the same host as potential attack vectors. (cert-portal.siemens.com, nvd.nist.gov)
Why loopback matters: many server suites expose maintenance or inter-process endpoints on loopback intentionally — administration utilities, local synchronization services, or update agents may listen there. If these endpoints assume a trusted local environment without validating untrusted input, it opens a path for lateral privilege escalation from a lower-privileged local user or a compromised host process. Mitigations must therefore include both software patching and host-level hardening (restricting local user accounts, disabling unnecessary services, and running the Locating Manager under least privilege).
CVE-2025-40751 — Insufficiently protected credentials (CWE-522)​
CVE-2025-40751 affects Report Clients’ handling of credentials used to authenticate to the Locating Manager server. Siemens’ description indicates credentials can be extracted by an authenticated local attacker, enabling escalation to the Systemadministrator role — that is both an authentication-bypass escalation and a confidentiality failure for stored secrets. Siemens lists this as requiring local authenticated access to a Report Client (local on the same machine or local network segment), and public vulnerability trackers (Tenable, security databases) reiterate the scoring and vectoring. (cert-portal.siemens.com, tenable.com)
The practical risk here is straightforward: if operator consoles, third‑party reporting clients, or desktop machines running track-view or report functions store credentials in plaintext or improperly encrypted stores, an attacker who can run code locally, access disk files, or read process memory could harvest elevated credentials and pivot into a more powerful administrative account. In OT/IT-converged networks this is a high-impact escalation path because RTLS Admin/Systemadministrator roles often control configuration and operational parameters for positioning and integration.
How these vulnerabilities fit into the larger RTLS security picture​
These two CVEs are part of a larger set of earlier and related issues disclosed for RTLS Locating Manager in 2024–2025 (hard-coded keys, download-without-integrity-check, buffer overflows, resource exhaustion, improper permissions, cleartext transmission). The product’s prior advisory (SSA‑093430 and other SSA notices) documented multiple critical issues and required updates to V3.0.1.1 and later; the new SSA‑707630 consolidates later issues and directs customers to V3.3. The pattern is common: complex, feature-rich server components that expose inter-process and client-server interfaces tend to accumulate both remote and local vulnerabilities across code paths (update logic, local tools, API endpoints). Two operational takeaways:
  • Patching alone is necessary but not sufficient: secure configuration, network segmentation, host hardening, and least-privilege operation remain essential compensating controls.
  • Local access is as important as remote access: many compromises begin with a local foothold, a misconfigured workstation, or a compromised admin machine, then use credentials or local endpoints to escalate.
Risk evaluation and real‑world impact​
Siemens and CISA both emphasize that successful exploitation could allow denial-of-service or privilege escalation from Manager to Systemadministrator. The vendor scores for the two CVEs (CVSS v3.1 ~6.2–6.3; CVSS v4.0 values vary) place them in the medium severity band individually — but in aggregate with prior critical weaknesses (e.g., hard-coded keys or missing integrity checks), the practical risk to a production environment increases markedly. Public vulnerability repositories and scanner vendors list these items with matching vectors and community-tracked EPSS/occurrence data; at time of publication there are no reliable reports of in-the-wild exploitation specifically targeting these CVEs, but that caveat is time‑sensitive and must be rechecked during incident response cycles. (cert-portal.siemens.com, tenable.com, cisa.gov)
Why this matters operationally:
  • Availability: a crashing Locating Manager can halt position feeds to dependent systems (WMS, AGV fleets, asset tracking dashboards), producing operational disruption and potential safety or logistic impacts.
  • Integrity & control: harvested credentials that grant Systemadministrator rights can permit persistent misconfiguration, tampering with position outputs, or insertion of malicious code into the ecosystem (for example, manipulating update artifacts if older integrity-check CVEs exist).
  • Lateral movement in IT/OT-converged environments: RTLS components are often integrated with business systems. Compromise of RTLS admin accounts can become a pivot point into higher-value systems.
Mitigation and step‑by‑step remediation (practical playbook)​
Siemens’ explicit advice: update to V3.3 or later. The vendor provides a V3.3 package and accompanying operational guidance; CISA and industry best-practice documents reiterate network isolation and defense-in-depth. (cert-portal.siemens.com, cisa.gov)
Follow this prioritized sequence:
  • Inventory and assess
  • Identify all hosts running SIMATIC RTLS Locating Manager (server and clients) and record installed versions and SKU numbers (6GT2780-*).
  • Tag any Report or Track Viewer Clients, operator consoles, and test/development hosts that may store RTLS credentials.
  • Patch management
  • Schedule immediate upgrades to SIMATIC RTLS Locating Manager V3.3 or later in test first, then production following change-control. Siemens’ ProductCERT advisory lists V3.3 as the remediation for the latest CVEs.
  • Where patching is delayed, implement compensating controls (see network isolation below).
  • Host hardening and least privilege
  • Harden the Windows host: remove unnecessary accounts, disable local interactive logons for service accounts, run services with the least privileges necessary, and ensure the host is fully patched and monitored.
  • Lock down local file permissions for client config stores and credential caches.
  • Network isolation and segmentation
  • Place RTLS servers behind dedicated OT/DMZ firewalls; do not expose Locating Manager or its clients to the public internet.
  • Restrict inter-host communications to known IPs/ports and apply allow-listing.
  • Use VLANs, micro-segmentation, and strong access control lists to separate operator workstations, test benches, and administrative consoles from the production RTLS server.
  • Protect credentials and secrets
  • Rotate credentials used by Report Clients and Manager accounts after patching.
  • Adopt secure credential storage (OS secrets stores, enterprise vaults with access controls), avoiding plaintext files or hard-coded keys. If clients used persistent credentials, ensure storage is encrypted and access-controlled.
  • Update and verify integrity checks
  • Confirm update delivery paths use integrity checking (signed packages, TLS with certificate validation); previously disclosed issues in this product family included missing integrity verification for updates.
  • Monitoring and detection
  • Enable process, file, and event logging on RTLS hosts and collect logs centrally.
  • Monitor for unusual service restarts, privilege escalations, or unexpected API calls to the Locating Manager endpoints.
  • Incident readiness
  • Prepare rollback plans and verified backups before applying patches.
  • If sensitive credentials are suspected to have been exposed, assume compromise and proceed with credential change and forensic evaluation.
Short — and medium‑term operational recommendations for IT/OT teams​
  • Treat RTLS management and associated operator consoles like any other critical server: patch quickly, harden hosts, and restrict access. This is not a “nice-to-have” for asset tracking systems; it is a core operational control.
  • Replace any local file-based credential storage with managed secrets (hardware-backed or enterprise vault).
  • Segregate test and training networks from production: training labs and demo environments are frequent infection vectors due to weaker segmentation and ephemeral user populations. Previous RTLS advisories highlighted training/test exposure as a common weakness.
  • Periodically review Siemens ProductCERT advisories and treat vendor CSRF/crypto/patch-related notices as actionable security bulletins. Siemens’ ProductCERT pages and their CSAF feeds are the canonical update sources for this product line.
Critical appraisal — strengths and remaining risks​
Notable strengths in Siemens’ response​
  • Timely consolidated advisory and a clear remediation version (V3.3) — Siemens ProductCERT published SSA‑707630 with direct guidance to update; the advisory lists CVE identifiers and CVSS vectors, enabling enterprises to triage using standard tooling. This reduces ambiguity for patch management and vulnerability scanning.
  • Comprehensive prior disclosures — Siemens’ earlier advisories (V3.0.1.1 era) documented high-severity remote issues (hard-coded keys, integrity-check bypasses) and mandated upgrades; the cumulative transparency allows defenders to apply multiple compensating controls while performing updates.
Residual and systemic risks​
  • Local‑only vector does not mean low real-world risk. Local access is often easier than assumed: compromised operator workstations, remote desktop connections, VPN‑exposed admin machines, or malicious insiders can obtain the “local” presence required. The consequence is that local CVEs often become remotely exploitable in large, poorly segmented environments. This is an industry-wide failure mode in OT/IT convergence.
  • Patch lag and complex operational schedules — industrial environments typically have long maintenance windows and rigorous change control; delaying patches is common and increases exposure when multiple CVEs exist across several components (clients, server, gateways).
  • Interdependent vulnerabilities — the RTLS product history shows multiple distinct weaknesses (e.g., hard-coded keys, unsigned updates). While CVE‑2025‑30034 and CVE‑2025‑40751 are moderate as single items, combined with older critical issues they materially raise the attack surface. Detection and mitigation must be holistic. (cisa.gov, cert-portal.siemens.com)
Quick checklist for Windows administrators (concise, actionable)​
  • Update Locating Manager to V3.3 immediately where feasible.
  • Harden the Windows server: apply OS patches, remove unneeded local accounts, enforce least privilege.
  • Rotate and re-protect credentials used by Report Clients and Manager roles; migrate to enterprise vaults where possible.
  • Isolate RTLS hosts from the business internet and corporate networks using firewalls and segmentation.
  • Verify update integrity mechanisms (signed packages, TLS) and disable insecure update paths until verified.
  • Enable logging and central monitoring of RTLS server and client hosts.
  • Plan maintenance windows and change control to reduce patch lag.
Verification, cross‑checks, and what remains time-sensitive​
All numerical claims and CVE metadata cited here were verified against Siemens’ ProductCERT advisory SSA‑707630 and public vulnerability databases (NVD and vendor trackers). Siemens’ SSA‑707630 lists both CVE‑2025‑30034 and CVE‑2025‑40751 and confirms V3.3 as the remediation. Public trackers (NVD/Tenable) published matching CVE entries and the CVSS vector/score details used here; vendor advisories and CISA archived guidance reiterate recommended mitigations (network isolation, patching, hardening). These multiple independent sources align on the core facts. (cert-portal.siemens.com, nvd.nist.gov, tenable.com)
Caveats and time-sensitive items:
  • Statements like “no known public exploitation” are accurate as of the publication date of the referenced advisories, but this is a rapidly changing space; organizations must re-check feeds (Siemens ProductCERT, NVD, CISA) regularly during incident response and patch cycles. (cisa.gov, cert-portal.siemens.com)
  • Some CVE records are still undergoing NVD enrichment; minor score adjustments and vector clarifications can occur after vendor publication. If precise CVSS values are critical for risk scoring, pull the vendor CNA entry and the current NVD record at time of triage. (nvd.nist.gov, cert-portal.siemens.com)
Final assessment and recommendations​
The August 2025 republishing of SIMATIC RTLS Locating Manager advisories consolidates a straightforward operational imperative: update to V3.3, harden the Windows hosts, and treat RTLS infrastructure as high-value OT assets. The two CVEs discussed here reinforce the recurring theme in industrial cybersecurity: local trust assumptions are fragile, credential storage must be threat-modeled, and defense-in-depth (patching + segmentation + least privilege + monitoring) is the only reliable posture.
  • Immediate action is to inventory, patch, and isolate — prioritize systems that interface directly with production automation or transport systems.
  • Medium-term programs should strengthen operational processes: secrets management, software bill-of-materials for RTLS components, and routine security testing in lab environments that mirror production segmentation.
  • Long-term: require vendors to standardize cryptographic protections, integrity checks for updates, and secure default configurations so that out-of-the-box deployments are not trivially exploitable.
Operators and administrators who manage RTLS deployments must assume that vulnerabilities — especially in complex server components — can be chained. A single local weakness combined with prior critical flaws (unsigned updates, hard-coded keys) can escalate into a widespread compromise. The recommended course remains the same: patch quickly, harden comprehensively, and monitor continuously. (cert-portal.siemens.com, cisa.gov)
This feature article used Siemens’ ProductCERT advisory SSA‑707630 and public vulnerability trackers to verify technical details and scoring, and synthesizes vendor guidance with established OT/IT security best practices to create a practical, prioritized remediation and hardening plan for SIMATIC RTLS Locating Manager deployments. (cert-portal.siemens.com, nvd.nist.gov, tenable.com)
Source: CISA Siemens SIMATIC RTLS Locating Manager | CISA
