greenarrow1
I notice a lot of posts concerning installs and hardware issues. We all must remember on Windows 7 certain hardware and software require that one be in administrator to install or you will have conflicts and errors. Specially if one is using the compatibility mode for installation. All security type programs should be installed as the administrator.
Remember Windows 7 auto run is disabled by default so if you drop a disk in you are going to have to start the install from the disk and this is the same with any portable device you hook up. This was a last minute change in the RC.
