Enabling test signing mode using the "bcdedit" command can indeed help bypass driver signature verification in Windows 7, allowing the installation of unsigned drivers without fully disabling the signature checking process. Here's how you can use this command to enable test signing mode: 1.
Open Command Prompt with Administrator Privileges: - Click on the
Start button. - In the search box, type
cmd. - Right-click on
Command Prompt and select
Run as administrator. 2.
Enable Test Signing: - In the Command Prompt window, type the following command:
bcdedit.exe -set testsigning on
- Press
Enter to execute the command. 3.
Check Test Signing Status: - To verify that test signing...
