32 bit apps don't run, 64 bit apps do Was
Some applications do not start.)
Hi, hope someone can help me with this. Having a problem that is almost worse than a program crashing. (At least I would get an error so I can see what is the cause of the problem.) Anyhow this is the sequence of events.
In the morning I "woke" up my pc from sleep and had no problems (basically surf web and read email, play some fb games
). I went to work. Coming home I woke up my pc again, and noticed some of my browser windows were no longer open, then I realized it looked like my machine rebooted. The desktop was showing, but the normal apps that remain open during start up were not present. I looked at the status bar?(the area that shows active apps like, sound volume, network connection, USB devices, New updates available, Microsoft Security Essentials...) and noticed only about 1/3 of the icons were showing. I naturally wanted to start up ie to search for this problem, but ie did not start up. Meaning, I double clicked on the icon and nothing showed up. I tried applications listed below.
ie does not start
Google Chrome does not start
Firefox does not start
Command Shell starts, able to ping externally so probably isn't network related?
word does not start
Notepad works, but doesn't help me much
Windows Update does not start
same problem in safe mode
Rebooted back to normal mode (not safe mode) and noticed Windows gadgets start to appear about 3 minutes after desktop appears.
performed a scandisk (had to reboot of course)
Started Microsoft Security Essentials, got it uptodate, ran quick scan, nothing found.
I eventually found out internet explorer 64 bit works! I searched and found this forum. Using problem identification guidelines posted.
1) rebooted to capture beginning of ev log. on boot up eventviewer (after 2 minutes comes up)
2) Device Manager shows no yellow triangles
3) permon /report shows (as expected from ev log)
Diagnostic Results/Warnings:
Symptom: A service is reported as having an unexpected error code
Cause: One or more services has failed. The service did not stop gracefully, suggesting the service may
have crashed or one of its components stopped in an unsupported way.
Details: Service exited with code not equal to 0 or 1077
Resolution: Restart the service
Related: Performance Diagnosis
I'm not sure what else is relevent in the report. It does show under Anti-Virus Information that a Query
of root\SecurityCenter:SELECT * FROM AntiVirusProduct resulted in 0x0.
4) "Find and Fix" did not have any thing for my problem
5) n/a did not upgrade from Vista, was a new install 2 years ago?
Properties(right clicking and selecting Properties) on Computer does nothing.
Running dxdiag does nothing (from Run option and cmd.exe)
Edit Added:
It's looking like 32 bit applications do not start, but 64 bit applications do. For example programs in the Program Files (x86) will not start, but programs in the Program Files (assuming these are 64 bit) do start.
Also I've used msconfig and found same results when booting with no startup items, and no Services started.
So is there an system application that runs the 32 bit applications on windows 64 bit? It seems that program does not work on my machine now. Is there any way to replace it?
Begin Edit Morning of June 9th, 2012
I've tried system restore and it failed during the restore, and then windows failed to boot. I was able to get it back to the same state? now with windows repair, sfc, and replacing reported bad files from windows 7 install disk.
End Edit Jun 9th 2012
Begin Edit June 10th, 2012
I'm 90% sure it's just 32 bit applications that don't start.
- Application Verifier does not start
- Application Verifier (x64) does start
- Internet Explorer (Program Files x86) does not start
- Internet Explorer (Program Files) does start
End Edit June 10th, 2012
Any ideas where go to from here?
Thanks,
Dan
ie does not start
word does not start
- The server {E10F6C3A-F1AE-4ADC-AA9D-2FE65525666E} did not register with DCOM within the required timeout.
- The Peer Name Resolution Protocol cloud did not start because the creation of the default identity failed
- with error code: 0x80630801.
- The Peer Name Resolution Protocol service terminated with the following error: %%-2140993535
- Session "Microsoft Security Client OOBE" stopped due to the following error: 0xC000000D
- A timeout was reached (30000 milliseconds) while waiting for the Akamai NetSession Interface service to connect.
- A timeout was reached (30000 milliseconds) while waiting for the Apple Mobile Device service to connect.
Edit Added:
Thanks,
Dan
