Hi, I have some small questions. (Grey means solved)
Can the key repeat speed of my keyboard be increased beyond the maximum of the slider?
Is there a way to stop Windows Live Messenger to be active on my bar, even when the window isn't open, and instead move it to the active processes in the lower right corner like all other good programs?
Is there a way to tweak the cursor jump with using mousekeys more precisely, in terms of pixels, because the slider just doesn't do it for me?
Is there a way to stop the other windows closing when I shake a window?
Is there a way to stop windows resizing when I drag them to the edge of the screen? The option in the configuration settings is already turned off, but it's still doing it.
Is there a way to stop dwm.exe from running, even though the fancy effect is turned off.
Is there a way to reset my internet connection more easily? Right now I need to go to network center, LAN-connection, turn it off (for some reason this closes the window, so I can't enable it easily), click on the red x in network center opening the problem solver, wait a bit, get insulted by windows thinking I'm an idiot, skip that step, wait a bit more, enable network adapter thingy, and when the internet connection is restored, I close the problem solver before it notices that it has resolved the problem.
I'm one of those guys that works more efficiently with the windows Vista setup of the start-bar. So I tweaked it so I have a quicklaunch, I see all active processes, the same program windows won't collapse and such, I hated having to click twice as much to do the same thing, nor could I stand the mess created.
But if you can resolve any of my requests, I'd be a happier man.
Thank you in advance
CX
CX
