sound/audio
Discussion in 'Windows Vista Help and Support' started by allioops, Jan 31, 2007.
  1. allioops
    allioops New Member
    Jan 31, 2007
    4
    0
    Just purchased new computer with vista already installed. The only problem I'm having is that the sound is much lower. We are using the same speakers-nothing fancy-just 2 speakers that came with our previous Compaq. I have checked everything-everything is up to '100' or at the max. Any advice?
  2. josh_rain
    josh_rain New Member
    Jan 23, 2006
    94
    0
    make sure the sound drivers are installed correctly, see if there are any updates to the driver. Also, get rid of the speakers. Go to staples and buy a decent speaker system for around $30. You can get a sub and everything for cheap. New speakers is your safest option.
  3. Mike
    Mike Windows Forum Admin
    Staff Member Premium Supporter
    Jul 22, 2005
    8,492
    780
    Look to see if there is an updated driver from either Compaq's website or more likely the actual vendor that makes the soundcard.
  4. shax
    shax New Member
    Feb 10, 2007
    2
    0
    Help
    hiya i have ust upgraded to vista home premium. my self. but there is no sound on it. i had sound on my last version xp. but how can i get sound on ma pc again
Share This Page
Loading...
