Hello there,
I hope you can help?! Ever since I bought my P6320UK HP Pavilion Desktop i have been having intermittent issues playing sound. The audio stops and starts and is distorted. I have gone down every available avenue, been in touch with HP, PC World and had the computer away for repair but still to no success. the computer has 6GB ram and lots of memory so playing sound shouldn't be an issue. My speakers (both monitor and separate powered speakers/subwoofer) are all working correctly.
Initially I had to have the memory replaced on the computer but the memory seems to be working fine now, it's just the sound that causes issues. I have Realtek HD Audio on the computer (and there is also an option for realtek digital output but i disabled this as i don't use this). I have monitor speakers and my own speaker/subwoofer as well, which i set up as a multi-channel set up.
i think that it may be to do with Windows 7 set up- as i notice a few other people have posted comments on windows 7 forums that it seems to be a windows 7 problem. it's nothing to do with the software as i've tried a system reboot and it doesn't make any difference to the sound.
I hope you can help - it would be much appreciated because it is very frustrating!
Many thanks
Morven
Many thanks
Morven
