cybercore
Spider Player - The Ultimate Music Player
Spider Player supports nearly thirty audio formats including most popular ones. You can use it to play music from your audio collection, stream files from the Internet and listen to Internet radio.
Spider Player can rip CDs, convert any supported files to different formats and record Internet radio with no quality loss. All essential features, like ten-band graphic equalizer with various presets, local and global hotkeys support, playlist and favorites editors, are present too.
Screenshots
Download
Features:
Link Removed due to 404 Error
Discover thousands of radio stations around the globe with fast and easy search in Shoutcast and Icecast radio directories right within Spider Player.
Crossfading effects result in a smooth subtle transition between tracks.
Internal 32-bit sound processing adds extra clarity and fidelity to playback, even if your sound card is not capable of output in such resolution. Supports 5.1/7.1 Surround as well as classic stereo/mono audio files.
DSP effects manager allows to apply several high-quality 32-bit DSP effects simultaneously in any order. Winamp DSP plugins are supported too.
Spider Player has a unique favorites manager with support for custom categories and comments, so you can have your favorites organized the way you want.
Prefer keyboard control?
Assign local or global hotkeys of your choice to any program's action and have all of the tools and functions at your fingertips.
- 32-bit sound processing for crystal clear sound. Spider Player can process sound with double precision internally. So even if your sound card is not capable of output in such resolution, the sound quality is still improved. The difference is especially noticeable, if DSP effects (such as peaking equalizer) are enabled.
- Streaming audio support.
Stream files from the Internet or LAN and listen to Internet radio.
- Radio Directory. Discover thousands of radio stations around the globe with fast and easy search in Shoutcast and Icecast radio directories right within Spider Player.
- Custom Hotkeys. Assign up to four local or global hotkeys of your choice to any program's action and have all of the tools and functions at your fingertips. Multimedia keyboards are supported as well as regular ones.
- Multiformat Playback. Audio formats supported are: MP1, MP2, MP3, MP4, M4A, AAC, AAC+, AC3, MPC, MP+, MPP, Ogg Vorbis, FLAC, Ogg FLAC, TTA, APE, WavPack, Speex, WAV, CDDA, WMA, MID, RMI, KAR, S3M, XM, MOD, IT, MO3, MTM, UMX.
- Converter and CD Ripper. Any supported audio file (see the list of supported audio formats above) or Audio CD track can be easily encoded to MP3, WMA, OGG, FLAC or WavPack format. FREE version allows to encode only one track at a time, while PRO version can be used for batch encoding. With Spider Player PRO you can also use any command-line encoder with STDIN support. There is even a help on encoders' command line options and a preset manager.
- Support for custom MIDI soundfonts. Spider Player allows you to choose SF2 soundfont used for MIDI playback to vary how your MIDI files sound. It is also possible to convert MIDI files to MP3 and other formats using soundfonts that suit them best.
- DSP Effects Manager. DSP effects manager allows you to apply several high-quality 32-bit DSP effects simultaneously in any order. Winamp DSP plugins are supported too.
- Unified Tag editor. Edit ID3v1, ID3v2, Vorbis, FLAC tags and WMA metadata (support for additional tag types and file formats can be added via plugins).
- Portable version. You can place Spider Player on your USB flash drive, iPod, portable hard drive or a CD and use it on any computer, without the need of installation or administrator rights.
- Multichannel Audio support
- Crossfading support
- Full Unicode support
- Advanced Title Formatting support
- Multilingual interface
- Skin support - vary the player's look and feel by changing skins and their color tones
- CD-Text and FreeDB support
- Ten-band Equalizer with Preset Manager
- Icon Sets feature lets you have a separate icon for each audio file type
- Built-in Visualizations: customizable spectrum analyzer and oscilloscope
M3U, PLS and ASX playlists support
- Incremental Playlist Search
Screenshots
Download
Features:
