Standard VGA graphics adapter problem
Saw a lot of these threads..
Basically Win 7 doesn't detect my ATI graphics card when I go to device manager and instead uses 'standard VGA graphics adapter'.If I try to install ATI drivers through Catalyst Instal Manager, I dont even get an option to instal the actual driver like this
1
However, Everest does recognize my graphics card which is Radeon HD 4670 correctly
2
I did manage to "force" instal drivers by using 'have disk' method and navigating to the folder where ATI driver was downloaded, but I can't get CCC to work and I still get those 'jitters' while dragging windows around etc.
Thanks
Highwayman
maybe try cleaning out the drivers for the GPU and using the "Individual downloads" for the driver etc, and make sure you "run as admin" (right click on launch of the installers). According to the release notes on Catalyst 11.2 the 4670 is clearly listed as supported.
