Windows 7 Start menu search issue
corey2010
my search menu on the start page won't allow any keyboard commands i can't type anything into it how do i fix that?
How often does this happen? Is it a continual problem or sporadic?
Try restarting explorer.exe.
Ctrl-Shift-Esc to launch Task Manager
Go to Processes
Find explorer.exe
"End Process"
Go to File -> Run -> explorer
A quicker way may be to restart the computer.
If it is happening often, you need to find out what software is on your system that may be effecting the system.
Top Bottom
