Bad.hair.spray
Hi Folks,
I have an issue i need assistance with. I have a VGN-N130G. It came with XP (MCE). Installed W7 the other day.
It seems to have an issue at start up. It goes into the Windows start up screen and just gets stuck there. It did the same with XP and now its doing the same with the W7 too. I did a clean install. Once it gets stuck in the start up nothing can be done except holding down the power key and then re-starting. I m really at a loss as to how to go about fixing it as I thought a clean install would kinda do the trick..
Any assistance is much appreciated.
Thanks
Thanks
