Surface Pro Getting Started Guide: Setup Gestures and Accessories
If you just unboxed a Surface Pro and want a practical, step‑by‑step plan to get started — from setup and gestures to the Type Cover, Surface Pen, screenshots, and sensible troubleshooting — this guide walks you through everything a beginner needs to know to use a Surface Pro confidently and efficiently.
A person annotates a document on a tablet with a stylus, keyboard attached.Background​
The Surface Pro line is Microsoft’s flagship 2‑in‑1: a detachable keyboard plus kickstand, a touchscreen optimized for pen input, and a full Windows desktop OS in a tablet form factor. Over recent generations Microsoft has refined the hardware and software experience: higher refresh displays, improved inking, detachable Type Covers, and new ARM‑based SKUs that trade raw desktop‑class performance for much better battery life in real‑world usage. The platform’s core promise is flexibility — use it as a tablet for reading and inking, or attach the Type Cover and treat it like a compact laptop. That said, the hybrid design has tradeoffs: lap typing can feel awkward, accessories (keyboard and pen) are often sold separately, and some platform behaviors (power, compatibility, and battery claims) vary by model and firmware.
Overview: What you'll learn​
  • How to perform the initial setup quickly and securely
  • Essential touchscreen gestures and touchpad tips
  • Correctly attaching and using the Type Cover and keyboard shortcuts
  • Pairing and using the Surface Pen for handwriting and annotations
  • Where to find and use built‑in Microsoft apps for productivity
  • How to take screenshots and use the Snipping Tool on Surface devices
  • Customization, power and battery considerations, and troubleshooting common problems
Each section gives short, actionable steps and flags important caveats so you can avoid common beginner mistakes.
Initial setup: first 10 minutes​
  • Unbox, connect the charger, and press the Power button.
  • Follow the on‑screen setup: choose language, connect to Wi‑Fi, and sign in with a Microsoft account (or create one). Signing in with a Microsoft account unlocks OneDrive integration, Windows Hello, and app syncing.
  • Check which Surface Pro model you have (sticker on the box or Settings > System > About) before you install accessories or buy extras — accessory compatibility and bundled items vary by SKU and region.
Why check the model? Because newer Surface Pro models may ship with different ports, processors (Intel, AMD, or ARM), and accessories; that affects whether a given Type Cover matches and how certain features behave.
Quick security and convenience steps (do these now)​
  • Enable Windows Hello (face or fingerprint) in Settings > Accounts > Sign‑in options for fast, secure sign‑in.
  • Turn on BitLocker or File History / OneDrive backup for important files.
  • Run Windows Update before installing core apps — firmware and driver updates often arrive right after unboxing.
Touchscreen basics and gestures​
The touchscreen is your primary interface when the Type Cover is detached. Learning a few gestures makes navigation fast and natural.
  • Tap to select, double‑tap to open items.
  • Swipe left/right to move between apps or pages in some apps.
  • Pinch to zoom in or out on images, maps, and documents.
  • Tap and hold to open the context (right‑click) menu for items.
  • Use the edge swipes configured in Settings > Bluetooth & devices > Touch to bring up Task View or switch apps quickly. These settings let you map three‑ and four‑finger gestures on compatible touchpads too.
Tip: If the touch input feels too sensitive during typing, reduce touchpad sensitivity or temporarily attach the Type Cover to avoid accidental touches.
Using the Type Cover and keyboard​
The Type Cover turns the Surface Pro into a productive laptop replacement. It connects magnetically and doubles as a screen protector when folded.
  • Attach the Type Cover to the bottom edge: it snaps on magnetically.
  • Adjust the kickstand to a comfortable angle — small adjustments can improve typing posture.
  • Use these essential shortcuts:
  • Windows + I → Settings
  • Alt + Tab → Switch apps
  • Windows + D → Show desktop
  • Windows + E → File Explorer
  • Windows + L → Lock screen
  • Windows + number keys → Launch pinned taskbar apps (Windows + 1 opens the first pinned app).
The Type Cover’s function row and touchpad can vary by generation (backlighting, mechanical keys, haptic touchpad). If you plan heavy typing without a desk, test the feel in a store — lap typing remains a known ergonomic tradeoff for the detachable design.
Surface Pen: pairing and everyday use​
The Surface Pen is one of the platform’s standout features for note‑taking, annotations, and creative work.
How to pair:
  • Open Settings > Bluetooth & devices > Bluetooth.
  • Press and hold the top button (or pairing button) on the Pen until the light flashes.
  • Select the pen from Bluetooth device list and pair.
Once paired, tap text fields to begin handwriting in supported apps (OneNote, Microsoft Word with Ink Editor, etc.). The pen’s top/eraser button may be configurable for actions like launching OneNote or taking screenshots depending on model. fileciteturn0file12turn0file2
Practical Surface Pen uses:
  • Quick notes in OneNote — handwriting converts to typed text when you use Ink to Text.
  • Annotate web pages in Microsoft Edge and mark up PDF documents in Edge or Acrobat.
  • Sketching and pressure‑sensitive drawing in apps like Adobe Fresco or Clip Studio.
Pen care:
  • Keep replacement nibs on hand if you sketch a lot.
  • Check battery type (some Surface Pens use AAAA, others are rechargeable) and follow manufacturer guidance for charging or replacement.
Microsoft apps you should try now​
Surface Pro ships with or is optimized for several Microsoft apps that highlight pen and touch features:
  • OneNote — best for handwritten notes, searchable ink, and cross‑device syncing.
  • Microsoft Edge — supports inking and Web Capture for screenshotting and annotating pages.
  • Office apps (Word, Excel, PowerPoint) — full desktop apps with native pen support and ink features.
  • Snipping Tool — modern screenshot tool for quick captures and markup. fileciteturn0file12turn0file15
If you use a Surface for teaching, meetings, or creative work, install Microsoft Whiteboard and set up OneDrive folder backups so your work is automatically archived and available on other devices.
Taking screenshots on Surface Pro​
Surface devices support multiple screenshot methods; pick the one that fits your workflow.
  • Win + Shift + S → Snipping Tool overlay (Rectangular, Freeform, Window, Full screen). The image is copied to the clipboard and offers editing.
  • Windows + PrtScn → Saves a full‑screen PNG to Pictures\Screenshots.
  • Alt + PrtScn → Capture active window to clipboard; paste into Paint or other editor.
  • On Surface tablets without a PrtScn key: press the Power + Volume Up hardware buttons together; the screenshot is saved to Pictures\Screenshots. This is the same physical approach as snapping a phone screenshot. fileciteturn0file3turn0file16
  • Xbox Game Bar (Win + G) → Good when recording or capturing gameplay or app sessions.
Practical tip: Use Win + Shift + S for quick annotated captures. Open the preview to save, crop, and annotate before storing to OneDrive or local folders.
Customize settings for comfort and battery life​
Surface Pros run full Windows (Windows 10 or Windows 11 depending on model), so you have deep control over personalization and power.
  • Settings > Personalization → Change themes, lock screen, and colors.
  • Settings > System > Power & battery → Enable Battery saver and configure screen timeout.
  • Settings > System > Tablet (or Tablet mode) → Switch to touch‑friendly layouts when you use the device as a tablet.
For performance and battery optimization:
  • If you have an ARM‑based Surface Pro (some newer models), expect exceptional battery efficiency for light tasks, but verify app compatibility for resource‑heavy x86 apps.
  • Don’t assume lab battery claims map to your day‑to‑day usage — independent test results vary widely depending on workloads and firmware. Flag any manufacturer runtime numbers as directional, not absolute.
Troubleshooting common beginner problems​
  • Surface won’t boot or hangs during setup: force a restart (hold Power for ~10 seconds), then boot to UEFI or recovery (use Volume Up + Power on many models) to run diagnostics. If you need to reinstall Windows, use a USB recovery drive prepared via Microsoft’s Recovery tools.
  • Touch or pen not working: check Bluetooth pairing and battery, then update drivers in Settings > Windows Update > Optional updates. Install Surface firmware updates when offered. fileciteturn0file14turn0file1
  • Keyboard not responding: detach and reattach the Type Cover; ensure the kickstand and magnetic connector are clean. Try the virtual on‑screen keyboard (Win + Ctrl + O) as a temporary workaround.
  • App compatibility on ARM devices: if your Surface Pro is ARM‑based (Surface Pro 11 and later SKUs), some legacy x86 apps run in emulation and may be slower or incompatible. Check vendor support for ARM native builds for mission‑critical software. fileciteturn0file5turn0file6
Workflows and productivity tips​
  • Use Snap Layouts and virtual desktops to keep projects separated — drag windows into a Snap Layout or press Win + Z for layout choices. This makes multitasking on a smaller screen more manageable.
  • Map a three‑ or four‑finger touchpad gesture to media controls (Play/Pause) if you frequently listen to audio while working. This avoids reaching for on‑screen controls.
  • Set up OneDrive to sync Documents and Pictures automatically — it acts as an immediate backup and makes files available across devices. Confirm OneDrive’s folder backup is enabled rather than relying on legacy automatic screenshot uploads that Microsoft removed from earlier OneDrive behavior.
Accessories and buying considerations​
  • Type Cover and Surface Pen are often sold separately; budget for them when you purchase a Surface Pro.
  • Newer Surface Pro models may have removable SSDs and improved repairability compared to older generations — that’s useful if you plan long‑term upgrades.
  • Consider whether you’ll use the device on your lap frequently; the Surface Pro’s kickstand + keyboard is best at a desk. If lap comfort matters more than detachable flexibility, a clamshell laptop might be a better fit.
Facts to verify and where to be cautious​
  • Manufacturer runtime claims (e.g., “up to X hours”) are derived from controlled lab tests and often do not reflect mixed‑use scenarios; treat these numbers as estimates and check multiple reviews for real‑world figures.
  • Hardware‑specific behaviors (USB‑C quirks, charger compatibility, port bandwidth like USB 3.2 vs USB4/Thunderbolt) have been reported inconsistently across reviews; if a particular peripheral is essential, double‑check the specific SKU’s port standards. fileciteturn0file19turn0file6
  • App compatibility on ARM SKUs: while major apps now support ARM natively, niche or legacy tools might still rely on emulation and legacy drivers. Validate compatibility for critical applications before committing to an ARM Surface Pro. fileciteturn0file5turn0file6
Quick reference: essential shortcuts and gestures​
  • Power + Volume Up → Screenshot (Surface hardware combo).
  • Win + Shift + S → Snipping Tool overlay.
  • Windows + PrtScn → Save screenshot to Pictures\Screenshots.
  • Alt + Tab → Switch apps.
  • Windows + I → Open Settings.
Final verdict for beginners​
The Surface Pro is an excellent device for users who want the flexibility of a tablet with the full capabilities of Windows. For beginners the learning curve is small: perform the guided setup, pair the pen, attach the Type Cover when you need long typing sessions, and practice a handful of gestures and keyboard shortcuts. Be mindful that the detachable design trades some lap comfort and that accessory cost and app compatibility (on ARM models) are real considerations. When configured right — with OneNote for notes, Edge for inking and web capture, Snipping Tool for screenshots, and a Type Cover for productivity — the Surface Pro becomes a versatile, portable workhorse for both daily tasks and creative projects. fileciteturn0file12turn0file15
By following the steps above, you’ll move from unboxed to productive quickly, and avoid the most common pitfalls new Surface Pro users encounter. If you need concise checklists or step‑by‑step troubleshooting for a specific Surface Pro model, consult the device’s support pages and firmware notes — and always confirm battery and performance claims against current independent reviews before making purchase decisions. fileciteturn0file6turn0file5
Source: Windows Report How to Use Surface Pro: Easy Guide for Beginners
