Windows 10 Synaptics Clickpad two finger scroll not working
LWL
I have a Lenovo Yoga Pro. I just updated to Windows 10. I have changed the Synaptics setting to allow two finger scroll and it does not work. Any suggestions?
Windows Forum Admin
Microsoft MVP
does this help any?
alextop30
Honorable Member
I have the same laptop and had the same issue please go to Lenovo's website go to the specific computer support page download the windows 10 drivers. Next make sure you remove bother the synaptic software from control panel uninstall program, and remove the driver from device manager. Restart your computer. After that install the driver, restart your computer. Go to control panel and find the mouse options click on synaptic and see if it works.
Also make sure you go to the power settings and unchecked keyboard and mouse going to sleep because the hardware stops working after it comes back from sleep.
Sent from my VS986 using Tapatalk
