System ID 41 Kernel Power Errors
I've been to tons of other sites for my problem and I can't find a solution. The kernel Power errors happen when ever I play a rather large game, such as Left 4 Dead, Left 4 Dead 2, Dead Rising 2, Assassins Creed Series, and Battlefield Bad Company 2. I've tried unplugging all my external devices such as, my headset, It worked for about two weeks, but then the errors started happening again. I had this computer custom built for gaming, It's not even a third full, And I want this to stop. I've updated all my drivers, Uninstalled tons of my games, just to get one working. The errors don't occur immediately once I run the game. It takes about 20 minutes more or less to stop. The computer doesn't freeze, or give any warning that it's about to happen. Just swiftly shuts off. Could anyone help me? I gave up for a while and tried to restore my system to factory settings. I can't restore it to factory settings, because I don't know where the disc is, and when I try to reset it by a restore point, the restore points are only for this month.
Saltgrass
Could you give us your computer specs., including power supply.
Any chance it is getting hot? Do you hear anything different prior to the shutdowns?
Have you ever gotten a Blue Screen so you might have a dump file?
Try turning the sound off to test. Can you reduce the resolution in the game for testing?
Have you updated the games?
Anything in the Event Viewer that might show repeated warnings or errors?
Ehh... Could you specify how I can list the computer specs? I'm not that very good at the actual computer, Just using it. I doubt it is getting hot, because it isn't in a confined area, and it doesn't get very hot in here. The fan has lots of place to breathe. I've never gotten a blue screen. I've reduced all the graphics in all of the games down to the lowest, and it still happens. The games automatically update via steam. and yes there are warnings that seem to be to the errors: Log Name: SystemSource: Microsoft-Windows-Kernel-Tm
Date:          9/16/2011 4:58:42 PM
Event ID:      4
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      Owner-PC
Description:
The TransactionManager (TmId={57EC180D-DA78-11E0-9CBD-806E6F6E6963}, LogPath=\SystemRoot\System32\Config\TxR\{5dceba63-da6e-11e0-8a25-6c626d07e7ed}.TM) has failed to advance its log tail, due to the transaction (UOW={A1CEE1BD-E086-11E0-950A-6C626D07E7ED}, Description='') being unresolved for some time.  The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services.  Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Tm" Guid="{4CEC9C95-A65F-4591-B5C4-30100E51D870}" />
    <EventID>4</EventID>
    <Version>0</Version>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2011-09-16T21:58:42.389000000Z" />
    <EventRecordID>79897</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="48" />
    <Channel>System</Channel>
    <Computer>Owner-PC</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="TmIdentity">{57EC180D-DA78-11E0-9CBD-806E6F6E6963}</Data>
    <Data Name="TmLogFileNameLength">73</Data>
    <Data Name="TmLogFileName">\SystemRoot\System32\Config\TxR\{5dceba63-da6e-11e0-8a25-6c626d07e7ed}.TM</Data>
    <Data Name="TxUow">{A1CEE1BD-E086-11E0-950A-6C626D07E7ED}</Data>
    <Data Name="TxDescriptionLength">0</Data>
    <Data Name="TxDescription">
    </Data>
  </EventData>
</Event>
Log Name:      System
Date:          9/16/2011 12:24:38 PM
Event ID:      4
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      Owner-PC
Description:
The TransactionManager (TmId={57EC180D-DA78-11E0-9CBD-806E6F6E6963}, LogPath=\SystemRoot\System32\Config\TxR\{5dceba63-da6e-11e0-8a25-6c626d07e7ed}.TM) has failed to advance its log tail, due to the transaction (UOW={2CBFB2B0-DFF6-11E0-BDBD-6C626D07E7ED}, Description='') being unresolved for some time.  The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services.  Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2011-09-16T17:24:38.199800000Z" />
    <EventRecordID>79718</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="TxUow">{2CBFB2B0-DFF6-11E0-BDBD-6C626D07E7ED}</Data>
    </Data>
  </EventData>
</Event>
Log Name:      System
Date:          9/16/2011 11:20:49 AM
Event ID:      4
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      Owner-PC
Description:
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2011-09-16T16:20:49.941500000Z" />
    <EventRecordID>79586</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    </Data>
  </EventData>
</Event>
Log Name:      System
Date:          9/15/2011 12:26:11 PM
Event ID:      4
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      Owner-PC
Description:
The TransactionManager (TmId={57EC180D-DA78-11E0-9CBD-806E6F6E6963}, LogPath=\SystemRoot\System32\Config\TxR\{5dceba63-da6e-11e0-8a25-6c626d07e7ed}.TM) has failed to advance its log tail, due to the transaction (UOW={FD4ED095-DF3B-11E0-B71B-6C626D07E7ED}, Description='') being unresolved for some time.  The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services.  Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2011-09-15T17:26:11.047700000Z" />
    <EventRecordID>79155</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="68" />
  </System>
  <EventData>
    <Data Name="TxUow">{FD4ED095-DF3B-11E0-B71B-6C626D07E7ED}</Data>
    </Data>
  </EventData>
</Event>
Log Name:      System
Date:          9/14/2011 8:57:43 PM
Event ID:      4
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      Owner-PC
Description:
The TransactionManager (TmId={57ec180d-da78-11e0-9cbd-806e6f6e6963}, LogPath=\SystemRoot\System32\Config\TxR\{5dceba63-da6e-11e0-8a25-6c626d07e7ed}.TM) has failed to advance its log tail, due to the transaction (UOW={9e2f92c6-df20-11e0-a56c-6c626d07e7ed}, Description='') being unresolved for some time.  The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services.  Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Event Xml:
  <System>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2011-09-15T01:57:43.610600000Z" />
    <EventRecordID>78943</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="TxUow">{9E2F92C6-DF20-11E0-A56C-6C626D07E7ED}</Data>
    </Data>
  </EventData>
</Event>
And recently, I've been getting kernel power errors OUTSIDE of games. And last night, I had one, and when I tried to reboot the system, it Wouldn't boot. The fan ran for a few seconds and it shut off again. This morning I started it up and windows error recovery ran. It did a system restore And it didn't tell me the date it restored it to. Please tell me how I can give you the information to your first question.
How do I find out my computer specs?
Saltgrass
#7
I looked through the error messages and do not see anything that looks familiar. I also checked the GUID numbers in my registry and did not see those listed.
The errors mention a log in this folder. C:\Windows\System32\Config\TxR\
My folder is empty. Do you show anything in yours that might help us determine what might be involved in these errors?
#8
My folder is empty also.
#9
How do I upload it?
#10
Here's the system info text document.
Host Name: OWNER-PC
OS Name: Microsoft Windows 7 Home Premium
OS Version: 6.1.7600 N/A Build 7600
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Owner
Registered Organization:
Product ID: 00359-OEM-8703163-67115
Original Install Date: 8/16/2010, 12:13:15 PM
System Boot Time: 9/20/2011, 6:53:10 PM
System Manufacturer: MSI
System Model: MS-7309
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: AMD64 Family 16 Model 5 Stepping 3 AuthenticAMD ~783 Mhz
BIOS Version: American Megatrends Inc. V2.4, 3/10/2010
Windows Directory: C:\Windows
System Directory: C:\Windows\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-us;English (United States)
Input Locale: en-us;English (United States)
Time Zone: (UTC-06:00) Central Time (US & Canada)
Total Physical Memory: 3,071 MB
Available Physical Memory: 1,508 MB
Virtual Memory: Max Size: 6,141 MB
Virtual Memory: Available: 4,465 MB
Virtual Memory: In Use: 1,676 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\OWNER-PC
Hotfix(s): 149 Hotfix(s) Installed.
[01]: KB971033
[02]: KB2032276
[03]: KB2079403
[04]: KB2120976
[05]: KB2158563
[06]: KB2160329
[07]: KB2183461
[08]: KB2207566
[09]: KB2249857
[10]: KB2272691
[11]: KB2281679
[12]: KB2284742
[13]: KB2286198
[14]: KB2296011
[15]: KB2296199
[16]: KB2300535
[17]: KB2305420
[18]: KB2345886
[19]: KB2347290
[20]: KB2360131
[21]: KB2362765
[22]: KB2378111
[23]: KB2385678
[24]: KB2387149
[25]: KB2387530
[26]: KB2388210
[27]: KB2393802
[28]: KB2398632
[29]: KB2416400
[30]: KB2416471
[31]: KB2419640
[32]: KB2423089
[33]: KB2425227
[34]: KB2436673
[35]: KB2442962
[36]: KB2443685
[37]: KB2446709
[38]: KB2447568
[39]: KB2454826
[40]: KB2467023
[41]: KB2467659
[42]: KB2475792
[43]: KB2476490
[44]: KB2478661
[45]: KB2479628
[46]: KB2479943
[47]: KB2482017
[48]: KB2483614
[49]: KB2484033
[50]: KB2485376
[51]: KB2487426
[52]: KB2488113
[53]: KB2491683
[54]: KB2492386
[55]: KB2497640
[56]: KB2503658
[57]: KB2503665
[58]: KB2505438
[59]: KB2506014
[60]: KB2506212
[61]: KB2506223
[62]: KB2506928
[63]: KB2507618
[64]: KB2507938
[65]: KB2508272
[66]: KB2508429
[67]: KB2509553
[68]: KB2510531
[69]: KB2511250
[70]: KB2511455
[71]: KB2515325
[72]: KB2518867
[73]: KB2522422
[74]: KB2524375
[75]: KB2525694
[76]: KB2529073
[77]: KB2530548
[78]: KB2532531
[79]: KB2533552
[80]: KB2533623
[81]: KB2534366
[82]: KB2535512
[83]: KB2536275
[84]: KB2536276
[85]: KB2539634
[86]: KB2541014
[87]: KB2544521
[88]: KB2544893
[89]: KB2545698
[90]: KB2547666
[91]: KB2552343
[92]: KB2555917
[93]: KB2556532
[94]: KB2559049
[95]: KB2560656
[96]: KB2562937
[97]: KB2563227
[98]: KB2563894
[99]: KB2567680
[100]: KB2570791
[101]: KB2570947
[102]: KB2607712
[103]: KB2616676
[104]: KB958488
[105]: KB972270
[106]: KB974332
[107]: KB974431
[108]: KB974571
[109]: KB975467
[110]: KB975496
[111]: KB975560
[112]: KB976422
[113]: KB976662
[114]: KB976902
[115]: KB976972
[116]: KB977074
[117]: KB978542
[118]: KB978601
[119]: KB978637
[120]: KB978886
[121]: KB979099
[122]: KB979309
[123]: KB979482
[124]: KB979538
[125]: KB979687
[126]: KB979688
[127]: KB979916
[128]: KB980195
[129]: KB980218
[130]: KB980232
[131]: KB980408
[132]: KB980436
[133]: KB980846
[134]: KB981078
[135]: KB981332
[136]: KB981793
[137]: KB981852
[138]: KB981889
[139]: KB981957
[140]: KB982018
[141]: KB982110
[142]: KB982132
[143]: KB982214
[144]: KB982519
[145]: KB982632
[146]: KB982664
[147]: KB982665
[148]: KB982799
[149]: KB983590
Network Card(s): 2 NIC(s) Installed.
[01]: NVIDIA nForce Networking Controller
Connection Name: Local Area Connection
DHCP Enabled: Yes
DHCP Server: 192.168.1.1
IP address(es)
[01]: 192.168.1.102
[02]: fe80::6412:80a8:5ed9:96f7
[02]: Hamachi Network Interface
Connection Name: Hamachi
DHCP Enabled: Yes
DHCP Server: 5.0.0.1
IP address(es)
[01]: 5.41.160.143
[02]: fe80::8cdd:4d36:ca48:c92d
[03]: 2620:9b::529:a08f
And here's the dx diag.
System Information
Time of this report: 9/20/2011, 19:11:09
Machine name: OWNER-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.110622-1503)
Language: English (Regional Setting: English)
BIOS: Default System BIOS
Processor: AMD Athlon(tm) II X4 635 Processor (4 CPUs), ~2.9GHz
Memory: 3072MB RAM
Available OS Memory: 3072MB RAM
Page File: 1683MB used, 4457MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Previously: Crashed in system information (stage 4). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9800 GT
Manufacturer: NVIDIA
Chip type: GeForce 9800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0614&SUBSYS_18611462&REV_A2
Display Memory: 2287 MB
Dedicated Memory: 1007 MB
Shared Memory: 1279 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: 17f3
Monitor Id: EMA06EB
Native Mode: 1024 x 768(p) (84.997Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.6658 (English)
Driver Version: 8.17.12.6658
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 1/7/2011 22:27:00, 12859496 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4554-11CF-D06D-6D381CC2C535}
Vendor ID: 0x10DE
Device ID: 0x0614
SubSys ID: 0x18611462
Revision ID: 0x00A2
Driver Strong Name: oem5.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.6658:pci\ven_10de&dev_0614
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_14627309&REV_1002
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/13/2009 19:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x03F1
| Matching Device ID: usb\root_hub
| Service: usbhub
+-+ USB Input Device
| | Vendor/Product ID: 0x046D, 0xC03D
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
System Devices
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_03F3&SUBSYS_CB8410DE&REV_A1\3&267A616A&0&20
Driver: n/a
Name: PCI Express standard Root Port
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_73091462&REV_A2\3&267A616A&0&60
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F2&SUBSYS_73091462&REV_A3\3&267A616A&0&11
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_73091462&REV_A2\3&267A616A&0&58
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F1&SUBSYS_73091462&REV_A3\3&267A616A&0&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03E8&SUBSYS_73091462&REV_A2\3&267A616A&0&48
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_03F0&SUBSYS_10EC0888&REV_A2\3&267A616A&0&28
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_03E0&SUBSYS_CB8410DE&REV_A2\3&267A616A&0&08
Driver: n/a
Name: NVIDIA GeForce 9800 GT
Device ID: PCI\VEN_10DE&DEV_0614&SUBSYS_18611462&REV_A2\4&468E095&0&0048
Driver: n/a
Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_03EF&SUBSYS_73091462&REV_A2\3&267A616A&0&38
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_73091462&REV_A2\3&267A616A&0&41
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_03EC&SUBSYS_73091462&REV_A2\3&267A616A&0&30
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_73091462&REV_A2\3&267A616A&0&40
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_03EB&SUBSYS_73091462&REV_A2\3&267A616A&0&09
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03F5&SUBSYS_73091462&REV_A2\3&267A616A&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03EA&SUBSYS_73091462&REV_A1\3&267A616A&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
DirectShow Filters
Nero Digital:
Nero Digital Renderer,0x00100000,1,0,NeroDigital.dll,5.05.0009.0011
Nero Digital MP4 Muxer,0x00100000,1,1,NeroDigital.dll,5.05.0009.0011
Nero Digital AAC Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0009.0011
Subpic Encoder,0x00100000,1,3,NeroDigital.dll,5.05.0009.0011
Watermark,0x00200000,1,1,NeroDigital.dll,5.05.0009.0011
AMR Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0009.0011
Nero Digital AVC Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0009.0011
Media Type Adjustment,0x00200000,1,1,NeroDigital.dll,5.05.0009.0011
Nero Digital DMO Wrapper,0x00200000,1,1,NeroDigital.dll,5.05.0009.0011
Nero Digital SP/ASP Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0009.0011
VideoTee,0x00200000,1,2,NeroDigital.dll,5.05.0009.0011
PreviewRenderer,0x00400000,1,0,NeroDigital.dll,5.05.0009.0011
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,gzHF330.ddc,1.01.0000.0017
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16597
QuickTime Video Decoder Filter,0x00600800,1,1,mtw178.ddc,1.01.0000.0017
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
Nero Digital Audio Encoder 8,0x00200000,1,2,NeNDAud.ax,5.05.0009.0011
Nero Digital Muxer 8,0x00200000,2,1,NeNDMux.ax,5.05.0009.0011
Nero Digital File Writer 8,0x00200000,1,0,NeNDMux.ax,5.05.0009.0011
Nero Digital Null Renderer 8,0x00200000,1,0,NeNDMux.ax,5.05.0009.0011
Nero Digital Subpicture Enc 8,0x00200000,1,0,NeNDMux.ax,5.05.0009.0011
Nero Digital Video Enc 8,0x00200000,1,2,NeNDVid.ax,5.05.0009.0011
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,5.05.0009.0011
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,5.05.0009.0011
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,5.05.0009.0011
Nero Subpicture Decoder,0x00200000,1,1,NeSubpicture.ax,5.05.0009.0011
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,5.05.0009.0011
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,5.05.0009.0011
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,5.05.0009.0011
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
Nero Splitter,0x00600000,1,3,NeSplitter.ax,5.05.0009.0011
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16724
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
Nero Vobu Generator,0x00200000,1,0,NeroVobuGenerator.ax,5.05.0009.0011
Nero Audio Renderer,0x00200000,1,0,NeAudioRender.ax,5.05.0009.0011
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,5.05.0009.0011
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16724
DivX AAC Decoder,0x00800000,1,1,daac.ax,8.08.0000.41966
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16724
Nero Teletext Decoder,0x00200000,1,1,NeTeletext.ax,5.05.0009.0011
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,5.05.0009.0011
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Nero DVD Navigator,0x00600000,0,14,NeDVD.ax,5.05.0009.0011
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0007.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16724
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
Nero Resize,0x00400000,1,1,NeResize.ax,5.05.0009.0011
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16724
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0007.0001
Nero Colorspace Converter,0x00200000,1,1,NeColorspace.ax,5.05.0009.0011
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,5.05.0009.0011
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,5.05.0009.0011
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,5.05.0009.0011
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,5.05.0009.0011
Nero FLV Splitter,0x00600000,1,1,NeFLVSplitter.ax,5.05.0009.0011
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,5.05.0009.0011
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,5.05.0009.0011
Nero MP2 Audio Encoder,0x00200000,1,1,NeMP2AudioEnc.ax,5.05.0009.0011
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,5.05.0009.0011
Nero HD Audio Mixer,0x00200000,3,1,NeHDAudioMixer.ax,5.05.0009.0011
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,5.05.0009.0011
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,5.05.0009.0011
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
Nero Elementary Stream Parser,0x00200000,1,1,NeESParser.ax,5.05.0009.0011
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16724
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
DivX Demux Filter,0x00800002,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
Nero Audio Transcoder,0x00200000,1,1,NeTranscoder.ax,5.05.0009.0011
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,5.05.0009.0011
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,5.05.0009.0011
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
Nero TS Muxer,0x00200000,1,1,NeTSMuxer.ax,5.05.0009.0011
DivX Demux Filter (Unrestricted Edition),0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
Nero Framerate Converter,0x00200000,1,1,NeFramerate.ax,5.05.0009.0011
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,5.05.0009.0011
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
Nero Mpeg Video Encoder,0x00200000,1,1,NeMpegVideoEnc.ax,5.05.0009.0011
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
Bandisoft MPEG-1 Video Decoder,0xff800001,1,1,bdfilters.dll,1.00.0001.0003
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
Nero Video Decoder HD,0x00200000,1,2,NeVideoHD.ax,5.05.0009.0011
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,5.05.0009.0011
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,5.05.0009.0011
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,5.05.0009.0011
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,5.05.0009.0011
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,5.05.0009.0011
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16724
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
Nero VMR Modules Filter,0x00200000,1,0,NeroVMRModules.dll,5.05.0009.0011
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16724
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,5.05.0009.0011
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,5.05.0009.0011
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,5.05.0009.0011
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16724
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Bandisoft MPEG-1 Audio Decoder,0xff800001,1,1,bdfilters.dll,1.00.0001.0003
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,5.05.0009.0011
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,5.05.0009.0011
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,5.05.0009.0011
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,5.05.0009.0011
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,5.05.0009.0011
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 Codec (4 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7600.16385
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7600.16385
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7600.16385
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
Xfire Video Codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16724
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16724
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16724
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Rendering Devices:
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16648
Video Capture Sources:
ManyCam Video Source,0x00200000,0,2,VideoSrcktt.dll,2.06.0000.0030
Google Camera Adapter 0,0x00000000,0,0,,
Google Camera Adapter 1,0x00000000,0,0,,
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16724
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16724
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16724
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16724
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
Digital Audio (S/PDIF) (High De,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Hope that helps. :(
Saltgrass
#11
Well, I suppose I could ask a couple of questions:
What version of Nero are you running?
The dx section says there was a previous crash and a section would be skipped. Don't know what section 4 is, but you might rerun the utility as a x64 version and then add /dontskip option to see what happens.
Hit Winkey + r and type dxdiag /64bit and then if it still shows the previous crash comment, type dxdiag /64bit /dontskip
Your video card is DX 10 capable as far as I can tell. I do not know if having DX 11 installed is a problem, but maybe someone else will. I have to assume it just runs DX 10...
#12
I honestly don't know what nero is. I'm not very skilled with computer knowledge. I'm sorry for not being very helpful. I really want this to work. I can't play any games at all anymore. Not even terraria or minecraft. (simple games)
Saltgrass
#13
Nero is a DVD burning/authoring software. It shows on your system, and I was just wondering if you were using the latest version with all updates.
And some Nvidia cards seem to have an increased incident of problems. I do not remember for sure, but yours might be one. Maybe a web search for your card type might provide some information.
#14
I highly doubt it is my graphics card. I bought my graphics card after I bought my computer. My graphics card was about $150 or so. My computer ran fine for about a year, but now I can't play anything at all. This is what I bought the computer for.
