U
Unregistered
Guest
ok. So, ive been trying to fix the version of vista i have on my computer for quiet some time now and theres only 1 thing left i could do to fix it, since none of the safemodes work and a recovery disk wont help anything, and that is to do a system restore or put in the install disk and just try to install and upgrade so it will replace all drivers. im likin the system restore idea best, but im not sure how, or if you can do that from a recovery disk or vista install disk. and uhh.. same with the upgrade option, you think it would let me do something like that to an already installed version?
