Hi KSnKing and Welcome to the Forum.
STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA
Usual causes: Defective hardware (particularly memory - but not just RAM), Faulty system service, Antivirus, Device driver, NTFS corruption, BIOS
Your latest dump file lists
win32k.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority:
Please see these threads:
Outdated Drivers. Update:
LHidFilt.Sys Fri Feb 29 10:08:27 2008
lltdio.sys Tue Jul 14 01:08:50 2009
LMouFilt.Sys Fri Feb 29 10:08:31 2008
Rt64win7.sys Thu Aug 20 17:05:06 2009
RTKVHD64.sys Fri Dec 26 09:24:56 2008
skfiltv.sys Thu Aug 14 07:48:33 2008 Probably Pilote USB audio (WDM); Creative wireless headset; Hs-1200 Digital Wireless Headset
Creative.
Bugcheck Analysis:
Loading Dump File [D:\ DOWNLOADS\ DUMPS\New folder\052010-22448-01.dmp]
Symbol search path is: SRV*C:\WinSym*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`02e57000 PsLoadedModuleList = 0xfffff800`03094e50
Debug session time: Thu May 20 06:51:58.729 2010 (UTC + 1:00)
System Uptime: 0 days 1:51:14.900
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 50, {fffff900c31b0320, 0, fffff9600028c69d, 0}
Probably caused by : win32k.sys ( win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+2d )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff900c31b0320, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff9600028c69d, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030ff0e0
fffff900c31b0320
FAULTING_IP:
fffff960`0028c69d 488b4f20 mov rcx,qword ptr [rdi+20h]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x50
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff88007b5b920 -- (.trap 0xfffff88007b5b920)
rax=0000000000000011 rbx=0000000000000000 rcx=fffff900c3dc8c60
rdx=000000000a121801 rsi=0000000000000000 rdi=0000000000000000
rip=fffff9600028c69d rsp=fffff88007b5bab0 rbp=0000000000000001
r8=0000000000000000 r9=0000000000000410 r10=fffff80002e57000
r11=0000000000000022 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+0x2d:
fffff960`0028c69d 488b4f20 mov rcx,qword ptr [rdi+20h] ds:8c60:00000000`00000020=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002f47e54 to fffff80002ec7600
STACK_TEXT:
fffff880`07b5b7b8 fffff800`02f47e54 : 00000000`00000050 fffff900`c31b0320 00000000`00000000 fffff880`07b5b920 : nt!KeBugCheckEx
fffff880`07b5b7c0 fffff800`02ec56ee : 00000000`00000000 fffff900`c3dc8c60 fffffa80`35616c00 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x42877
fffff880`07b5b920 fffff960`0028c69d : 00000000`00000000 00000000`0a121801 00000000`0a121801 00000000`00000001 : nt!KiPageFault+0x16e
fffff880`07b5bab0 fffff960`0028bbae : fffff900`c3dc8c60 00000000`00000000 00001801`624d4653 00000000`0000001d : win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+0x2d
fffff880`07b5bae0 fffff960`0028cab3 : 00000000`00000000 00000000`0a121801 fffff900`c3dc8c60 00000000`0210047c : win32k!SFMLOGICALSURFACE::DeInitialize+0x4e
fffff880`07b5bb20 fffff960`001e95ff : 00000000`00000000 fffff900`c00bf010 fffff900`c3dc8c60 00000000`00000020 : win32k!bhLSurfDestroyLogicalSurfaceObject+0x4b
fffff880`07b5bb60 fffff960`0020a908 : 00000000`00000001 00000000`00000001 fffff880`07b5bca0 00000000`00000000 : win32k!GreSfmCloseCompositorRef+0x10f
fffff880`07b5bba0 fffff800`02ec6853 : fffffa80`06ef5b60 fffff880`07b5bca0 00000000`000000bc fffffa80`06eed550 : win32k!NtGdiHLSurfSetInformation+0x1a8
fffff880`07b5bc20 000007fe`fef34efa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`037df678 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fef34efa
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+2d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc5e0
FAILURE_BUCKET_ID: X64_0x50_win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+2d
Drivers:
fffff880`10b63000 fffff880`10ba1000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00f08000 fffff880`00f5f000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`06aed000 fffff880`06b05000 adfs adfs.SYS Thu Jun 26 21:52:37 2008 (48640195)
fffff880`02d31000 fffff880`02dbb000 afd afd.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`10ba1000 fffff880`10bb7000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00ff3000 fffff880`00ffe000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`073a4000 fffff880`073af000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e1a000 fffff880`00e23000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff960`00810000 fffff960`00871000 ATMFD ATMFD.DLL Thu Jul 30 06:07:22 2009 (4A712A8A)
fffff880`040c7000 fffff880`0410e000 avgldx64 avgldx64.sys Thu Feb 11 03:52:31 2010 (4B737EFF)
fffff880`02ce1000 fffff880`02ce8080 avgmfx64 avgmfx64.sys Wed Feb 17 22:40:14 2010 (4B7C704E)
fffff880`019af000 fffff880`01a00000 avgtdia avgtdia.sys Tue Apr 13 22:12:20 2010 (4BC4DE34)
fffff880`01903000 fffff880`0190a000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`01800000 fffff880`01811000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`061c4000 fffff880`061e2000 bowser bowser.sys Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff960`007d0000 fffff960`007f7000 cdd cdd.dll Tue Jul 14 02:25:40 2009 (4A5BDE94)
fffff880`041cf000 fffff880`041ec000 cdfs cdfs.sys Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`018d0000 fffff880`018fa000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`0186a000 fffff880`0189a000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d24000 fffff880`00d82000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`010d4000 fffff880`01147000 cng cng.sys Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`043eb000 fffff880`043fb000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`041ec000 fffff880`041fa000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`02cc3000 fffff880`02ce1000 dfsc dfsc.sys Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`02cb4000 fffff880`02cc3000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01854000 fffff880`0186a000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05c00000 fffff880`05c22000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05c34000 fffff880`05c3d000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0189a000 fffff880`018a6000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`018a6000 fffff880`018b9000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05c28000 fffff880`05c34000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04200000 fffff880`042f4000 dxgkrnl dxgkrnl.sys Fri Oct 02 02:00:14 2009 (4AC5509E)
fffff880`042f4000 fffff880`0433a000 dxgmms1 dxgmms1.sys Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`01062000 fffff880`01076000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01016000 fffff880`01062000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`013e3000 fffff880`013ed000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0181a000 fffff880`01854000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`043de000 fffff880`043eb000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`02e0e000 fffff800`02e57000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`043ae000 fffff880`043d2000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`0610b000 fffff880`06124000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`06124000 fffff880`0612c080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`060fd000 fffff880`0610b000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`06000000 fffff880`060c8000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`014ef000 fffff880`014f8000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`04134000 fffff880`0414a000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`10be7000 fffff880`10bf6000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06189000 fffff880`06197000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00ba5000 fffff800`00baf000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`04000000 fffff880`04043000 ks ks.sys Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`013b8000 fffff880`013d2000 ksecdd ksecdd.sys Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000 ksecpkg ksecpkg.sys Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`05c22000 fffff880`05c27200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`06155000 fffff880`06168000 LHidFilt LHidFilt.Sys Fri Feb 29 10:08:27 2008 (47C7D99B)
fffff880`06197000 fffff880`061ac000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06175000 fffff880`06189000 LMouFilt LMouFilt.Sys Fri Feb 29 10:08:31 2008 (47C7D99F)
fffff880`011cd000 fffff880`011f0000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00ccc000 fffff880`00d10000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`018b9000 fffff880`018c7000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`0fe00000 fffff880`0fe0f000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06168000 fffff880`06175000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`061e2000 fffff880`061fa000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`06a4f000 fffff880`06a7c000 mrxsmb mrxsmb.sys Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`06a7c000 fffff880`06aca000 mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`06aca000 fffff880`06aed000 mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`01968000 fffff880`01973000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f68000 fffff880`00f72000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01076000 fffff880`010d4000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`02ca9000 fffff880`02cb4000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`014dd000 fffff880`014ef000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014fe000 fffff880`015f0000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`10bdb000 fffff880`10be7000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0414a000 fffff880`04179000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`040af000 fffff880`040c4000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02dea000 fffff880`02df9000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02cec000 fffff880`02d31000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01973000 fffff880`01984000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02c9d000 fffff880`02ca9000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e57000 fffff800`03433000 nt ntkrnlmp.exe Sat Feb 27 07:55:23 2010 (4B88CFEB)
fffff880`01215000 fffff880`013b8000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`018fa000 fffff880`01903000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`10b22000 fffff880`10b23180 nvBridge nvBridge.kmd Sat Nov 21 03:09:47 2009 (4B0759FB)
fffff880`0fe14000 fffff880`10b21a00 nvlddmkm nvlddmkm.sys Sat Nov 21 03:40:46 2009 (4B07613E)
fffff880`02dc4000 fffff880`02dea000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fb2000 fffff880`00fc7000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f72000 fffff880`00fa5000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fdc000 fffff880`00fe3000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fe3000 fffff880`00ff3000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013d2000 fffff880`013e3000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06b05000 fffff880`06bab000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05dc0000 fffff880`05dfd000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d10000 fffff880`00d24000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`10bb7000 fffff880`10bdb000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04179000 fffff880`04194000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04194000 fffff880`041b5000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`041b5000 fffff880`041cf000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02c4c000 fffff880`02c9d000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`0194d000 fffff880`01956000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01956000 fffff880`0195f000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0195f000 fffff880`01968000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01193000 fffff880`011cd000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`061ac000 fffff880`061c4000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`10b24000 fffff880`10b63000 Rt64win7 Rt64win7.sys Thu Aug 20 17:05:06 2009 (4A8D7432)
fffff880`05c3d000 fffff880`05dbfe00 RTKVHD64 RTKVHD64.sys Fri Dec 26 09:24:56 2008 (4954A2E8)
fffff880`06bab000 fffff880`06bb6000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`043d2000 fffff880`043de000 serenum serenum.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000 serial serial.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`06148000 fffff880`06155000 skfiltv skfiltv.sys Thu Aug 14 07:48:33 2008 (48A3D541)
fffff880`014d5000 fffff880`014dd000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0729b000 fffff880`07333000 srv srv.sys Tue Dec 08 08:32:55 2009 (4B1E0F37)
fffff880`07232000 fffff880`0729b000 srv2 srv2.sys Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`06bb6000 fffff880`06be3000 srvnet srvnet.sys Tue Dec 08 08:32:26 2009 (4B1E0F1A)
fffff880`043fb000 fffff880`043fc480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000 tcpip tcpip.sys Tue Jul 14 00:25:34 2009 (4A5BC26E)
fffff880`06be3000 fffff880`06bf5000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`019a2000 fffff880`019af000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01984000 fffff880`019a2000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02c38000 fffff880`02c4c000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00500000 fffff960`0050a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`0410e000 fffff880`04134000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`04043000 fffff880`04055000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`0612d000 fffff880`06147c00 usbaudio usbaudio.sys Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`060de000 fffff880`060fb000 usbccgp usbccgp.sys Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`060fb000 fffff880`060fcf00 USBD USBD.SYS Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`0439d000 fffff880`043ae000 usbehci usbehci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04055000 fffff880`040af000 usbhub usbhub.sys Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`04347000 fffff880`0439d000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`0433a000 fffff880`04347000 usbuhci usbuhci.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00fa5000 fffff880`00fb2000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0190a000 fffff880`01918000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01918000 fffff880`0193d000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fc7000 fffff880`00fdc000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d82000 fffff880`00dde000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01147000 fffff880`01193000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`02c1d000 fffff880`02c38000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`0193d000 fffff880`0194d000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e55000 fffff880`00ef9000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ef9000 fffff880`00f08000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02dbb000 fffff880`02dc4000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`0031f000 win32k win32k.sys Tue Jul 14 00:40:16 2009 (4A5BC5E0)
fffff880`00f5f000 fffff880`00f68000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00dde000 fffff880`00dff000 WudfPf WudfPf.sys Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`07333000 fffff880`073a4000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`0189a000 fffff880`018a8000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`018a8000 fffff880`018b4000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`018b4000 fffff880`018bd000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`018bd000 fffff880`018d0000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
If after updating the listed drivers blue screens continue:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct
Link Removed for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download
Link Removed due to 404 Error as AVG's replacement. Re-boot to Safe Mode. In Safe Mode run the
AVG Removal tools. Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled!
Run Memtest86+ overnight, after your computer has been off for about an hour or two so it has a cold start. Let it run for
at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test.
Note!! Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Test RAM sticks individually. When you find a good one then test it in all slots. Post back with the results.
If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
