Original release date: June 18, 2013 | Last revised: June 19, 2013
[h=3]Systems Affected[/h] Any system using Oracle Java including
[h=3]Overview[/h] Oracle released the June 2013 Critical Patch Update for Oracle Java SE. This patch contains 40 new security fixes across Java SE products and a fix to the Javadoc Tool. API documentation in HTML format generated by the Javadoc tool that contains a right frame may be vulnerable to frame injection when hosted on a web server.
[h=3]Description[/h] Oracle's June Critical Patch Update includes a fix to the Javadoc Tool. API documentation in HTML format generated by the Javadoc tool that contains a right frame may be vulnerable to frame injection when hosted on a web server. Additional information can be found in CERT Vulnerablity Report VU#225657. It is recommened that sites hosting such pages should re-generate the API documentation using the latest Javadoc tool and replace the current pages with the re-generated Javadoc output. In cases where regenerating API documentation is not feasible, a Java API Documentation Updater Tool that updates API documentation "in place" is available Oracle's Java SE Downloads page.
[h=3]Impact[/h] An attacker can cause one of the frames within a Javadoc-generated web page to be replaced with a malicious page. This vulnerability could be used for phishing or social engineering, or it could be used for browser exploitation if combined with another browser-related vulnerability.
[h=3]Solution[/h] Apply Updates
Oracle has released the June 2013 Java Critical Patch Update to address this vulnerability. Oracle Java Development Toolkit (JDK) and Javadoc users are advised to apply the June 2013 Java Critical Patch Update and regenerate and republish affected Javadoc HTML pages.
Fix-in-Place Tool
Oracle has released a fix-in-place tool named Java API Documentation Updater Tool. This fix-in-place tool can process directories or folders to search for HTML files to be remediated without having to regenerate existing Javadocs. When presented directories/folders and their sub-directories or sub-folders, the Java API Documentation Updater Tool will search for files with the following names:
[h=3]References[/h]
This product is provided subject to this Notification and this Privacy & Use policy.
Syndicated from the United States Security Readiness Team (US-CERT). More...
- JDK and JRE 7 Update 21 and earlier
- JDK and JRE 6 Update 45 and earlier
- JDK and JRE 5.0 Update 45 and earlier
- JavaFX 2.2.21 and earlier
Fix-in-Place Tool
- index.htm
- index.html
- toc.htm
- toc.html
[h=3]References[/h]
- Oracle Java SE Critical Patch Update Announcement - June 2013
- Vulnerability Note VU#225657
- Oracle Java SE Critical Patch Update Advisory - June 2013
- CVE-2013-1571
- Javadoc Tool
- Initial Release
