Taskbar issue
Discussion in 'Windows 7 Help and Support' started by Wout000, May 25, 2009.
  1. Radenight
    Radenight New Member
    Nov 16, 2008
    4,525
    108
    Have you taken a look at the link I posted? Did it help at all? ;)
  2. Wout000
    Wout000 New Member
    May 25, 2009
    26
    0
    IE was just the program i tried to pin to the taskbar.
    tried pinning shortcut from desktop... doesn't work.
    I now have 2 pinned programs, which are 'libraries' and 'WMP' I didn't accidentally delete those.... deleted IE from the taskbar...never got it back (or any other program for that matter ;(
  3. reghakr
    reghakr Excellent Member
    Jan 26, 2009
    14,220
    180
    Sorry, misinterpreted that.
  4. loathe
    loathe New Member
    Jan 16, 2009
    1,718
    66
    If you are in the position to format and reinstall, I'd try that.:confused:
  5. Radenight
    Nov 16, 2008
    4,525
    108
    Agreed, I was going to suggest that but from what he said it didn't sound like that was an option.. ;) I really don't think this is a bug, a glitch maybe, but not a bug..
  6. Wout000
    Wout000 New Member
    May 25, 2009
    26
    0
    Radenight, your previous post (with the link) got me thinking.... I did remove the arrow from the shortcuts...
    So i followed the instructions...didn't work, i thought... let's try it manually and bingo presto, 30 minutes of fiddleing later and about a dozen reboots it works !!!
    thanks for all the help, time and advice everyone gave me .... thank you all !
  7. Radenight
    Nov 16, 2008
    4,525
    108
    Sweet! I'm glad you finally got it.. :) And without having to resort to a reinstall.. ;)
  8. Wout000
    Wout000 New Member
    May 25, 2009
    26
    0
    This does raise an entire new support topic though...
    using .reg files in Windows 7 doesn't work.... at all !
  9. reghakr
    Jan 26, 2009
    14,220
    180
    Radenight,
    NICE call!!!
    Wout000,
    I found the answer why reg files are not working correctly in Windows 7.
    You need to save the file in Notepad, and choose ANSI as the format.
    Works consistently for me.
  10. Wout000
    Wout000 New Member
    May 25, 2009
    26
    0
    excellent, works like a charm
    thanks all !
  11. Radenight
    Nov 16, 2008
    4,525
    108
    Same to you my friend.. ;) I'd say we covered all angles of this problem very well.. At least if someone else runs into the same problem, they should be able to get it solved with all the suggestions in this thread alone! :)
    EXCELLENT JOB to everyone who was involved with this thread! :)
  12. stueycaster
    stueycaster Millennium Celebration Award Winner
    Feb 5, 2009
    1,534
    58
    Thanks to this thread I found out that I could remove the arrows from my desktop icons without using a Tweak?i program. I never did like the looks of them little boogers. I thought I'd have to wait til PowerToys for Windows 7 came out.
Share This Page
Loading...
