taskbarr, need help
Discussion in 'Windows 7 Help and Support' started by SJD, Jul 10, 2010.
  1. SJD
    SJD New Member
    Jul 10, 2010
    2
    0
    hello,
    well i was uninstalling ebay off my computer and after i did. my taskbar display changed..
    i use windows 7 64 bit and my dispay used to be when i hovered over the icon, different windows there side by side and when i hovered over that it let me veiw the window without clicking on it.
    aero peek if im right?
    well now it wont let me do that and the task bar has gone back to where it stacks them upp and i have to click on them and its really annoying.
    i look in settings and it doesnt give me any idea..
    is there a way i can get it back?
  2. CommonTater
    CommonTater New Member
    Jul 21, 2010
    868
    36
    Right click the taskbar... select properties. Have a look through the tabs there.
    If AeroPeek is unchecked... check it.
Share This Page
Loading...
