The Default gateway is not available, all researched solutions NOT working.
Discussion in 'Windows 7 Networking' started by abd121699, May 28, 2013.
  1. abd121699
    abd121699 New Member
    May 28, 2013
    12
    0
    Hello, I have what the seems to be some what common The default gateway is not available problem, where my internet goes off at random times ( when internet is stressed it seems) and to fix it you need to run troubleshooter.
    IPS: Comact
    Modem : Arris TM822
    Router : Netgear WPS WNR2000v3
    fMtagF1.
    http://i.imgur.com/fMtagF1.png
    etD4qLN.
    http://i.imgur.com/etD4qLN.png
    Any help will be appreciated.
  2. patcooke
    patcooke Microsoft MVP
    Staff Member Premium Supporter Microsoft MVP
    May 16, 2010
    5,502
    275
    Your ipconfig looks fine. Check to see if there any updates available for your network card. Also, have you got a firewall installed? If so you may find it is causing the problem. Try running with it disabled for a while and see if things improve.
  3. abd121699
    May 28, 2013
    12
    0
    Hello, sorry for the late response. I don't have any firewalls and I updated my network card. I'll see if anything improves.
Share This Page
Loading...
