This might help some folks out
dooglo
A friend recently purchased W7 Upgrade and had issues with installation. He did some web hunting and found this Link Removed due to 404 Error, It helped him out tremendously. I hope someone else here can verify, for I've only seen his W7 working, I was not there during his delema, he just told me about it.
D.
busydog
D.
Works like a champ!
dooglo
Glad to hear it. I was looking for fixes for my friend at the same time he was and he called me just as he finished when I found it. So, folks, there are fixes out there for most things, just be patient, and case sensitive with your searches and you'll find it.
D.
Super Sarge
Number 3 works as this was the same trick used to do a clean install of a Vista Upgrade known as double install
