knevyn
I have a win 7 pro laptop that has some applets too small to read.
Most apps including desktop are fine. However if you right click on the task bar and choose properties. The applet appears with very small font.
I've tried uping the message box text with no improvement.
If you're facing issues with some applets or text appearing too small on your Windows 7 Pro laptop, there are a few settings you can adjust to improve readability. Here are some steps you can take to address the small font size in applets like the Taskbar Properties window: 1. Adjust Display Settings: - Right-click on the desktop and select "Screen Resolution" or go to Control Panel > Appearance and Personalization > Display. - Check the resolution settings on your display. A higher screen resolution can often make text and icons appear smaller. Try lowering the resolution to see if it helps with text size. 2. Change Text Size: - Go to Control Panel > Appearance and Personalization > Display. - Click on "Set custom text size...
If you're facing issues with some applets or text appearing too small on your Windows 7 Pro laptop, there are a few settings you can adjust to improve readability. Here are some steps you can take to address the small font size in applets like the Taskbar Properties window: 1. Adjust Display Settings: - Right-click on the desktop and select "Screen Resolution" or go to Control Panel > Appearance and Personalization > Display. - Check the resolution settings on your display. A higher screen resolution can often make text and icons appear smaller. Try lowering the resolution to see if it helps with text size. 2. Change Text Size: - Go to Control Panel > Appearance and Personalization > Display. - Click on "Set custom text size (DPI)" on the left panel. - Adjust the text size using the slider to make text on your screen larger. 3. Change Window Colors and Metrics: - Right-click on the desktop and choose "Personalize." - Click on "Window Color" at the bottom of the window. - Click on "Advanced appearance settings...". - In the "Item" dropdown menu, select the element you want to change (e.g., Menu, Message Box, etc.). - Adjust the size and font to make it more readable. 4. Adjust Theme Settings: - Right-click on the desktop and choose "Personalize." - Select a different theme that may have larger fonts and elements by clicking on "Window Color" or "Theme Settings." 5. Update Drivers: - Ensure your graphics driver is up to date. Sometimes outdated drivers can cause display issues. 6. Accessibility Options: - Explore Windows accessibility options that can assist users with vision impairments. You can adjust settings such as magnifier, high contrast, and more in the Control Panel. After making these adjustments, restart your computer for the changes to take effect. Hopefully, one of these solutions will help improve the readability of applets and small text on your Windows 7 Pro laptop.
