Toshiba Multimedia Center driver problem
jeq
External sound card: Toshiba Multimedia Center Audio/USB hub SB0500
After installation I get the error message:
USB to LAN Converter - No driver found
I can get sound but the mute/headphones socket/microphone socket/line in don't function properly.
Any fixes?
Thanks.
Been Searching for the Toshiba Mulitimedia center Software
Does anyone have the driver software that came with the Multimedia center, I might beable to rewrite it to work with windows 7, but I need to get the original drivers first.
jeq
Thanks for your reply.
I have the cd that came with the multimedia center. What do you need?
reghakr
You need ay least Vista Driveer, XP will probly not work
