Trouble with desk...
aLf
Last few days (weeks) I am having trouble with my PC
MBD: Asus M4A77T
CPU: DualCore AMD Athlon II X2 255, 3100 MHz (15.5 x 200)
GPU: ATI Radeon HD 5670 (Redwood)
HDD: WDC WD5000AADS-67S9B1 ATA Device
PSU: Blueberry PSB500
OS: Win 7 x64 SP1
Here are dump files from last few days.
View attachment Minidump.zip
Thank you!!!
Elmer
Hi aLf and Welcome to The Forum.
STOP 0x00000024: NTFS_FILE_SYSTEM
Usual causes:
Disk corruption, insufficient physical memory, Device driver, Indexing, Resident antivirus, backup, defrag programs, Disk/Drive failing/failure.
Your latest dump file Ntfs.sys lists as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes often indicate hardware issues.
As a Priority:
Avira is known to be a cause of BSOD's on some Windows 7 systems and was specifically mentioned in one of your dump files.
Uninstall Avira and download BSOD friendly Microsoft Security Essentials as its replacement. Make sure Windows firewall is enabled!
ASACPI.sys Mon Mar 28 03:30:36 2005 This driver is notorious for causing BSOD's. You have two options:
  • You can disable the ATK0110 ACPI Utility in the DeviceManager (under System Devices) with no apparent issues. OR (and if disabling does cause issues)
  • There is an update here: Asus ATK0110 driver. Look under the sub-heading: Utilities. Approx. 12th one down.
Driver Install - Manual method
  1. Download the driver and extract it to a folder.
  2. Open the Device Manager.
  3. Right click the device you wish to change the drivers for. You can select Properties > Driver > Driver Details to check you have the right device. In this case System Devices >> ATK0110 ACPI Utility
  4. Choose Update Driver Software.
  5. Select Browse My Computer For Driver Software.
  6. Select Let me pick from a list of device drivers on my computer.
  7. Select Have disk...
  8. Select Browse..
  9. Navigate to the extracted folder and double click on the .inf file
  10. Hit OK, then Next and the driver(s) will then begin to install.
  11. After it has installed, GoTo C:\Windows\System32\Drivers. Locate the Asacpi.sys driver, right click it and check the dates under its properties. You're looking for a date of 2009 or 2010 (ignore todays date). Occasionally it can be a bit stubborn to change.
Outdated Drivers. Update:
Rt64win7.sys Thu Feb 26 09:04:13 2009 Realtek PCIe GBE Family Controller v7.046
Bugcheck Analysis:
BugCheck 24, {1904fb, fffff88005e585c8, fffff88005e57e20, fffff80003048a90}
Probably caused by : Ntfs.sys ( Ntfs!NtfsCommonCleanup+1f68 )
Followup: MachineOwner
1: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88005e585c8
Arg3: fffff88005e57e20
Arg4: fffff80003048a90
Debugging Details:
EXCEPTION_RECORD:  fffff88005e585c8 -- (.exr 0xfffff88005e585c8)
ExceptionAddress: fffff80003048a90 (nt!FsRtlPrivateFastUnlockAll+0x0000000000000014)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff88005e57e20 -- (.cxr 0xfffff88005e57e20)
rax=fffffa80059f2920 rbx=fffff8a001f65010 rcx=ff00000000000000
rdx=fffffa80057a3a20 rsi=fffff8a001f65140 rdi=fffff88005e4a004
rip=fffff80003048a90 rsp=fffff88005e58800 rbp=fffff88005e4a500
 r8=fffffa80059f2920  r9=0000000000000000 r10=0000000000000000
r11=fffff88005e4a2b0 r12=fffffa80057a3a20 r13=0000000000000000
r14=fffff8a001f653a8 r15=fffff8a002016760
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
nt!FsRtlPrivateFastUnlockAll+0x14:
fffff800`03048a90 488b4118        mov     rax,qword ptr [rcx+18h] ds:002b:ff000000`00000018=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032b60e8
 ffffffffffffffff
FOLLOWUP_IP:
fffff880`012bb94a e942e9ffff      jmp     Ntfs!NtfsCommonCleanup+0x8b1 (fffff880`012ba291)
FAULTING_IP:
nt!FsRtlPrivateFastUnlockAll+14
BUGCHECK_STR:  0x24
LAST_CONTROL_TRANSFER:  from fffff80003048a6e to fffff80003048a90
STACK_TEXT:
fffff880`05e58800 fffff800`03048a6e : fffff880`05e4a2b0 fffff880`012298bb fffff8a0`02016760 00000000`00000000 : nt!FsRtlPrivateFastUnlockAll+0x14
fffff880`05e588e0 fffff880`012bb94a : fffff8a0`01f65010 fffff880`05e4a500 fffff8a0`01f65140 fffff880`05e4a004 : nt!FsRtlFastUnlockAll+0x16
fffff880`05e58920 fffff880`01229cc9 : fffffa80`049af010 fffffa80`05a29010 fffff880`05e4a210 fffffa80`05a29660 : Ntfs!NtfsCommonCleanup+0x1f68
fffff880`05e58d30 fffff800`0307d157 : fffff880`05e4a210 00000000`00000000 00000000`00000000 00000000`00000000 : Ntfs!NtfsCommonCleanupCallout+0x19
fffff880`05e58d60 fffff800`0307d111 : 00000000`00000000 00000000`00000000 fffff880`05e59000 fffff800`03092242 : nt!KxSwitchKernelStackCallout+0x27
fffff880`05e4a0e0 fffff800`03092242 : fffff8a0`00010570 00000000`00000002 fffffa80`05a29661 fffff800`03072f93 : nt!KiSwitchKernelStackContinue
fffff880`05e4a100 fffff880`01229d42 : fffff880`01229cb0 00000000`00000000 fffff880`05e4a500 00000000`00000000 : nt!KeExpandKernelStackAndCalloutEx+0x2a2
fffff880`05e4a1e0 fffff880`012c8a04 : fffff880`05e4a2b0 fffff880`05e4a2b0 fffff880`05e4a2b0 00000000`00000000 : Ntfs!NtfsCommonCleanupOnNewStack+0x42
fffff880`05e4a250 fffff880`01007bcf : fffff880`05e4a2b0 fffffa80`05a27010 fffffa80`05a273b0 fffffa80`059be010 : Ntfs!NtfsFsdCleanup+0x144
fffff880`05e4a4c0 fffff880`010066df : fffffa80`049acc20 00000000`00000000 fffffa80`0441f400 fffffa80`05a27010 : fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x24f
fffff880`05e4a550 fffff800`0338cf0f : fffffa80`05a27010 00000000`00000000 00000000`00000000 fffffa80`057a3a20 : fltmgr!FltpDispatch+0xcf
fffff880`05e4a5b0 fffff800`03383d7c : fffff880`01027cb0 fffffa80`056df4c8 00000000`20707249 fffffa80`05a29010 : nt!IopCloseFile+0x11f
fffff880`05e4a640 fffff800`0337fd38 : fffffa80`048fa650 fffff880`01027cb0 fffffa80`056df310 000007fe`00000001 : nt!IopParseDevice+0xe8c
fffff880`05e4a7d0 fffff800`03380f56 : 00000000`00000000 fffffa80`056df310 fa80059d`4e400420 fffffa80`039f4080 : nt!ObpLookupObjectName+0x588
fffff880`05e4a8c0 fffff800`03360f66 : 00000000`00000000 00000000`0142efa0 fffff683`ff7d8501 fffff800`030a2ac3 : nt!ObOpenObjectByName+0x306
fffff880`05e4a990 fffff800`030848d3 : 00000000`00000000 000007fe`fb0bef54 fffffa80`05a29660 00000000`c0000034 : nt!NtQueryAttributesFile+0x145
fffff880`05e4ac20 00000000`775a16ea : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0142ef68 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x775a16ea
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  Ntfs!NtfsCommonCleanup+1f68
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME:  Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce792f9
STACK_COMMAND:  .cxr 0xfffff88005e57e20 ; kb
FAILURE_BUCKET_ID:  X64_0x24_Ntfs!NtfsCommonCleanup+1f68
Drivers:
fffff880`00ee1000 fffff880`00f38000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01157000 fffff880`011e0000   afd      afd.sys      Sat Nov 20 09:23:27 2010 (4CE7938F)
fffff880`0486f000 fffff880`04885000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`03b39000 fffff880`03b4d000   amdiox64 amdiox64.sys Thu Feb 18 15:17:53 2010 (4B7D5A21)
fffff880`02dc0000 fffff880`02dd5000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00fe8000 fffff880`00ff3000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`04093000 fffff880`0409b000   ASACPI   ASACPI.sys   Mon Mar 28 03:30:36 2005 (42476C4C)
fffff880`00fb5000 fffff880`00fbe000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fbe000 fffff880`00fe8000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`03bce000 fffff880`03bef000   AtihdW76 AtihdW76.sys Thu Mar 31 08:15:43 2011 (4D942A1F)
fffff880`048a8000 fffff880`051dc000   atikmdag atikmdag.sys Wed Apr 20 02:53:29 2011 (4DAE3C99)
fffff880`02c00000 fffff880`02c50000   atikmpag atikmpag.sys Wed Apr 20 02:22:32 2011 (4DAE3558)
fffff960`00900000 fffff960`00961000   ATMFD    ATMFD.DLL    Sat Nov 20 09:49:28 2010 (4CE799A8)
fffff880`01680000 fffff880`0169f000   avgntflt avgntflt.sys Fri May 27 15:33:08 2011 (4DDFB624)
fffff880`02d76000 fffff880`02d9a000   avipbb   avipbb.sys   Tue Jun 14 14:57:13 2011 (4DF768B9)
fffff880`016e9000 fffff880`016f0000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`02d65000 fffff880`02d76000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`03a72000 fffff880`03a8f000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`016b6000 fffff880`016e0000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d35000 fffff880`00df5000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01650000 fffff880`01680000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cd7000 fffff880`00d35000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`010c3000 fffff880`01135000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0485f000 fffff880`0486f000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`03a9b000 fffff880`03aa9000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`02cc4000 fffff880`02d47000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`02d47000 fffff880`02d65000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03c17000 fffff880`03c26000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0163a000 fffff880`01650000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03a3d000 fffff880`03a5f000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`03ab5000 fffff880`03abe000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`03aa9000 fffff880`03ab5000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`03abe000 fffff880`03ad1000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`03a8f000 fffff880`03a9b000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0409b000 fffff880`0418f000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0418f000 fffff880`041d5000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`01051000 fffff880`01065000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01005000 fffff880`01051000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013ea000 fffff880`013f4000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`0163a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`018f6000 fffff880`01940000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`035ef000 fffff800`03638000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`041d5000 fffff880`041f9000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05a00000 fffff880`05a19000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05bf7000 fffff880`05bff080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05be9000 fffff880`05bf7000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`019f0000 fffff880`019f9000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`0481d000 fffff880`0483b000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0483b000 fffff880`0484a000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bd0000 fffff800`00bda000   kdcom    kdcom.dll    Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`03af6000 fffff880`03b39000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013be000 fffff880`013d9000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`03a5f000 fffff880`03a64200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`02a96000 fffff880`02aab000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`02a52000 fffff880`02a75000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cb6000 fffff880`00cc3000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`03ad1000 fffff880`03adf000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`051ed000 fffff880`051fc000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`03a65000 fffff880`03a72000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e73000 fffff880`00e8d000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`01489000 fffff880`01494000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f41000 fffff880`00f4b000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01065000 fffff880`010c3000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03c0c000 fffff880`03c17000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`019de000 fffff880`019f0000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0149f000 fffff880`01592000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`04885000 fffff880`04891000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`02c74000 fffff880`02ca3000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`03bb9000 fffff880`03bce000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03d4f000 fffff880`03d5e000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03c2e000 fffff880`03c73000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01592000 fffff880`015f2000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01200000 fffff880`01211000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03c00000 fffff880`03c0c000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03005000 fffff800`035ef000   nt       ntkrnlmp.exe Sat Nov 20 09:30:02 2010 (4CE7951A)
fffff880`0121b000 fffff880`013be000   Ntfs     Ntfs.sys     Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`016e0000 fffff880`016e9000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`03c7c000 fffff880`03ca2000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`04800000 fffff880`0481d000   parport  parport.sys  Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`00f8b000 fffff880`00fa0000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f4b000 fffff880`00f7e000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e63000 fffff880`00e73000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013d9000 fffff880`013ea000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`03a00000 fffff880`03a3d000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cc3000 fffff880`00cd7000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`03ca2000 fffff880`03d4f000   pwipf6   pwipf6.sys   Mon Jan 31 11:47:04 2011 (4D46A138)
fffff880`02c50000 fffff880`02c74000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`02ca3000 fffff880`02cbe000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`02dd5000 fffff880`02df6000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`011e0000 fffff880`011fa000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03daa000 fffff880`03dfb000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04891000 fffff880`0489c000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`0146e000 fffff880`01477000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01477000 fffff880`01480000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01480000 fffff880`01489000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`019a4000 fffff880`019de000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`02aab000 fffff880`02ac3000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04000000 fffff880`04032000   Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`0484a000 fffff880`04856000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`03d5e000 fffff880`03d7b000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`0199c000 fffff880`019a4000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`041f9000 fffff880`041fa480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`016f2000 fffff880`018f6000   tcpip    tcpip.sys    Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`015f2000 fffff880`015ff000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01135000 fffff880`01157000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03d96000 fffff880`03daa000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005a0000 fffff960`005aa000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d9a000 fffff880`02dc0000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`03b4d000 fffff880`03b5f000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05bca000 fffff880`05be7000   usbccgp  usbccgp.sys  Sat Nov 20 10:44:03 2010 (4CE7A673)
fffff880`05be7000 fffff880`05be8f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`051dc000 fffff880`051ed000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`03b5f000 fffff880`03bb9000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`04032000 fffff880`0403d000   usbohci  usbohci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`0403d000 fffff880`04093000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`00f7e000 fffff880`00f8b000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0142b000 fffff880`01439000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`05a1c000 fffff880`05bca000   viahduaa viahduaa.sys Mon Jan 11 10:05:18 2010 (4B4AF7DE)
fffff880`01439000 fffff880`0145e000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e8d000 fffff880`00ec9000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01940000 fffff880`01950000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00fa0000 fffff880`00fb5000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01950000 fffff880`0199c000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`03d7b000 fffff880`03d96000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`0145e000 fffff880`0146e000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ca4000 fffff880`00cb3000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03c73000 fffff880`03c7c000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00370000   win32k   win32k.sys   Sat Nov 20 09:52:51 2010 (4CE79A73)
fffff880`00ec9000 fffff880`00edd000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`04856000 fffff880`0485f000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f38000 fffff880`00f41000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02a75000 fffff880`02a96000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`01680000 fffff880`0168e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0168e000 fffff880`0169a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0169a000 fffff880`016a3000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`016a3000 fffff880`016b6000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Download and run CPU-Z. Take screenshots/snips of the Memory tab and all the slot#'s under the SPD tab.
Go to Post Reply, click on Go Advanced button and attach the screenshots to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
