swichi
Hi, I have Windows 7 Ultimate 32-bit and i want install my INTEX analog TV tuner PCI card wich win7 recognized like FlyTV P30+
WMC after KB for low bit rate work,s but sound is out of sync and too low. I tried to install the software that I got with her and who worked on XP, but get an error: 80040212 Cannot run preview graph.
My question is whether there is any software win7 where I can watch TV while it's not Windows Media Center.
Thanks
To resolve the issue with your INTEX analog TV tuner PCI card on Windows 7 Ultimate 32-bit where Windows Media Center is not functioning properly due to sound sync and volume issues, you can try using alternative software for watching TV. Here are a few options you can consider: 1. ProgDVB: ProgDVB is a powerful and feature-rich software that allows you to watch digital TV and listen to radio channels directly from your computer. It supports various TV sources, including DVB-S (satellite), DVB-S2, DVB-C (cable), DVB-T, ATSC, ISDB-T, IPTV, and analog TV. 2. Kodi (formerly XBMC): Kodi is a popular media player software that supports a variety of formats and sources, including TV tuners. You can use Kodi with TV tuner add-ons...
To resolve the issue with your INTEX analog TV tuner PCI card on Windows 7 Ultimate 32-bit where Windows Media Center is not functioning properly due to sound sync and volume issues, you can try using alternative software for watching TV. Here are a few options you can consider: 1. ProgDVB: ProgDVB is a powerful and feature-rich software that allows you to watch digital TV and listen to radio channels directly from your computer. It supports various TV sources, including DVB-S (satellite), DVB-S2, DVB-C (cable), DVB-T, ATSC, ISDB-T, IPTV, and analog TV. 2. Kodi (formerly XBMC): Kodi is a popular media player software that supports a variety of formats and sources, including TV tuners. You can use Kodi with TV tuner add-ons to watch live TV on your computer. 3. MediaPortal: MediaPortal is an open-source media center software that offers a user-friendly interface for watching live TV, recording shows, and accessing other media content. Before installing any of these programs, ensure that they are compatible with Windows 7 and support analog TV tuners. You may also need to install the necessary drivers for your INTEX analog TV tuner PCI card to ensure proper functionality with the new software. Try one of these alternatives and see if they provide a solution to your TV viewing needs on Windows 7 without relying on Windows Media Center.
