Windows 7 unable to reach outside LAN upon resume from sleep
merk
I'm not sure when this started happening - i don't think I changed any network settings, maybe after a windows update?
Anyhow, when i wake up my PC i'm unable to reach anything outside the LAN, even via it's IP address. I can ping the router and pull up the router's web page via Link Removed
I tried getting a new router - same problem.
The router is running dd-wrt, but it was happening with the default firmware as well as the latest firmware (asus rt-n16).
It's easy enough for me to fix the problem - i disabled the network connection and re-enable it and everything works. But this still a pain since I have my computer set up for Wake on Lan so that I can access it remotely.
The NIC is a Realtek PCIe card.
Anyone have any ideas why this is happening and how to fix it?
Hello,
I had similar wake on lan problem with my Realtek NIC. After some investigation, I found out that problem is related to NIC driver.
I solved it by installing vendor NIC driver from Realtek website.
Hope it helps.
Hello,
Hope it helps.
