- Thread Author
- #1
I need help setting up properly my NICs on windows 7. This is what happens:
I have a PC (Asus A8-N SLI Deluxe) with two embeded NICs both GigaBit.
Unfortunately one of the two does not have the correct driver (unavailable because the Mobo is old) and it allows me to select up to 100 Mbps Full Duples.
Rather I wish to set it up to go up to 1 Gb. This is not possible.
I have even tried to install a windows vista x64 driver but nothing done.
My current Config is:
NIC #1 (nVidia nForce 4 Controller) = wired, configured and recognized as Domain Netowrk with static IP
NIC #2 (Marvell Yukon 88E8001/8003/8001 PCI Gigabit Ethernet) = unplugged and not configured
NIC #2 has the correct and most updated driver and allows me to set it up manually up to 1 Gb.
If I switch roles, implementing this setting it never works and my PC is isolated from the Internet.
NIC #1 unplugged and not configured
NIC #2 wired, configured and recognized as Domain Netowrk.
This is what I get (similar case) = Link Removed - Invalid URL
where UIUCnet is my NIC #1 and Unidentified Network is my NIC #2
Can someone please help me out trying to implement my second configuration being NIC #2 up and running and NIC #1 unplugged?
To me this is a quite simple step. I should be able to choose which NIC to choose, even because I can disable one of each from BISO, but for
some strange reason my second configuration NEVER worked.
Please let me know..
Thanks a lot,
Spiro
Thanks a lot,
Spiro
