Windows 7 UNEXPECTED SHUTDOWN OF WINDOW 7(32bit)
pcprincelive
Good Morning All,,
well i am getting a problem with my window7(32),,whenever i start my laptop it unexpectedly shutdown once then after starting, Cpu processing reaches 90-100%.
But I've checked throughout that there are no heavy applications or processes running.
Both of these problems inviting more troubles like
1.) Gettting Less Battery Backup
2.) More Heating Up
3.) Not responding problem after a few minutes ,everytime i start an application
4.) System Hang
Please Help me out Regarding this ,, i would be obliged to u..plzplzplz LLLLLLessLess LeessLessLeLess Battery BackUp
More Heating UpLess Battery BackUp
More Heating llll
The details of unexpected shutdown Problem are following:
Problem Signature:
Problem Event Name: blueScreen
Os Version: 6.1.7600.2.0.0.256.1
Locale Id: 1033
Additional Information about the problem:
BCCode: 124
BCP1: 00000000
BCP2: 85DD1024
BCP3: 00000000
BCP4: 00000000
OS Version : 6_1_7600
Service Pack: 0_0
Product: 256_1
Thank you.
It seems like your Windows 7 (32-bit) laptop is encountering several issues, including unexpected shutdowns, high CPU usage, reduced battery backup, overheating, unresponsiveness, system hanging, and blue screen errors (BCCode: 124). These problems can be challenging, but here are some steps you can take to troubleshoot and potentially resolve these issues: 1. High CPU Usage and Unexpected Shutdowns: - Check for malware using Windows Defender or a third-party antivirus program. - Run a disk cleanup to remove temporary and unnecessary files. - Update device drivers, especially graphics and chipset drivers. - Monitor background processes using Task Manager to identify any resource-intensive applications. 2. Battery Backup and...
It seems like your Windows 7 (32-bit) laptop is encountering several issues, including unexpected shutdowns, high CPU usage, reduced battery backup, overheating, unresponsiveness, system hanging, and blue screen errors (BCCode: 124). These problems can be challenging, but here are some steps you can take to troubleshoot and potentially resolve these issues: 1. High CPU Usage and Unexpected Shutdowns: - Check for malware using Windows Defender or a third-party antivirus program. - Run a disk cleanup to remove temporary and unnecessary files. - Update device drivers, especially graphics and chipset drivers. - Monitor background processes using Task Manager to identify any resource-intensive applications. 2. Battery Backup and Heating Issues: - Ensure proper ventilation to prevent overheating. - Adjust power settings to optimize battery life (Control Panel > Power Options). - Consider replacing the laptop battery if it's old and not holding a charge efficiently. 3. Application Unresponsiveness and System Hang: - Check for disk errors using CHKDSK. - Disable unnecessary startup programs using MSConfig. - Consider increasing RAM if the system is running low on memory. 4. Blue Screen Error (BCCode: 124): - BCCode 124 often indicates hardware issues, such as faulty hardware components (RAM, motherboard, etc.). - Update BIOS firmware if available. - Test hardware components (RAM, CPU, hard drive) for any failures. 5. General Recommendations: - Make sure Windows 7 is fully updated with the latest security patches. - Backup important data regularly to prevent data loss in case of system failure. - Consider upgrading to a newer supported operating system like Windows 10 for better performance and security. If the issues persist after following these steps, seeking professional help or taking the laptop to a repair center may be necessary to diagnose and fix any underlying hardware problems. It's crucial to address these issues promptly to prevent further damage to the system.
