Hi RedPoker and Welcome to The Forum.
STOP 0x00000019: BAD_POOL_HEADER
Usual causes: Device driver
Your latest dump file lists
klim6.sys as the probable cause. This is a driver for your Kaspersky Security Software..
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes often indicate hardware issues.
Kaspersky can, on rare occasions, contribute to BSOD's on some Windows 7 systems. For now, until your PC settles:
Uninstall Kaspersky with the
Removal tool for Kaspersky and download BSOD friendly
Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled. Once your blue screen issues are resolved feel free to re-install an up to date Kaspersky set up.
Make sure your system is fully up to date including
SP1 Will update this thread shortly with any other recommendations.
**** UPDATE ****
As a Priority: sptd.sys Sun Oct 11 21:54:02 2009 The
sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from
Duplex Secure - Downloads to uninstall the SPTD.SYS driver.
Make sure to select the
uninstall button!
DO NOT SELECT INSTALL!! Outdated Drivers. Update: Rt86win7.sys Thu Feb 26 09:04:22 2009 Realtek PCIe GBE Family Controller v7.046 Rtnicxp.sys Fri May 30 16:12:11 2008 Realtek 10/100/1000 NDIS 5.1 Driver SCDEmu.SYS Mon Apr 09 13:27:07 2007 Link Removed - Invalid URL hcmon.sys Fri Mar 27 01:51:53 2009
vmci.sys Fri Mar 27 01:20:49 2009
VMkbd.sys Fri Mar 27 03:59:48 2009
VMNET.SYS Thu May 22 11:33:05 2008
vmnetbridge.sys Thu May 22 11:33:38 2008
vmnetuserif.sys Fri Mar 27 02:04:43 2009
VMparport.sys Fri Mar 27 01:19:57 2009
vstor2-ws60.sys Mon Dec 01 19:26:30 2008 VMware Drivers with Updates: nvlddmkm.sys Sat Jan 08 02:03:58 2011 nVidia Graphics Drivers. Bugcheck Analysis: Code:
* Bugcheck Analysis *
BugCheck 19, {20, 86254f38, 86255150, 4a434642}
Unable to load image \SystemRoot\system32\DRIVERS\klim6.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for klim6.sys
*** ERROR: Module load completed but symbols could not be loaded for klim6.sys
Probably caused by : klim6.sys ( klim6+218f )
Followup: MachineOwner
1: kd> !analyze -v
BAD_POOL_HEADER (19)
The pool is already corrupt at the time of the current request.
This may or may not be due to the caller.
The internal pool links must be walked to figure out a possible cause of
the problem, and then special pool applied to the suspect tags or the driver
verifier to a suspect driver.
Arguments:
Arg1: 00000020, a pool block header size is corrupt.
Arg2: 86254f38, The pool entry we were looking for within the page.
Arg3: 86255150, The next pool entry.
Arg4: 4a434642, (reserved)
Debugging Details:
BUGCHECK_STR: 0x19_20
POOL_ADDRESS: GetPointerFromAddress: unable to read from 82ba9718
Unable to read MiSystemVaType memory at 82b89160
86254f38
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: INTEL_CPU_MICROCODE_ZERO
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 8c8ff651 to 82b601b6
STACK_TEXT:
807df4dc 8c8ff651 86254f40 00000000 00000000 nt!ExFreePoolWithTag+0x1b1
807df4ec 8ce2118f 86254f40 00000000 00000000 ndis!NdisFreeMemory+0x16
WARNING: Stack unwind information not available. Following frames may be wrong.
00000000 00000000 00000000 00000000 00000000 klim6+0x218f
STACK_COMMAND: kb
FOLLOWUP_IP:
klim6+218f
8ce2118f ?? ???
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: klim6+218f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: klim6
IMAGE_NAME: klim6.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4bd06628
FAILURE_BUCKET_ID: 0x19_20_klim6+218f
Drivers: Code:
8c75a000 8c7a2000 ACPI ACPI.sys Tue Jul 14 00:11:11 2009 (4A5BBF0F)
8cf5b000 8cfb5000 afd afd.sys Tue Jul 14 00:12:34 2009 (4A5BBF62)
943af000 943c1000 AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
8c8a5000 8c8ae000 amdxata amdxata.sys Tue May 19 18:57:35 2009 (4A12F30F)
94369000 943a2000 amwrd01a amwrd01a.SYS Tue Jul 14 22:12:41 2009 (4A5CF4C9)
8c879000 8c882000 atapi atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8c882000 8c8a5000 ataport ataport.SYS Tue Jul 14 00:11:18 2009 (4A5BBF16)
8d5f4000 8d5fb000 Beep Beep.SYS Tue Jul 14 00:45:00 2009 (4A5BC6FC)
926fd000 9270b000 blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
8c49a000 8c4a2000 BOOTVID BOOTVID.dll Tue Jul 14 02:04:34 2009 (4A5BD9A2)
9ac9f000 9acb8000 bowser bowser.sys Tue Jul 14 00:14:21 2009 (4A5BBFCD)
82730000 8274e000 cdd cdd.dll unavailable (00000000)
97bd3000 97bf2000 cdrom cdrom.sys Tue Jul 14 00:11:24 2009 (4A5BBF1C)
8c4e4000 8c58f000 CI CI.dll Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8d577000 8d59c000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
8c4a2000 8c4e4000 CLFS CLFS.SYS Tue Jul 14 00:11:10 2009 (4A5BBF0E)
8cb93000 8cbf0000 cng cng.sys Tue Jul 14 00:32:55 2009 (4A5BC427)
943a2000 943af000 CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
97a00000 97a0d000 crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
92681000 926e5000 csc csc.sys Tue Jul 14 00:15:08 2009 (4A5BBFFC)
926e5000 926fd000 dfsc dfsc.sys Tue Jul 14 00:14:16 2009 (4A5BBFC8)
92675000 92681000 discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
8d566000 8d577000 disk disk.sys Tue Jul 14 00:11:28 2009 (4A5BBF20)
97bba000 97bd3000 drmk drmk.sys Tue Jul 14 01:36:05 2009 (4A5BD2F5)
97a18000 97a21000 dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
97a0d000 97a18000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
943e4000 943f5000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
97bf2000 97bfc000 Dxapi Dxapi.sys Tue Jul 14 00:25:25 2009 (4A5BC265)
9273e000 927f5000 dxgkrnl dxgkrnl.sys Tue Jul 14 00:26:15 2009 (4A5BC297)
94216000 9424f000 dxgmms1 dxgmms1.sys Tue Jul 14 00:25:25 2009 (4A5BC265)
ab51d000 ab591200 EagleXNt EagleXNt.sys Wed Mar 16 01:05:14 2011 (4D800CCA)
ab4f3000 ab51d000 fastfat fastfat.SYS Tue Jul 14 00:14:01 2009 (4A5BBFB9)
8c8e2000 8c8f3000 fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
8c8ae000 8c8e2000 fltmgr fltmgr.sys Tue Jul 14 00:11:13 2009 (4A5BBF11)
8ca00000 8ca09000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:11:14 2009 (4A5BBF12)
8d534000 8d566000 fvevol fvevol.sys Tue Jul 14 00:13:01 2009 (4A5BBF7D)
8cd65000 8cd96000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
82a0a000 82a41000 hal halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
9ad43000 9ad4d000 hcmon hcmon.sys Fri Mar 27 01:51:53 2009 (49CC3139)
942b4000 942d3000 HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
97b3b000 97b8b000 HdAudio HdAudio.sys Tue Jul 14 00:51:46 2009 (4A5BC892)
9ac1a000 9ac9f000 HTTP HTTP.sys Tue Jul 14 00:12:53 2009 (4A5BBF75)
8d52c000 8d534000 hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
94329000 94341000 i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
9272c000 9273e000 intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
94357000 94364000 kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
80baf000 80bb7000 kdcom kdcom.dll Tue Jul 14 02:08:58 2009 (4A5BDAAA)
8d00a000 8d52c000 kl1 kl1.sys Wed Jun 09 14:24:39 2010 (4C0F9617)
8d5e7000 8d5ed000 kl2 kl2.sys Wed Jun 09 14:24:35 2010 (4C0F9613)
8ce6c000 8ceef000 klif klif.sys Fri Oct 01 08:30:11 2010 (4CA58E03)
8ce1f000 8ce27000 klim6 klim6.sys Thu Apr 22 16:07:20 2010 (4BD06628)
94341000 9434a000 klmouflt klmouflt.sys Mon Nov 02 16:26:08 2009 (4AEF0820)
97aa4000 97ad8000 ks ks.sys Tue Jul 14 00:45:13 2009 (4A5BC709)
8cb80000 8cb93000 ksecdd ksecdd.sys Tue Jul 14 00:11:56 2009 (4A5BBF3C)
8c600000 8c625000 ksecpkg ksecpkg.sys Tue Jul 14 00:34:00 2009 (4A5BC468)
94200000 94210000 lltdio lltdio.sys Tue Jul 14 00:53:18 2009 (4A5BC8EE)
92600000 9261b000 luafv luafv.sys Tue Jul 14 00:15:44 2009 (4A5BC020)
8c411000 8c489000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:06:41 2009 (4A5BDA21)
97a21000 97a2c000 monitor monitor.sys Tue Jul 14 00:25:58 2009 (4A5BC286)
9434a000 94357000 mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8c863000 8c879000 mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
9acb8000 9acca000 mpsdrv mpsdrv.sys Tue Jul 14 00:52:52 2009 (4A5BC8D4)
9acca000 9aced000 mrxsmb mrxsmb.sys Tue Jul 14 00:14:24 2009 (4A5BBFD0)
9aced000 9ad28000 mrxsmb10 mrxsmb10.sys Tue Jul 14 00:14:34 2009 (4A5BBFDA)
9ad28000 9ad43000 mrxsmb20 mrxsmb20.sys Tue Jul 14 00:14:29 2009 (4A5BBFD5)
8cf20000 8cf2b000 Msfs Msfs.SYS Tue Jul 14 00:11:26 2009 (4A5BBF1E)
8c7a2000 8c7aa000 msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
8cb55000 8cb80000 msrpc msrpc.sys Tue Jul 14 00:11:59 2009 (4A5BBF3F)
9266b000 92675000 mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8ce5c000 8ce6c000 mup mup.sys Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8c8f3000 8c9aa000 ndis ndis.sys Tue Jul 14 00:12:24 2009 (4A5BBF58)
943d9000 943e4000 ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
97a30000 97a52000 ndiswan ndiswan.sys Tue Jul 14 00:54:34 2009 (4A5BC93A)
97b2a000 97b3b000 NDProxy NDProxy.SYS Tue Jul 14 00:54:27 2009 (4A5BC933)
8cde6000 8cdf4000 netbios netbios.sys Tue Jul 14 00:53:54 2009 (4A5BC912)
8cfb5000 8cfe7000 netbt netbt.sys Tue Jul 14 00:12:18 2009 (4A5BBF52)
8c9aa000 8c9e8000 NETIO NETIO.SYS Tue Jul 14 00:12:35 2009 (4A5BBF63)
8cf2b000 8cf39000 Npfs Npfs.SYS Tue Jul 14 00:11:31 2009 (4A5BBF23)
92661000 9266b000 nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
82a41000 82e51000 nt ntkrpamp.exe Tue Jul 14 00:15:19 2009 (4A5BC007)
8ca26000 8cb55000 Ntfs Ntfs.sys Tue Jul 14 00:12:05 2009 (4A5BBF45)
8d5ed000 8d5f4000 Null Null.SYS Tue Jul 14 00:11:12 2009 (4A5BBF10)
93400000 93401040 nvBridge nvBridge.kmd Sat Jan 08 01:57:19 2011 (4D27C47F)
93405000 93dfeee0 nvlddmkm nvlddmkm.sys Sat Jan 08 02:03:58 2011 (4D27C60E)
8ce00000 8ce1f000 pacer pacer.sys Tue Jul 14 00:53:58 2009 (4A5BC916)
94311000 94329000 parport parport.sys Tue Jul 14 00:45:34 2009 (4A5BC71E)
8c7df000 8c7f0000 partmgr partmgr.sys Tue Jul 14 00:11:35 2009 (4A5BBF27)
9ad4d000 9ad54000 parvdm parvdm.sys Tue Jul 14 00:45:29 2009 (4A5BC719)
8c7b5000 8c7df000 pci pci.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
8c84e000 8c855000 pciide pciide.sys Tue Jul 14 00:11:19 2009 (4A5BBF17)
8c855000 8c863000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:11:15 2009 (4A5BBF13)
8cbf0000 8cbfe000 pcw pcw.sys Tue Jul 14 00:11:10 2009 (4A5BBF0E)
9dafe000 9db95000 peauth peauth.sys Tue Jul 14 01:35:44 2009 (4A5BD2E0)
97b8b000 97bba000 portcls portcls.sys Tue Jul 14 00:51:00 2009 (4A5BC864)
8c489000 8c49a000 PSHED PSHED.dll Tue Jul 14 02:09:36 2009 (4A5BDAD0)
943c1000 943d9000 rasl2tp rasl2tp.sys Tue Jul 14 00:54:33 2009 (4A5BC939)
97a52000 97a6a000 raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
97a6a000 97a81000 raspptp raspptp.sys Tue Jul 14 00:54:47 2009 (4A5BC947)
97a81000 97a98000 rassstp rassstp.sys Tue Jul 14 00:54:57 2009 (4A5BC951)
92620000 92661000 rdbss rdbss.sys Tue Jul 14 00:14:26 2009 (4A5BBFD2)
97a98000 97aa2000 rdpbus rdpbus.sys Tue Jul 14 01:02:40 2009 (4A5BCB20)
8d000000 8d008000 RDPCDD RDPCDD.sys Tue Jul 14 01:01:40 2009 (4A5BCAE4)
8cf10000 8cf18000 rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
8cf18000 8cf20000 rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
8ce2f000 8ce5c000 rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
8d5b6000 8d5c9000 rspndr rspndr.sys Tue Jul 14 00:53:20 2009 (4A5BC8F0)
942d3000 942f8000 Rt86win7 Rt86win7.sys Thu Feb 26 09:04:22 2009 (49A65B16)
942f8000 94307000 Rtnicxp Rtnicxp.sys Fri May 30 16:12:11 2008 (4840194B)
8ce27000 8ce2e260 SCDEmu SCDEmu.SYS Mon Apr 09 13:27:07 2007 (461A311B)
8c734000 8c75a000 SCSIPORT SCSIPORT.SYS Tue Jul 14 00:45:55 2009 (4A5BC733)
9db95000 9db9f000 secdrv secdrv.SYS Wed Sep 13 14:18:32 2006 (45080528)
94307000 94311000 serenum serenum.sys Tue Jul 14 00:45:27 2009 (4A5BC717)
8cc00000 8cc1a000 serial serial.sys Tue Jul 14 00:45:33 2009 (4A5BC71D)
8cdde000 8cde6000 spldr spldr.sys Mon May 11 17:13:47 2009 (4A084EBB)
8c638000 8c72b000 sptd sptd.sys Sun Oct 11 21:54:02 2009 (4AD245EA)
ab438000 ab489000 srv srv.sys Tue Jul 14 00:15:10 2009 (4A5BBFFE)
9ad62000 9adb1000 srv2 srv2.sys Tue Jul 14 00:14:52 2009 (4A5BBFEC)
9db9f000 9dbc0000 srvnet srvnet.sys Tue Jul 14 00:14:45 2009 (4A5BBFE5)
97aa2000 97aa3380 swenum swenum.sys Tue Jul 14 00:45:08 2009 (4A5BC704)
8cc1c000 8cd65000 tcpip tcpip.sys Tue Jul 14 00:13:18 2009 (4A5BBF8E)
9dbc0000 9dbcd000 tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
8cf50000 8cf5b000 TDI TDI.SYS Tue Jul 14 00:12:12 2009 (4A5BBF4C)
8cf39000 8cf50000 tdx tdx.sys Tue Jul 14 00:12:10 2009 (4A5BBF4A)
8c9e8000 8c9f8000 termdd termdd.sys Tue Jul 14 01:01:35 2009 (4A5BCADF)
82700000 82709000 TSDDD TSDDD.dll unavailable (00000000)
9270b000 9272c000 tunnel tunnel.sys Tue Jul 14 00:54:03 2009 (4A5BC91B)
97ad8000 97ae6000 umbus umbus.sys Tue Jul 14 00:51:38 2009 (4A5BC88A)
942a5000 942b4000 usbehci usbehci.sys Tue Jul 14 00:51:14 2009 (4A5BC872)
97ae6000 97b2a000 usbhub usbhub.sys Tue Jul 14 00:52:06 2009 (4A5BC8A6)
9425a000 942a5000 USBPORT USBPORT.SYS Tue Jul 14 00:51:13 2009 (4A5BC871)
9424f000 9425a000 usbuhci usbuhci.sys Tue Jul 14 00:51:10 2009 (4A5BC86E)
8c7aa000 8c7b5000 vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
8d5ce000 8d5da000 vga vga.sys Tue Jul 14 00:25:50 2009 (4A5BC27E)
8ceef000 8cf10000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
9ad54000 9ad5fc80 vmci vmci.sys Fri Mar 27 01:20:49 2009 (49CC29F1)
94364000 94368080 VMkbd VMkbd.sys Fri Mar 27 03:59:48 2009 (49CC4F34)
97a2c000 97a2ef00 VMNET VMNET.SYS Thu May 22 11:33:05 2008 (48354BE1)
943f5000 943fb000 vmnetbridge vmnetbridge.sys Thu May 22 11:33:38 2008 (48354C02)
9dbcd000 9dbd1c80 vmnetuserif vmnetuserif.sys Fri Mar 27 02:04:43 2009 (49CC343B)
9ad60000 9ad62000 VMparport VMparport.sys Fri Mar 27 01:19:57 2009 (49CC29BD)
8cd96000 8cd9e380 vmstorfl vmstorfl.sys Tue Jul 14 00:28:44 2009 (4A5BC32C)
9da2e000 9dafdb80 vmx86 vmx86.sys Fri Mar 27 04:27:32 2009 (49CC55B4)
8c7f0000 8c800000 volmgr volmgr.sys Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8c803000 8c84e000 volmgrx volmgrx.sys Tue Jul 14 00:11:41 2009 (4A5BBF2D)
8cd9f000 8cdde000 volsnap volsnap.sys Tue Jul 14 00:11:34 2009 (4A5BBF26)
9dbd2000 9dbd5d80 vstor2_ws60 vstor2-ws60.sys Mon Dec 01 19:26:30 2008 (49343A66)
8ca09000 8ca1c000 wanarp wanarp.sys Tue Jul 14 00:55:02 2009 (4A5BC956)
8d5da000 8d5e7000 watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
8c58f000 8c600000 Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
8c400000 8c40e000 WDFLDR WDFLDR.SYS Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8cff0000 8cff7000 wfplwf wfplwf.sys Tue Jul 14 00:53:51 2009 (4A5BC90F)
824a0000 826ea000 win32k win32k.sys unavailable (00000000)
8c72b000 8c734000 WMILIB WMILIB.SYS Tue Jul 14 00:11:22 2009 (4A5BBF1A)
8cfe7000 8cff0000 ws2ifsl ws2ifsl.sys Tue Jul 14 00:55:01 2009 (4A5BC955)
8d59c000 8d5b6000 WudfPf WudfPf.sys Tue Jul 14 00:50:13 2009 (4A5BC835)
Unloaded modules:
ab400000 ab421000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00021000
ab5e3000 ab5e5000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
ab5cc000 ab5e3000 USBSTOR.SYS
Checksum: 00000000
ImageSize: 00017000
ab5ab000 ab5cc000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00021000
ab5a9000 ab5ab000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
ab592000 ab5a9000 USBSTOR.SYS
Checksum: 00000000
ImageSize: 00017000
ab489000 ab4f3000 spsys.sys
Checksum: 00000000
ImageSize: 0006A000
8d59c000 8d5a9000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000D000
8d5a9000 8d5b4000 dump_ataport
Checksum: 00000000
ImageSize: 0000B000
8d5b4000 8d5bd000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
8d5bd000 8d5ce000 dump_dumpfve
Checksum: 00000000
ImageSize: 00011000
8d5ce000 8d5ed000 cdrom.sys
Checksum: 00000000
ImageSize: 0001F000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
