Unknown BSOD occuring when starting games
valer
Capture1.PNG Capture2.PNG I've been getting this very annoying bsod recently, it mostly occurs once, the first time I use the computer after plugging it into the wall. I have windows 7 x64 and have eset nod32 av(64bit). I have already uninstalled my gpu drivers and driver cleaned them, and have also memtested with no problems. I installed fl studio recently and sometimes bsod in that, if this is the cause. I have disabled most unneccesary processes and have flashed bios and updated mobo drivers. I can't seem to find a solution. Thanks in advance.
Memdump is attached.
All the bsods seem to point to ntoskrnl.exe, which is the cause
IRQL_NOT_LESS_OR_EQUAL (a)
Probably caused by : memory_corruption
1. Uninstall Daemon Tools, reboot, and uninstall its driver with this tool:
DuplexSecure - FAQ
2. The memory settings look right. 9-9-9-24. Verify that the voltage is 1.5v or 'Auto'. In the bios.
If the crashes persist, run memtest 10 passes overnight:
Memtest86+ - Advanced Memory Diagnostic Tool
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010311-22417-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`0364d000 PsLoadedModuleList = 0xfffff800`0388ae50
Debug session time: Sun Jan  2 16:34:44.480 2011 (UTC - 5:00)
System Uptime: 0 days 0:06:19.182
Loading Kernel Symbols
Loading User Symbols
BugCheck A, {fffffa7cffffffe0, 2, 1, fffff800036e2f9e}
Probably caused by : memory_corruption ( nt!MiRemoveAnyPage+13e )
Followup: MachineOwner
0: kd> !analyze -v
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa7cffffffe0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff800036e2f9e, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800038f50e0
 fffffa7cffffffe0
CURRENT_IRQL:  0
FAULTING_IP:
fffff800`036e2f9e f0410fba6c241000 lock bts dword ptr [r12+10h],0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
LAST_CONTROL_TRANSFER:  from fffff800036cb24a to fffff880040c97f2
STACK_TEXT:
fffff800`04d88c98 fffff800`036cb24a : 00000000`002fe72f fffffa80`058479d8 fffff800`03845c40 00000000`00000001 : 0xfffff880`040c97f2
fffff800`04d88ca0 fffff800`036c5ebc : fffff800`03837e80 fffff800`00000000 00000000`00000000 fffff800`037ddda0 : nt!PoIdle+0x53a
fffff800`04d88d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
SYMBOL_NAME:  nt!MiRemoveAnyPage+13e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_nt!MiRemoveAnyPage+13e
Drivers:
fffff880`00e2f000 fffff880`00e86000   ACPI     ACPI.sys     unavailable (00000000)
fffff880`011eb000 fffff880`011ff000   amdsata  amdsata.sys  unavailable (00000000)
fffff880`01062000 fffff880`0106d000   amdxata  amdxata.sys  unavailable (00000000)
fffff880`011ad000 fffff880`011b6000   atapi    atapi.sys    unavailable (00000000)
fffff880`011b6000 fffff880`011e0000   ataport  ataport.SYS  unavailable (00000000)
fffff880`015e8000 fffff880`015f0000   AtiPcie  AtiPcie.sys  unavailable (00000000)
fffff880`00c85000 fffff880`00d45000   CI       CI.dll       unavailable (00000000)
fffff880`01200000 fffff880`01230000   CLASSPNP CLASSPNP.SYS unavailable (00000000)
fffff880`00c27000 fffff880`00c85000   CLFS     CLFS.SYS     unavailable (00000000)
fffff880`014be000 fffff880`01531000   cng      cng.sys      unavailable (00000000)
fffff880`015d2000 fffff880`015e8000   disk     disk.sys     unavailable (00000000)
fffff880`00fd8000 fffff880`00fec000   fileinfo fileinfo.sys unavailable (00000000)
fffff880`0106d000 fffff880`010b9000   fltmgr   fltmgr.sys   unavailable (00000000)
fffff880`01542000 fffff880`0154c000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   unavailable (00000000)
fffff880`017a6000 fffff880`017f0000   fwpkclnt fwpkclnt.sys unavailable (00000000)
fffff800`03604000 fffff800`0364d000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`016a5000 fffff880`016ae000   hwpolicy hwpolicy.sys unavailable (00000000)
fffff800`00ba4000 fffff800`00bae000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`014a4000 fffff880`014be000   ksecdd   ksecdd.sys   unavailable (00000000)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  unavailable (00000000)
fffff880`00c06000 fffff880`00c13000   mcupdate mcupdate.dll unavailable (00000000)
fffff880`01193000 fffff880`011ad000   mountmgr mountmgr.sys unavailable (00000000)
fffff880`011e0000 fffff880`011eb000   msahci   msahci.sys   unavailable (00000000)
fffff880`00e86000 fffff880`00e90000   msisadrv msisadrv.sys unavailable (00000000)
fffff880`01446000 fffff880`014a4000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`01693000 fffff880`016a5000   mup      mup.sys      unavailable (00000000)
fffff880`016b4000 fffff880`017a6000   ndis     ndis.sys     unavailable (00000000)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    unavailable (00000000)
fffff800`0364d000 fffff800`03c29000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0123d000 fffff880`013e0000   Ntfs     Ntfs.sys     unavailable (00000000)
fffff880`010f6000 fffff880`0110b000   partmgr  partmgr.sys  unavailable (00000000)
fffff880`010c3000 fffff880`010f6000   pci      pci.sys      unavailable (00000000)
fffff880`0117c000 fffff880`01183000   pciide   pciide.sys   unavailable (00000000)
fffff880`01183000 fffff880`01193000   PCIIDEX  PCIIDEX.SYS  unavailable (00000000)
fffff880`01531000 fffff880`01542000   pcw      pcw.sys      unavailable (00000000)
fffff880`00c13000 fffff880`00c27000   PSHED    PSHED.dll    unavailable (00000000)
fffff880`01598000 fffff880`015d2000   rdyboost rdyboost.sys unavailable (00000000)
fffff880`00e00000 fffff880`00e2f000   SCSIPORT SCSIPORT.SYS unavailable (00000000)
fffff880`0168b000 fffff880`01693000   spldr    spldr.sys    unavailable (00000000)
fffff880`00ea9000 fffff880`00fcf000   sptd     sptd.sys     unavailable (00000000)
fffff880`01000000 fffff880`01062000   storport storport.sys unavailable (00000000)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    unavailable (00000000)
02d702d6`02d502d4 02d702d6`05b205b0   Unknown_Module_02d702d6_02d502d4 Unknown_Module_02d702d6`02d502d4 unavailable (00000000)
fffff880`00e90000 fffff880`00e9d000   vdrvroot vdrvroot.sys unavailable (00000000)
fffff880`017f0000 fffff880`01800000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`0110b000 fffff880`01120000   volmgr   volmgr.sys   unavailable (00000000)
fffff880`01120000 fffff880`0117c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`0154c000 fffff880`01598000   volsnap  volsnap.sys  unavailable (00000000)
fffff880`00d45000 fffff880`00de9000   Wdf01000 Wdf01000.sys unavailable (00000000)
fffff880`00de9000 fffff880`00df8000   WDFLDR   WDFLDR.SYS   unavailable (00000000)
fffff880`00fcf000 fffff880`00fd8000   WMILIB   WMILIB.SYS   unavailable (00000000)
valer
Just BSODed again, around 3 mins after trying your fix. This time I got a registry error and another IRQL_not_less_or_equal. Here are the dumps. Please help, I'm going to a lan tommorow.
REGISTRY_ERROR (51)
Something has gone badly wrong with the registry
Pausible causes:
-- the registry encountered an I/O error while trying to read one of its files. This can be caused by hardware problems or file system corruption;
-- a failure in a refresh operation, which is used only in by the security system, and then only when resource limits are encountered;
Stack text:
STACK_TEXT:
fffff880`069cd3f8 fffff800`03a03f78 : 00000000`00000051 00000000`00000001 fffff8a0`00022200 00000000`017ef000 : nt!KeBugCheckEx
fffff880`069cd400 fffff800`039731c4 : 00000000`00064d9e 00000000`0000bf77 00000000`00000000 fffffa80`00000004 : nt! ?? ::NNGAKEGL::`string'+0x9b6a
fffff880`069cd460 fffff800`039723db : fffff8a0`00022200 fffff8a0`00022200 fffff8a0`00048160 00000000`00c8bfb0 : nt!HvMarkDirty+0x125
fffff880`069cd4c0 fffff800`03973326 : fffff8a0`00022200 fffff8a0`044486d8 fffff8a0`0444796c fffff8a0`00022200 : nt!HvMarkCellDirty+0x13b
fffff880`069cd510 fffff800`03934d02 : 00000000`00000001 fffff8a0`044486d8 fffff8a0`03bdaa7c fffff8a0`00022200 : nt!CmpMarkValueDataDirty+0x4a
fffff880`069cd550 fffff800`03934aa4 : fffff8a0`03bdaa7c 00000000`ffffffff fffff8a0`03bdaa7c fffff8a0`00022200 : nt!CmpMarkKeyValuesDirty+0x182
fffff880`069cd5f0 fffff800`039341aa : fffff8a0`00022200 00000000`ffffffff fffff8a0`03bdaa7c fffff8a0`00022200 : nt!CmpFreeKeyValues+0x24
fffff880`069cd620 fffff800`03933ed8 : fffff8a0`00022200 00000000`00e25180 fffff8a0`03bdaa7c fffff8a0`01527a78 : nt!CmpSyncKeyValues+0x7a
fffff880`069cd700 fffff800`0393679e : fffff8a0`084a3000 00000000`00a322f8 fffffa80`00000000 00000000`00000000 : nt!CmpCopySyncTree2+0x2a8
fffff880`069cd7b0 fffff800`039366b7 : 00000000`00000000 00000000`00000002 fffff8a0`02ec5e80 fffff8a0`039c9500 : nt!CmpCopySyncTree+0x6e
fffff880`069cd800 fffff800`03936286 : fffff8a0`08471470 00000000`00000000 00000000`00000001 00000000`00000000 : nt!CmpSaveBootControlSet+0x307
fffff880`069cd9e0 fffff800`036d4993 : fffffa80`0683f760 00000000`01413530 fffff880`069cdab0 00000000`00000001 : nt!NtInitializeRegistry+0xc6
fffff880`069cda30 fffff800`036d0f30 : fffff800`0393622f 00000000`00000220 00000000`0016f988 00000000`0016fcb8 : nt!KiSystemServiceCopyEnd+0x13
fffff880`069cdbc8 fffff800`0393622f : 00000000`00000220 00000000`0016f988 00000000`0016fcb8 00000000`000a001f : nt!KiServiceLinkage
fffff880`069cdbd0 fffff800`036d4993 : fffffa80`0683f760 fffff880`069cdca0 fffff880`069cdca0 00000000`00000003 : nt!NtInitializeRegistry+0x6f
fffff880`069cdc20 00000000`76f40afa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0016fc38 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76f40afa
FAILURE_BUCKET_ID: X64_0xA_nt!MmZeroPageThread - memory corruption
Pausible causes:
-- An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses.
Stack text:
STACK_TEXT:
fffff880`009a9938 fffff800`036c0ca9 : 00000000`0000000a fffffa7c`ffffffe0 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`009a9940 fffff800`036bf920 : 00000000`00000000 ffffffff`efffffff 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009a9a80 fffff800`03708349 : 00000000`000000ff 00000000`00000024 00000000`0000000d 00000000`00000000 : nt!KiPageFault+0x260
fffff880`009a9c10 fffff800`03965c06 : fffffa80`039d5b60 00000000`00000080 fffffa80`039d5040 fffff800`0369fc19 : nt!MmZeroPageThread+0x3d4
fffff880`009a9d40 fffff800`0369fc26 : fffff800`0383be80 fffffa80`039d5b60 fffff800`03849c40 ff097704`f9830e72 : nt!PspSystemThreadStartup+0x5a
fffff880`009a9d80 00000000`00000000 : fffff880`009aa000 fffff880`009a4000 fffff880`009a99b0 00000000`00000000 : nt!KxStartSystemThread+0x16
What to do:
1. Update Realtek 8136/8168/8169 PCI/PCIe Adapter:
Rt64win7.sys Thu Feb 26 04:04:13 2009
Realtek
2. Uninstall:
Eset
Elaborate Bytes AG CDRTools
SlySoft AnyDVD
3. Run HDD SMASRT Scan as a light hard disk diagnostic tool:
HDDScan
Also check the file system for errors:
Start >> cmd >> chkdsk /r /f
4. Give link to your memory sticks with their rated specs to reverify your current RAM settings.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010311-23166-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03665000 PsLoadedModuleList = 0xfffff800`038a2e50
Debug session time: Sun Jan  2 23:25:58.678 2011 (UTC - 5:00)
System Uptime: 0 days 0:01:02.005
Loading unloaded module list
BugCheck 51, {1, fffff8a000022200, 17ef000, 374}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+9b6a )
1: kd> !analyze -v
REGISTRY_ERROR (51)
Something has gone badly wrong with the registry.  If a kernel debugger
is available, get a stack trace. It can also indicate that the registry got
an I/O error while trying to read one of its files, so it can be caused by
hardware problems or filesystem corruption.
It may occur due to a failure in a refresh operation, which is used only
in by the security system, and then only when resource limits are encountered.
Arguments:
Arg1: 0000000000000001, (reserved)
Arg2: fffff8a000022200, (reserved)
Arg3: 00000000017ef000, depends on where Windows bugchecked, may be pointer to hive
Arg4: 0000000000000374, depends on where Windows bugchecked, may be return code of
	HvCheckHive if the hive is corrupt.
Debugging Details:
BUGCHECK_STR:  0x51
PROCESS_NAME:  services.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80003a03f78 to fffff800036d5740
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`03a03f78 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::NNGAKEGL::`string'+9b6a
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
FAILURE_BUCKET_ID:  X64_0x51_nt!_??_::NNGAKEGL::_string_+9b6a
Loading Dump File [F:\a\Minidump\D M P\DMP\010311-23977-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03651000 PsLoadedModuleList = 0xfffff800`0388ee50
Debug session time: Sun Jan  2 23:24:27.719 2011 (UTC - 5:00)
System Uptime: 0 days 0:15:32.420
BugCheck A, {fffffa7cffffffe0, 2, 1, fffff80003708349}
Probably caused by : memory_corruption ( nt!MmZeroPageThread+3d4 )
0: kd> !analyze -v
Arguments:
Arg4: fffff80003708349, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800038f90e0
 fffffa7cffffffe0
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`03708349 f0410fba6d1000  lock bts dword ptr [r13+10h],0
BUGCHECK_STR:  0xA
TRAP_FRAME:  fffff880009a9a80 -- (.trap 0xfffff880009a9a80)
rax=00000000000000ea rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80003708349 rsp=fffff880009a9c10 rbp=00000000000000ff
 r8=0000000000000000  r9=0000058000000000 r10=0000000000000002
r11=fffff880009a9c08 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
nt!MmZeroPageThread+0x3d4:
fffff800`03708349 f0410fba6d1000  lock bts dword ptr [r13+10h],0 ds:5b60:00000000`00000010=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800036c0ca9 to fffff800036c1740
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MmZeroPageThread+3d4
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0xA_nt!MmZeroPageThread+3d4
Drivers:
fffff880`03e00000 fffff880`03e3e000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f2f000 fffff880`00f86000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c65000 fffff880`02cef000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04336000 fffff880`0434c000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03f37000 fffff880`03f4c000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00c35000 fffff880`00c49000   amdsata  amdsata.sys  Wed Oct 07 16:13:09 2009 (4ACCF655)
fffff880`01140000 fffff880`0114b000   amdxata  amdxata.sys  Wed Oct 07 16:13:10 2009 (4ACCF656)
fffff880`051bc000 fffff880`051df000   AnyDVD   AnyDVD.sys   Wed Dec 01 14:06:20 2010 (4CF69CAC)
fffff880`079f0000 fffff880`079fb000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00df4000 fffff880`00dfd000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c00000 fffff880`00c2a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`048b7000 fffff880`050c8000   atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`03f55000 fffff880`03fa1000   atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff880`01974000 fffff880`0197c000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`00890000 fffff960`008f1000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`019e5000 fffff880`019ec000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03f00000 fffff880`03f11000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0751e000 fffff880`0753c000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`019b2000 fffff880`019dc000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d1a000 fffff880`00dda000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01944000 fffff880`01974000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cbc000 fffff880`00d1a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0105e000 fffff880`010d1000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04326000 fffff880`04336000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`075f2000 fffff880`075fb000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`060d3000 fffff880`060e1000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e5f000 fffff880`03ee2000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03ee2000 fffff880`03f00000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02deb000 fffff880`02dfa000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0192e000 fffff880`01944000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05362000 fffff880`05384000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`060ed000 fffff880`060f6000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`060e1000 fffff880`060ed000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`060f6000 fffff880`06109000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06109000 fffff880`06115000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`050c8000 fffff880`051bc000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`06115000 fffff880`061ed000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`01800000 fffff880`01825000   ehdrv    ehdrv.sys    Wed Jul 14 04:14:21 2010 (4C3D71DD)
fffff880`02ddf000 fffff880`02deb000   ElbyCDIO ElbyCDIO.sys Tue Nov 30 15:43:34 2010 (4CF561F6)
fffff880`07400000 fffff880`07421000   epfwwfpr epfwwfpr.sys Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`01197000 fffff880`011ab000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0114b000 fffff880`01197000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013e6000 fffff880`013f0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018f4000 fffff880`0192e000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`015ab000 fffff880`015f5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`03608000 fffff800`03651000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`052c9000 fffff880`05325000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`01fc0000 fffff880`01fd9000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`01fd9000 fffff880`01fe1080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01fb2000 fffff880`01fc0000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`07456000 fffff880`0751e000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f5000 fffff880`015fe000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04225000 fffff880`04234000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e1d000 fffff880`01e2b000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b9b000 fffff800`00ba5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04245000 fffff880`04288000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013bb000 fffff880`013d5000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01580000 fffff880`015ab000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05384000 fffff880`05389200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`05e21000 fffff880`05e36000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01e2b000 fffff880`01e4e000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c9b000 fffff880`00ca8000   mcupdate mcupdate.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`01f87000 fffff880`01f95000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04234000 fffff880`04243000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e00000 fffff880`01e0d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00dda000 fffff880`00df4000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0753c000 fffff880`07554000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07554000 fffff880`07581000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`07581000 fffff880`075cf000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`075cf000 fffff880`075f2000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00c2a000 fffff880`00c35000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01883000 fffff880`0188e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f8f000 fffff880`00f99000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02dd4000 fffff880`02ddf000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01418000 fffff880`0142a000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0142e000 fffff880`01520000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04370000 fffff880`0437c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`01e4e000 fffff880`01e61000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0437c000 fffff880`043ab000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`052b4000 fffff880`052c9000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d79000 fffff880`02d88000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cef000 fffff880`02d34000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01520000 fffff880`01580000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01e61000 fffff880`01f7a000   netr28ux netr28ux.sys Mon Apr 19 08:25:12 2010 (4BCC4BA8)
fffff880`0188e000 fffff880`0189f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03651000 fffff800`03c2d000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01218000 fffff880`013bb000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019dc000 fffff880`019e5000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0429a000 fffff880`042b2000   nusb3hub nusb3hub.sys Mon Jul 26 20:45:44 2010 (4C4E2C38)
fffff880`0486a000 fffff880`0489a000   nusb3xhc nusb3xhc.sys Mon Jul 26 20:45:44 2010 (4C4E2C38)
fffff880`0538a000 fffff880`053dd000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d3d000 fffff880`02d63000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04309000 fffff880`04326000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00fd9000 fffff880`00fee000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fa6000 fffff880`00fd9000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013d5000 fffff880`013e6000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07803000 fffff880`078a9000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`01e0d000 fffff880`01e1d000   point64  point64.sys  Tue Jun 29 04:54:31 2010 (4C29B4C7)
fffff880`05325000 fffff880`05362000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ca8000 fffff880`00cbc000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0434c000 fffff880`04370000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043ab000 fffff880`043c6000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043c6000 fffff880`043e7000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04200000 fffff880`0421a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0421a000 fffff880`04225000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01868000 fffff880`01871000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01871000 fffff880`0187a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0187a000 fffff880`01883000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`00c49000 fffff880`00c83000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05e36000 fffff880`05e4e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`042cb000 fffff880`042fd000   Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`05e77000 fffff880`060d2d80   RTKVHD64 RTKVHD64.sys Fri Sep 03 04:02:27 2010 (4C80AB93)
fffff880`078a9000 fffff880`078b4000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`042fd000 fffff880`04309000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d88000 fffff880`02da5000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01410000 fffff880`01418000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0795a000 fffff880`079f0000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`078f3000 fffff880`0795a000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`078b4000 fffff880`078e1000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`010de000 fffff880`01140000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`04243000 fffff880`04244480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`078e1000 fffff880`078f3000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`018bd000 fffff880`018ca000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0189f000 fffff880`018bd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02dc0000 fffff880`02dd4000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00460000 fffff960`0046a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03f11000 fffff880`03f37000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04288000 fffff880`0429a000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`01fe2000 fffff880`01ffcc00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`01f95000 fffff880`01fb2000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0489a000 fffff880`0489bf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`051ea000 fffff880`051fb000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0525a000 fffff880`052b4000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`051df000 fffff880`051ea000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03fa1000 fffff880`03ff7000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00f99000 fffff880`00fa6000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01825000 fffff880`01833000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01833000 fffff880`01858000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01400000 fffff880`01410000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`011ab000 fffff880`011f7000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01f7a000 fffff880`01f87000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02d63000 fffff880`02d79000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02da5000 fffff880`02dc0000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01858000 fffff880`01868000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e7c000 fffff880`00f20000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f20000 fffff880`00f2f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d34000 fffff880`02d3d000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`03f4c000 fffff880`03f55000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f86000 fffff880`00f8f000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05e00000 fffff880`05e21000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`09202000 fffff880`09273000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0197c000 fffff880`0198a000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0198a000 fffff880`01996000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01996000 fffff880`0199f000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0199f000 fffff880`019b2000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
valer
I've done what you've said and I'm still bsoding with the same error
In this case:
1. Attach the newest crash dumps
2. Submit results of HDD scan
3. Confirm that you have performed Start >> cmd >> chkdsk /r /f
4. Give link to your memory sticks with the official specs.
valer
#7
I ran chkdsk again and the computer BSODed straight after finishing it ( while getting into Windows).
Here is my HDDScan and dump of the crash.
This is the RAM that I am using Kingston ValueRam KVR1333D3N9K2/4G 4GB DDR3 1333MHz (2x2GB) | Kingston Desktop Memory
I'll upload photos of the finished chkdsk when my camera finishes transferring.
The programs you asked to be uninstalled have been, and I have updated the realtek driver [EDIT] I updated the driver after the bsod happened (the one in the dump)
valer
#8
Ok here's the picture of the completed chkdsk. Attached is another BSOD that happened shortly after installing the realtek drivers. Do you think this might be a hardware issue? kdk_1107.jpg
Elmer
#9
Hi valer,
Your latest dump shows this Realtek driver hasn't changed since cybercores post (#4)
Rt64win7.sys Thu Feb 26 09:04:13 2009
That needs seriously updating. Realtek LAN look at version 7.034, that should hopefully update it.
This driver is also not the latest, but not as bad as above:
RTKVHD64.sys Fri Sep 03 09:02:27 2010
Sorry cybercore mate, thought you'd gone for some shut eye, thought I'd move the bus on for you.
Ok thanks guys, I seem to have installed the 6.111 driver. Lets hope that this one is good :D
#11
Ok it did it again, this time with the new drivers. This is really starting to annoy me :mad:.
I've attached the latest dump. Do you think this may be a hardware issue?
#14
OK will do, thanks for your help. It just BSODed twice in the last 10 minutes :p Both have exactly the same error codes.
#15
The latest crash dump points to memory corruption again, and all your drivers are up to date. The crash was again caused by the system's kernel file. Definitely a hardware issue, and I would not at all exclude RAM from the list of suspected causers.
010811-18470-01.dmp
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800039030e0
fffffa7cffffffe0
You could update USB 3.0 motherboard driver to the latest, but it won't fix you anyway:
1. The RAM is set right. However, CPU-Z does not show all settings, so enter your bios setup just to check -> Chipset -> Advanced -> DRAM -> see if all the settings there are set "Auto." If some of them are not "Auto", then tell me what the values are for the memory clock and for the voltage.
2. Run memtest overnight.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010811-18470-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0365b000 PsLoadedModuleList = 0xfffff800`03898e50
Debug session time: Sat Jan  8 03:50:19.345 2011 (UTC - 5:00)
System Uptime: 0 days 0:06:52.046
BugCheck A, {fffffa7cffffffe0, 2, 1, fffff80003712349}
0: kd> !analyze -v
Arguments:
Arg4: fffff80003712349, address which referenced memory
Debugging Details:
 fffffa7cffffffe0
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`03712349 f0410fba6d1000  lock bts dword ptr [r13+10h],0
BUGCHECK_STR:  0xA
rax=000000000000000a rbx=0000000000000000 rcx=0000000000000000
rip=fffff80003712349 rsp=fffff880009a9c10 rbp=00000000000000ff
fffff800`03712349 f0410fba6d1000  lock bts dword ptr [r13+10h],0 ds:5b60:00000000`00000010=????????
LAST_CONTROL_TRANSFER:  from fffff800036caca9 to fffff800036cb740
STACK_TEXT:
fffff880`009a9938 fffff800`036caca9 : 00000000`0000000a fffffa7c`ffffffe0 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`009a9940 fffff800`036c9920 : 00000000`00000000 ffffffff`efffffff 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009a9a80 fffff800`03712349 : 00000000`000000ff 00000000`00000005 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
fffff880`009a9c10 fffff800`0396fc06 : fffffa80`039d5b60 00000000`00000080 fffffa80`039d5040 fffff800`036a9c19 : nt!MmZeroPageThread+0x3d4
fffff880`009a9d40 fffff800`036a9c26 : fffff800`03845e80 fffffa80`039d5b60 fffff800`03853c40 ff097704`f9830e72 : nt!PspSystemThreadStartup+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Drivers:
fffff880`00f24000 fffff880`00f7b000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c3b000 fffff880`02cc5000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0436d000 fffff880`04383000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03f3f000 fffff880`03f54000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`010f2000 fffff880`010fd000   amdxata  amdxata.sys  Wed Oct 07 16:13:10 2009 (4ACCF656)
fffff880`05496000 fffff880`054a1000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e63000 fffff880`00e6c000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0482e000 fffff880`0503f000   atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`03f5d000 fffff880`03fa9000   atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff880`01973000 fffff880`0197b000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`008c0000 fffff960`00921000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`019e4000 fffff880`019eb000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03f08000 fffff880`03f19000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`039bf000 fffff880`039dd000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006c0000 fffff960`006e7000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`019b1000 fffff880`019db000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d0b000 fffff880`00dcb000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01943000 fffff880`01973000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cad000 fffff880`00d0b000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0435d000 fffff880`0436d000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0389e000 fffff880`038a7000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`06b68000 fffff880`06b76000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e67000 fffff880`03eea000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03eea000 fffff880`03f08000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c17000 fffff880`02c26000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0192d000 fffff880`01943000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`053ab000 fffff880`053cd000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06b82000 fffff880`06b8b000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06b76000 fffff880`06b82000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06b8b000 fffff880`06b9e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06b5c000 fffff880`06b68000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0503f000 fffff880`05133000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`05133000 fffff880`05179000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`01149000 fffff880`0115d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010fd000 fffff880`01149000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018f3000 fffff880`0192d000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`03612000 fffff800`0365b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`05179000 fffff880`0519d000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05312000 fffff880`0536e000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`06af2000 fffff880`06b0b000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06b0b000 fffff880`06b13080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06ae4000 fffff880`06af2000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`038f7000 fffff880`039bf000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018ea000 fffff880`018f3000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04246000 fffff880`04255000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06b4e000 fffff880`06b5c000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba1000 fffff800`00bab000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04266000 fffff880`042a9000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`053cd000 fffff880`053d2200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02821000 fffff880`02836000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`029be000 fffff880`029e1000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c8c000 fffff880`00c99000   mcupdate mcupdate.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`029b0000 fffff880`029be000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04255000 fffff880`04264000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06b31000 fffff880`06b3e000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00ddb000 fffff880`00df5000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`039dd000 fffff880`039f5000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03800000 fffff880`0382d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0382d000 fffff880`0387b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0387b000 fffff880`0389e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`015e2000 fffff880`015ed000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f84000 fffff880`00f8e000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0115d000 fffff880`011bb000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c0c000 fffff880`02c17000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018d8000 fffff880`018ea000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014d7000 fffff880`015c9000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`043a7000 fffff880`043b3000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`029e1000 fffff880`029f4000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`043b3000 fffff880`043e2000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`052fd000 fffff880`05312000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d4f000 fffff880`02d5e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cc5000 fffff880`02d0a000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0288a000 fffff880`029a3000   netr28ux netr28ux.sys Mon Apr 19 08:25:12 2010 (4BCC4BA8)
fffff880`015ed000 fffff880`015fe000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c00000 fffff880`02c0c000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0365b000 fffff800`03c37000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0124e000 fffff880`013f1000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019db000 fffff880`019e4000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`04800000 fffff880`04818000   nusb3hub nusb3hub.sys Mon Jul 26 20:45:44 2010 (4C4E2C38)
fffff880`0519d000 fffff880`051cd000   nusb3xhc nusb3xhc.sys Mon Jul 26 20:45:44 2010 (4C4E2C38)
fffff880`02836000 fffff880`02889000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d13000 fffff880`02d39000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04340000 fffff880`0435d000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00fce000 fffff880`00fe3000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f9b000 fffff880`00fce000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00dcb000 fffff880`00ddb000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`054a4000 fffff880`0554a000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06b3e000 fffff880`06b4e000   point64  point64.sys  Tue Jun 29 04:54:31 2010 (4C29B4C7)
fffff880`0536e000 fffff880`053ab000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c99000 fffff880`00cad000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04383000 fffff880`043a7000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043e2000 fffff880`043fd000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04200000 fffff880`04221000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04221000 fffff880`0423b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02daa000 fffff880`02dfb000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0423b000 fffff880`04246000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01835000 fffff880`0183e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0183e000 fffff880`01847000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015d9000 fffff880`015e2000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0189e000 fffff880`018d8000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06b9e000 fffff880`06bb6000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`042ce000 fffff880`04334000   Rt64win7 Rt64win7.sys Tue Nov 30 01:01:28 2010 (4CF49338)
fffff880`06888000 fffff880`06ae3d80   RTKVHD64 RTKVHD64.sys Fri Sep 03 04:02:27 2010 (4C80AB93)
fffff880`0554a000 fffff880`05555000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04334000 fffff880`04340000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d5e000 fffff880`02d7b000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01896000 fffff880`0189e000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06800000 fffff880`06871000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`05400000 fffff880`05496000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`05594000 fffff880`055fb000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`05555000 fffff880`05582000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`01090000 fffff880`010f2000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`04264000 fffff880`04265480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`05582000 fffff880`05594000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01235000 fffff880`01242000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`011bb000 fffff880`011d9000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d96000 fffff880`02daa000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03f19000 fffff880`03f3f000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`042a9000 fffff880`042bb000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06b14000 fffff880`06b31000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`051cd000 fffff880`051cef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`051da000 fffff880`051eb000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052a3000 fffff880`052fd000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`051cf000 fffff880`051da000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03fa9000 fffff880`03fff000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00f8e000 fffff880`00f9b000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019eb000 fffff880`019f9000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01800000 fffff880`01825000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015c9000 fffff880`015d9000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fe3000 fffff880`00ff8000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0184a000 fffff880`01896000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`029a3000 fffff880`029b0000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02d39000 fffff880`02d4f000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02d7b000 fffff880`02d96000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01825000 fffff880`01835000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e71000 fffff880`00f15000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f15000 fffff880`00f24000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d0a000 fffff880`02d13000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03f54000 fffff880`03f5d000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f7b000 fffff880`00f84000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02800000 fffff880`02821000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0197b000 fffff880`01989000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01989000 fffff880`01995000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01995000 fffff880`0199e000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0199e000 fffff880`019b1000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
#16
The RAM is running at 1.504 V and 6.66x 1333mhz Unganged. All of the values are auto.
I will memtest in a couple of minutes.
#17
You're supposed to do a full run during 10 passes literally overnight.
#18
OK I just finished the memtest. I got no errors at all. I managed to get all 10 passes by the morning. So that rules out the ram right? The 'memory corruption' BSODs are occurring when I play Call of Duty 4, and I always get the same error codes, however other BSODs also occur while using firefox, Fl studio, Photoshop etc. Will attach a pic if you want(of the memtest).
#19
Not yet. What else to try:
1. Uninstall Catalyst and then run Driver Sweeper to clean up:
Guru3D - Driver Sweeper
2. Install any Catalyst before version 10.10. I would recommend Catalyst 10.3 - 10.9
3. If the Catalyst does not fix it, reformat and reinstall the system.
4. Remove one of the RAM sticks and see if it's any better. Then try another stick. Then try another RAM slot.
#20
Not completely sure if I can reinstall as I don't have a disc, but I will roll back the drivers and try to replace/change the ram.
I just BSODed as I was writing you this very message, and here is the dump.
This BSOD says "MEMORY MANAGEMENT"
A strange thing to point out, is that the BSODs dont auto restart anymore, but instead say something along the lines of 'Ask an admin for help'
Thanks for your help.
