Upgrade help
sameh83
Well-Known Member
I have windows 8 pro and i want to upgrade to windows 8.1 final. However, the upgrade doesn't show up in the store for me. I have made sure that all of the windows updates are installed to make sure all of the patches are installed, but no luck. Any help? or, do i need to clean install a different version?
davidhk129
Read your own screenshot. Go to Windows Activation heading. What does it say ?
Windows is not activated.
You cannot get win 8.1 until you have activated the Win 8 first.
