Windows 7 Upgraded to Winodws 7 Today, but audio no longer works.
blakelemonj
Hello, I upgraded to windows 7 with the Cd that was given with the Free windows update for recent vista purchases. It's windows 7 Home Premium. Anyway, the installation was smooth and everything works, except my audio and i would really appreciate some help, thanks here are my specs.
Some was removed due to space issues, refer to the attachment for more detail :D.
System Information
Time of this report: 10/27/2009, 22:41:03
Machine name: BLAKES-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 03/27/09 10:24:37 Ver: 16.03
Processor: AMD Phenom(tm) II X4 955 Processor (4 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 8192MB RAM
Page File: 1446MB used, 14934MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x9440)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9440&SUBSYS_24481682&REV_00
Display Memory: 4083 MB
Dedicated Memory: 1015 MB
Shared Memory: 3067 MB
Current Mode: 1440 x 900 (32 bit) (75Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: E19T6W
Monitor Id: EMA0782
Native Mode: 1440 x 900(p) (60.070Hz)
Output Type: DVI
Driver Name: atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.14.0010.0700 (English)
Driver Version: 8.661.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 18:00:58, 4649472 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-D700-11CF-8E77-4204A1C2C535}
Vendor ID: 0x1002
Device ID: 0x9440
SubSys ID: 0x24481682
Revision ID: 0x0000
Driver Strong Name: oem2.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R7X:8.661.0.0:pci\ven_1002&dev_9440
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_E721&SUBSYS_104382EA&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: n/a
Date and Size: 7/13/2009 20:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line In (High Definition Audio Device)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Cap Flags: 0x1
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_82EF1043&REV_00\3&267A616A&0&A1
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_82EF1043&REV_00\3&267A616A&0&88
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_82EF1043&REV_00\3&267A616A&0&A5
Driver: n/a
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_82EF1043&REV_3A\3&267A616A&0&A0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_82EF1043&REV_00\3&267A616A&0&99
Driver: n/a
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_00\3&267A616A&0&A4
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_82EF1043&REV_00\3&267A616A&0&91
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_82EA1043&REV_00\3&267A616A&0&A2
Driver: n/a
Name: Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_82C61043&REV_02\4&C9CCDE8&0&0030
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_82EF1043&REV_00\3&267A616A&0&98
Driver: n/a
Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301682&REV_00\4&31C4F86D&0&0110
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_82EF1043&REV_00\3&267A616A&0&90
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1022&DEV_9603&SUBSYS_82EE1043&REV_00\3&267A616A&0&10
Driver: n/a
Name: ATI Radeon HD 4800 Series
Device ID: PCI\VEN_1002&DEV_9440&SUBSYS_24481682&REV_00\4&31C4F86D&0&0010
Driver: n/a
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16385
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16385
Audio Capture Sources:
Microphone (High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7600.16385
Line In (High Definition Audio ,0x00200000,0,0,qcap.dll,6.06.7600.16385
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7600.16385
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16385
Digital Audio (S/PDIF) (High De,0x00200000,1,0,quartz.dll,6.06.7600.16385
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16385
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16385
Does device manager show the audio drivers as working correctly?
I had to locate and download new sound drivers to get rid of error messages in my adminstrative logs
I agree, you probably just need to install the motherboard audio drivers.
So you guys suggest i try popping in the motherboard disc and see if i can reinstall the drives on it? Even if its not for windows 7?
Why try the motherboard disc? They not only wouldn't have Windows 7 drivers, but they'd have older drives at that.
I'd hit up the manufacturer's web site who made your motherboard. Give that a shot.
If you have a brand new ASUS motherboard, it might have the drivers!!
