urgent help regarding windows vista ultimate 32bit
dearmoawiz
Hello
i install windows vista ultimate 32bit without product key. i just want to use it for 30 days but when installation complete nothing is working properly when i tried to click on control panel or any thing else nothing opened and even i am not able to open personalize computer to change settings.
i m using ist time windows vista so thats why i dont know what is the real problem please guide me for assistance
waiting for kind response
Regards,
Moawiz
Windows Forum Admin
Where did you obtain the copy? If it's from a torrent site it may be that the copy itself is bad.
thuydung88
The only Anti-Virus solution I have fount that works with Windows Vista X64 is Avast 4 VPS. The best part is it is available for free for home use and con ba downloaded from Avast's Website here..
The only issue I have found so far is the automatic updater is not working yet and you will have to manually update.
