Windows 7 USB BUG CODE, what to do ?
JeanP
Hello everyone,
I keep getting a USB BUG CODE BSOD for two weeks now. No particular change on hardware or software that I recall which may have triggered this.
I checked my system with the following softwares (which are up to date) :
Avira Antivir
Malwarebytes
Glary Utilities
HijackThis
And it is definitely clean.
System drivers and Windows Vista are up to date.
Please find attached :
1) 3 screenshots from CPU-Z
2) SF Diagnostic Tool folder (zipped)
3) RAMMon HTML report (zipped)
JeanP - CPU-Z - Memory.PNGJeanP - CPU-Z - SPD1.PNGJeanP - CPU-Z - SPD2.PNGView attachment JeanP - RAMMon - SPD Info.zipView attachment JeanP - Seven Forums.zip
Please note that the USB BUG CODE is the most frequent BSOD I get, but if you look at the dump files you'll actually see a mixed bag of reasons.
I think it is wise to focus on this one, please share your thoughts on the matter if you want to.
Can anyone see the beginning of an answer ?
I'm getting quite desperate to be honest.
If you need further information, please tell me so and I will provide it as soon as possible.
Thanks a lot to everybody reading this.
Regards,
JeanP
The problem is getting more and more frequent.
Sometimes before i can even log in to Windows.
Does that indicate a hardware problem in your opinion ?
Thanks for your help.
Anyone ?
If upgraded my SSD's firmware and did a full RAM test with Memtest86+ but the problem is still there. :(
Top Bottom
